Old 02-10-2005, 04:16 PM
GTO71's Avatar
GTO71 GTO71 is offline
The Crank and Cam in the block. Nodluar Iron Indexed Crank..
Old 02-10-2005, 04:22 PM
GTO71's Avatar
Enlarging the wristpen end to install a bushing for to make the robs free floating. Yes I know you can buy them this way. OH SH#T No one will miss that extra ten thousands!!!!!
Old 02-10-2005, 04:29 PM
GTO71's Avatar
Thw Comp XR-288-10 cam is now in the block, I spent some time on removing the flashings on the outside of the lifterbores and "smothing" out the lifter gallery area for better oil return.
Old 02-24-2005, 01:33 PM
GTO71's Avatar
Block Now has the Pistons in it, man I starting to get excited now!
Old 02-24-2005, 01:38 PM
GTO71's Avatar
THe slugs .005 in the hole, custom made JE Pistons 0.60 over.
Old 02-24-2005, 01:40 PM
GTO71's Avatar
Side pic got that Milodon Oil pan off the parts for sale section in this forum.
Old 02-24-2005, 01:41 PM
GTO71's Avatar
Side Pic
Old 02-24-2005, 01:45 PM
GTO71's Avatar
Just a Pic of the Timing Cover with the new SFI balancer. Degreed in the Camshaft, got a adjustable true double roller chain under there.
Old 02-24-2005, 01:48 PM
GTO71's Avatar
Another Side pic. More to Come soon................
Old 02-24-2005, 01:55 PM
Formula jg Formula jg is offline
Which damper is that?
Old 02-24-2005, 09:59 PM
67vertBird 67vertBird is offline
Looks nice, what kind of compression will that setup get you? I am just a week or 2 behind you on a 400 build.
67 Firebird 400 Convertible (sold)
Old 02-25-2005, 01:50 AM
GTO71's Avatar
Romac dampner, 9.5 to 1 Compression.
Old 02-25-2005, 03:47 PM
ErikW's Avatar
ErikW ErikW is offline
Arias or JE, which are they?
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 02-25-2005, 06:11 PM
GTO71's Avatar
Sorry the are JE, Ihad two sets of slugs and I was in a hurry when I posted the pictures.
Old 02-25-2005, 06:49 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Am I missing something here?? A .060 over 400 with 102cc chambered heads will not give you anywhere close to 9.5:1 CR. You're more like 8:1 if the specs you gave are correct.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 02-25-2005, 07:45 PM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
Keep us informed on whether it runs as good as it looks. That's the real deal...
Old 02-25-2005, 11:44 PM
GTO71's Avatar
Not missing anything, but you can't assume that I would give away me whole combo's specs!!!
  #38
Old 02-26-2005, 04:09 AM
Jagtec1's Avatar
Blown? Turbo? Cuz, it's not 9.5:1!! Looks good, good luck with it. Just wondering why you said it would be 9.5:1 with those specs.
Darin
9.81 @ 136.39MPH
  #39
Old 02-26-2005, 07:21 AM
Mo's Avatar
Mo Mo is offline
Maybe that crank has a little extra stroke in it.
Systems under stress fail catastrophically
  #40
Old 02-26-2005, 10:03 AM
Jagtec1's Avatar
Could be, but it wouldn't be a 400 then! (See topic header) Just breakin stones! If it's a 4.21 stroke, that puts him right around 9:1.
Darin
9.81 @ 136.39MPH
