Old 02-26-2005, 11:51 AM
roadrage david roadrage david is offline
400 stroker to 461(4.25 stroke)
  #42
Old 02-26-2005, 12:31 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
I'm building a "400" also! Says so right on the block!
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
  #43
Old 02-26-2005, 12:37 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
have not looked at an after market crank in a while but that crank has no hash markes for the rear seal don't look like a 400 crank to me
www.pro-touringf-body.com
  #44
Old 03-01-2005, 04:20 PM
GTO71's Avatar
GTO71 GTO71 is offline
No, I am having 9.5 comp with the custon pistons, also if you look on how most piston companys rate compression ratios with heads they are usually rated with the pistons .008 in the whole and the TRW pistons have for valve releafs, using a head gasket of about 45 thousands. My gaskett is 37 thousands compressed and like I said I have custom piston made up to get the compression of 9.5 to 1 and I said that my slugsd were .005 in the hole but they relly close to being a 0 Deck height.
  #45
Old 03-01-2005, 06:55 PM
Jagtec1's Avatar
Are they domed pistons??? Don't look like it. My calculations with .037 compressed gasket, zero deck, and let's say 5cc valve relief area still only come to around 8.3:1 with a 3.75 stroke and 4.181 bore (If that is what the bore and stroke are). I'm not trying to be a jacka$$, just curious as to how you are arriving at those compression #'s with a 102cc head.
Darin
9.81 @ 136.39MPH
  #46
Old 03-01-2005, 07:50 PM
loren loren is offline
nice
  #47
Old 03-02-2005, 08:45 AM
GTO71's Avatar
No man, They are custom made pistons, I gave the piston manufactor the spec of my rod lenght, deck height, cc of chamber and head gasket thickness and got a piston designed to get a 9.5 to 1 ratio. Jeez I put pics up for peolpe to enjoy and get my head bit off. I got too much time invested and money not to waste by goofing up on a compression issue!!!!!
  #48
GTO71's Avatar
And I will let my time slips to the talking.
  #49
Old 03-02-2005, 09:08 AM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
Time slips won't be talking that loud with that c.r. Unless with some kind of boost.
  #50
Old 03-02-2005, 09:11 AM
russ467's Avatar
russ467 russ467 is offline
70 Formula
Old engine:
467 HO headed
6.79 1/8th mile @ 101.87 no N20. 1.44 60ft
6.23 1/8th @ 111.83 w/nitrous
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Few test passes made. Tore it up. Just got it fixed.
  #51
Old 03-02-2005, 09:17 AM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
gto71, what machine shop were/are you using?
costs too much
  #52
Old 03-02-2005, 03:48 PM
Jagtec1's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by GTO71:
No man, They are custom made pistons, I gave the piston manufactor the spec of my rod lenght, deck height, cc of chamber and head gasket thickness and got a piston designed to get a 9.5 to 1 ratio. Jeez I put pics up for peolpe to enjoy and get my head bit off. I got too much time invested and money not to waste by goofing up on a compression issue!!!!! </div></BLOCKQUOTE>
Dude, relax! Nobody's biting any heads off. I was curious as to how you arrived at those numbers! I asked a few questions...SFW. You posted your combo, and some pics, and you don't want to answer any questions about it??! I still am not sure how you are getting the numbers you are claiming. But, I guess either it's "Top Secret", or you're not really sure. Either way...I'd be interested in your time slips. If you don't want to share your info, then why post the combo and pics in the first place? What did they do to your custom pistons that will allow you to achieve 9.5:1 CR in a .060 over 400 with 102cc chambers...if they are not domed?? Seriously, I'm curious! I agree that you'll need a bit more compression based on MY calculations to pull off some serious time slips with that 400. Good luck with it! (Not being sarcastic)
Darin
9.81 @ 136.39MPH
  #53
Old 03-02-2005, 04:35 PM
Mo's Avatar
Mo Mo is offline
That motor is just begging for a power adder or blower of some sort.
Systems under stress fail catastrophically
  #54
Old 03-02-2005, 05:16 PM
GTO71's Avatar
STOP KILLIN ME EVERBODY!!!!!!!!!!!! I will get the specs back up here on Friday. Most of this crap I was going by off memory!!!!
  #55
Old 03-03-2005, 08:26 PM
GTO71's Avatar
Finally got the heads on now
  #56
Old 03-03-2005, 08:29 PM
GTO71's Avatar
Side pic
  #57
Old 03-03-2005, 08:34 PM
GTO71's Avatar
Rear Pic
  #58
Old 03-03-2005, 08:39 PM
GTO71's Avatar
The Roller Lifters
  #59
Old 03-17-2005, 03:58 PM
GTO71's Avatar
1.60 Comp roller rockers
  #60
Old 03-17-2005, 04:03 PM
GTO71's Avatar
Intake manifold ported to heads & gasket
