Old 05-16-2005, 06:58 AM
slowbird's Avatar
slowbird slowbird is offline
Besides price what is the difference between the CSR and the Meziere water pumps.
slowbird's Avatar
Old 05-16-2005, 07:08 AM
SlowSpitzer's Avatar
SlowSpitzer SlowSpitzer is offline
Might not mean squat, but had my Meziere for 4 1/2 years with no problems.
Steve
Yea, I know, the heads suck!
2005 Cordova Q16 Winner!
2005 Norwalk Sat Top ET Winner!
Old 05-16-2005, 07:13 AM
60man's Avatar
60man 60man is offline
Guess I need to replace the old Mr. Gasket belt drive WP. Was pulling 220 + on return road after some passes yesterday. Haven't made up my mind yet...
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 05-16-2005, 08:29 AM
mikeb mikeb is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 60man:
Guess I need to replace the old Mr. Gasket belt drive WP. Was pulling 220 + on return road after some passes yesterday. Haven't made up my mind yet... </div></BLOCKQUOTE>
I had the same problem saturday at the PSN with my moroso belt drive setup (saw 240 in the lights and shut it off at 100mph). I also have the same question re: CSR vs. Meziere.
Old 05-16-2005, 09:22 AM
ErikW's Avatar
ErikW ErikW is offline
Hey 60man. You need to update your profile. I could have sworn I saw you running 11's!! Got that thing running good!
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 05-16-2005, 09:27 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
The major difference is that the CSR uses the stock divider plate and bushings and the Meziere has them built in, hence the price difference. We sell the CSR ($199.99) and have had great feedback. I run one on my own car.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 05-16-2005, 12:50 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
60Man, Yes you should get one. I used to run that blet drive deal & i got rid of it because it was doing exactly what your's is. I have the CSI/CSR one & love it.
Old 05-16-2005, 01:57 PM
60man's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Erik W:
Hey 60man. You need to update your profile. I could have sworn I saw you running 11's!! Got that thing running good! </div></BLOCKQUOTE>
Thanks Eric. Guess I should update the profile.
That is one sweet looking & bad ass 64 GTO you have Eric. I would love to see you and Jeff Raff side by side one day. See you at Norwalk or before..
ECM member.
MANDRA
Old 05-16-2005, 02:00 PM
60man's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Scott Esterle:
60Man, Yes you should get one. I used to run that blet drive deal & i got rid of it because it was doing exactly what your's is. I have the CSI/CSR one & love it. </div></BLOCKQUOTE>
Thanks Scott. I'll check them both out. I keep forgetting your extention..Would you email it or post it here.
ECM member.
MANDRA
Old 05-16-2005, 02:06 PM
BVR421's Avatar
BVR421 BVR421 is offline
One more vote for CSI pump, mine is great and a rebuild kit is about 15bucks if its ever needed.
I would never do it but Ive heard they work just fine on a street car as well.
Old 05-16-2005, 04:08 PM
Old 05-16-2005, 06:32 PM
60man's Avatar
Thanks Scott
ECM member.
MANDRA
Old 05-17-2005, 08:02 AM
quicksilver97ta's Avatar
Were can I find that csi?
Old 05-17-2005, 08:22 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by quicksilver97ta:
Were can I find that csi? </div></BLOCKQUOTE>
http://www.bopengineering.com/beltdr..._topend3.shtml
Wade Congdon
BOP Engineering
Old 05-24-2005, 05:28 AM
60man's Avatar
OK. I got a CSR/CSI water pump. Went to install it and have a problem with alternator belt routing. Belt will hit WP motor as is.. My car has PS/ALT set up typical of 64/65 up cars. Both piggy back on driver side. I need to move alt. to get belt out of the way. I will eventialy ditch PS as soon as I find a manual box...but mean while I would like to run CSR pump!! I ordered a alt. relocation kit and going to try mounting alt. on Pass. side cyl. head and try it. Any street/strip guys running this pump with power steering ???
Maybe I should post this in Heating & Cooling section.
ECM member.
MANDRA
Old 05-24-2005, 02:18 PM
Flamin65's Avatar
Flamin65 Flamin65 is offline
Troy my brother is running that pump with power steering and the relocation kit is what was needed. I'm pretty sure that was all he needed to do. If you post on outlaw pontiac drag series I'm sure he will reply. Talk to you later Greg
Old 05-24-2005, 04:10 PM
60man's Avatar
Thanks Greg...will do.
ECM member.
MANDRA
Old 05-24-2005, 04:45 PM
Jim Scites's Avatar
Jim Scites Jim Scites is offline
Troy on my 69 Firebird I just relocated the alternator to the passenger side and the power steering belt worked fine. You just have to figure out how to get the alternator wiring over on the other side. If you need any help let me know.
Go Fast... Return... Go Fast Again... Who cares about left turns???
Old 05-26-2005, 10:32 AM
60man's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 69ProBird:
Troy on my 69 Firebird I just relocated the alternator to the passenger side and the power steering belt worked fine. You just have to figure out how to get the alternator wiring over on the other side. If you need any help let me know. </div></BLOCKQUOTE>
Oh well.....I tried mounting the alt. on pass. side head and still have problems. After much work lowering the radiator(Griffin) mount for hose clearance on alt. the belt won't line up on crank pully. It lines up with the PS slot..can't win. PS has to come off--then no problem except steering a 2 ton car..
I used straight water & Water Wetter this time. It took 20-25 minuets to get to 220 but it still did and it's not that hot
Back to my seach for a manual bax.......
ECM member.
MANDRA
