04-06 Wheels/Tires Stay stock or go custom? |
![Reply](images/cars/buttons/reply.gif) |
![Old](images/cars/statusicon/post_old.gif)
01-04-2005, 01:23 PM
My 2004 GTO has only 7500 miles on it, but the rear tires are worn down to the wear bars! The fronts are about 30% gone. I haven't been smoking the tires either. I heard the BFG gForce tires were only good for 10-20k miles, but this is rediculous!
Have any of you experienced similar levels of wear?
01-04-2005, 03:37 PM
![Mr_GTO's Avatar](image.php?u=146427&dateline=1514149214) |
Have you checked your pressure? Or to see if the dealer removed the helper springs in the suspension?
Take it to the dealer and bitch and moan.
01-04-2005, 09:41 PM
![RandyW's Avatar](image.php?u=132318&dateline=1219774794) |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> I haven't been smoking the tires either. <HR></BLOCKQUOTE>
Sure you haven't!!
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold)
01-05-2005, 12:54 PM
I work at a Pontiac dealership, and one problem I have found is that these tires are shipped from Australia with 60lbs in each tire. If your dealership dosn't correct this at delivery it can cause problems.
01-06-2005, 12:58 PM
Mr_GTO,
Yes, I've checked tire pressure. What are "helper springs?"
01-06-2005, 04:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PK:
Mr_GTO,
Yes, I've checked tire pressure. What are "helper springs?" <HR></BLOCKQUOTE>
The factory installs them for shippment from Australia. Many dealers miss them when they prep the car.
A good site for your new GTO is www.ls1gto.com
01-06-2005, 04:55 PM
Mr_GTO,
Helper springs are "springs" of a sort attached to the undercarriage. They are frequently used when shipping cars overseas to lessen the up and down motion a car might experience in transit. They need to be removed upon receipt of the vehicle.
01-06-2005, 06:03 PM
![T.D.Vick's Avatar](image.php?u=137899&dateline=1706381016) |
They're rubber spacers jammed between the front coils. They squeak like crazy when they get wet too. Mine had them left in and the tires were at 55 PSI when I picked the car up. At 7500 miles I had to rotate the tires, the rears were about 2/3 gone. No big burnouts from me either.
'80 Grand Lemans
Was 301 C.I. Will be bigger soon.
00 GTP NBM / Graphite, Stock
Sold Aug. 2011
70 GTO Black / Black TH400
460 CID, 542 FWHP, 580 FWTQ
(Sold, Fall '09)
04 GTO Black / Black M6
Back to bone stock and sold, fall '05.
01-10-2005, 12:45 PM
I have noticed a squeak the last couple of days when I hit a bump. It's not loud but it's noticeable. How easy are the helper springs to spot? I need to check to make sure mine weren't left in.
01-10-2005, 07:26 PM
Turn your steering wheel all the way to one side and look at the front springs. You'll see the rubber spacers in the coils. When mine were removed I also had to adjust my headlights up quite a bit. The front of the car does drop down when they're removed.
'80 Grand Lemans
Sold Aug. 2011
(Sold, Fall '09)
01-11-2005, 12:37 PM
I didn't see anything but I am going to take it in and have the dealship check it anyways. I checked the tire pressure and it was WAY off. All four set at 55 psi.
01-11-2005, 04:38 PM
tires @ 55 psi...helper springs left in ?Whatever happened to dealer prep. before a customer picks up their new ride? jeez!
01-13-2005, 02:06 PM
![Goathead's Avatar](image.php?u=139862&dateline=1280949019) |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Whatever happened to dealer prep. before a customer picks up their new ride? jeez! <HR></BLOCKQUOTE>
Dealer prep nowadays is "here are the key's". If you catch something we were supposto do, we will have an excuse when you come back to fix it right...
03-08-2005, 08:27 AM
I HAVE THE SAME PROBLEM WITH THE REAR TIRES.MY GTO ONLY HAS 6,000 MILES ON IT.WHAT DID YOU END UP DOING. IS SOMEBODY HELPING YOU WITH THIS.
03-17-2005, 01:17 PM
I just passed the 20K mark and my rears are complete trash. But mine are due to testosterone surges. I love driving this car!
Matt H.
04 Barb. Blue M6 GTO
Member:GatewayGTO & GTOAA
25K miles and counting.....
03-18-2005, 08:00 AM
At 19,900 miles on my 2004 GTO driving 60 mph on an interstate off ramp without, my rear end shimmyed, then the car corrected itself. I only then noticed white smoke coming from the right rear. By the time I pulled over the entire tire separated from the rim.
Even though I check tire pressure every month, when the 20,000 mile make hits, I have truly appreciated the tires are unforgiving. Fortunately this car is so stable that I was able to safely navigate to the side of the road.
I also found out that Michline rated tires for the GTO DO NOT FIT as I was opting for their 40,000 mile rating. After four days of waiting for tires to be delivered, tested, and not fitting, I resolved to go back to the original Goodrich tires. So now I am contributing to my piggy bank in anticipation of the next 15,000 miles when I will have to replace them again, this time BEFORE THEY BLOW. I hope this advice saves some one from a less fortunate outcome when the tire completely peels away from the wheel.
You can live without your lover, but you cannot love without your liver.
