Waiting for my new 455 shortblock. Looks so empty. The 350 is gone....
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
Looks familiar, I'm waiting on my block, crank rods, and my heads. IT'S KILLING ME!!! I'm trying to use the down time to detail my engine compartment/frame and stuff but motivation is down without a powerplant. Did you convert from power brakes? I would like to do that to my T/A.
Thanks for posting the pic,I was wondering which side the taller engine frame mount went on.I have to install the frame mounts in my 70 race car and was not sure,they had a BBC in it before and I did'nt remember which side they came off of the donor car(its frame was cut up like a jigsaw puzzle.I got you beat too,I have two lonely engine bays,but only for a short time.First the lemans/GTO racecar.
And my 72 firebirds.
Yes, I did convert to manual brakes from power. Wilwood Mopar style aluminum MC.
On the brakes, Is that it? Just bolt on the new master? How much? Thanks alot!
I had to modify the mounting flange on the MC, as the Mopar style bolt pattern is slightly more narrow. I just drilled and filed the holes carefully to fit. I had to bend lines for the proportioning valve. I still need to fab a mounting bracket for the valve, but yeah, that's about it. The Wilwood unit was nice because it cam with the pushrod, so I didn't have to make one. I reused the clevis, and moved the pushrod to the upper hole on the pedal arm. I have not been to the track yet, but I'll report. Cost was about $115.00 or so for the MC.
ScreamingChief. The taller mount is on the drivers side on my 66 GTO. Now I am wondering if mine is backwards
The drivers side is the tall one, on all 64-72 Pontiac A bodies.
Darin,
Do you have a part # for the MC? My car has manual brakes, but I am going from drum/drum to 4 wheel disk. |
Well here's a new motor almost ready for a new "home".
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Skip, it looked better with the crossram
Well, I mean it look's GREAT, but that crossram is just killer looking
![]() MY SHOP-MY GATOR MY RULES |
I don't think I can get the Shaker to fit the crossram!
Just about everythings buttoned up to go dyno this thing.
Don't feel bad Darin, It must be a northeast thing!!!!
Brian, the Wilwood # for the kit is 260-4894, and the # for just the MC is 260-4893.
I'm just waiting on the shipping amount from the Dude for my shortblock, then I can proceed! Got the whole fuel system to plumb, the motor has to go together, get mocked up with trans to measure for driveshaft....etc... I've bitten off almost more than I can chew.
I don't feel so bad now. My heads are in the machine shop as we speak. When I ge those back it's 462 Blower motor, Hopefully, if nothing else goes wrong.
Here is the closest to finished I can do.
And another.
what kind of headers are on the lemans 72?
