Old 09-17-2002, 05:57 PM
MoJo's Avatar
MoJo MoJo is offline
#13s, lightly ported
"There's a fatman in the bathtub with the blues"
Lowell George
""Guitar groups are on the way out", "The Beatles have no
future in show business"
Decca Records rejection of The Beatles - 1962
Old 09-17-2002, 06:17 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
72cc E-heads
Old 09-17-2002, 06:43 PM
judgera4's Avatar
judgera4 judgera4 is offline
D-Ports #62 on 70 bird
D-Ports #16 on 67 bird
Round Ports RAIV on The JUDGE #722
1969 GTO Judge RA IV 4 Speed Windward Blue
1967 Firebird 428 auto
1970 Firebird 455 auto
1998 Trans Am WS6
2005 GTO M6
Old 09-17-2002, 08:37 PM
WDCreech's Avatar
WDCreech WDCreech is offline
51cc Wenzler High Ports by Kauffman (345 cfm)
474 cu. in, 2500# race weight '64 GTO.
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 09-17-2002, 10:44 PM
Will Will is offline
#061 D-ports
273 cfm @ .550" @ 28"
170cc port volume
~76 cc chambers
Old 09-17-2002, 11:03 PM
SLOW 77 SLOW 77 is offline
87cc Eheads
10.99 on pump gas
Powered by Pontiac
Old 09-18-2002, 03:33 AM
455T/A 455T/A is offline
6X heads fully ported.
Old 09-18-2002, 04:11 AM
Engo's Avatar
Engo Engo is offline
#62 d-ports. Ported to flow 260/200 cfm.
Performance in a 3800 lbs weight as raced car see below.
Street ยด69 Firebird 455
D-ports and drag radials...
[email protected] (motor only)
[email protected] (+180hpNOS)
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 09-18-2002, 04:58 AM
Half-Inch Stud Half-Inch Stud is online now
#48s ...cc senoir
One set has ports raised & lowered, & pushrod tubes.
other set has ports raised.
Both sets have Ram IV valves, 995 or 997 springs, stock retainers, Exh flange opened to header, bowl work, select sealing surface grinding to provide head gasket locking, and outside surface grinding to pass time while thinking.
otherwise stock. [img]/infopop/emoticons/icon_rolleyes.gif[/img]
H.I. Stud
"11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/472 #48/Flat HYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/472 #48/FlatHYD/Q-Jet/Torker/3650Lbs"
Old 09-18-2002, 05:00 AM
7M5 for the blower.
Screw-in studs added, 6-bolt Exh flange. Combustion chamber smoothed. No port work. 2-piece valves...hummm gonna have to update these bookends...any help?
H.I. Stud
Old 09-18-2002, 05:06 AM
Larry Navarro's Avatar
#16 D-ports, 277cfm int./210 cfm ex. @ .550"
188cc port volume
76cc chambers
http://community.webshots.com/photo/...2367TZCFyTXVCl
http://community.webshots.com/photo/...45901437JUUvUq
Old 09-18-2002, 10:36 AM
Nickv's Avatar
Nickv Nickv is offline
72cc E-heads, 3:23 gears, 406ci, 216 duration cam. 13.5@103 best time in 72 lemans convt with street tires.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
Old 09-18-2002, 06:56 PM
WDCreech's Avatar
Not going to vote yet as I haven't tried the "E" head.
Bill
Bill
Old 09-19-2002, 12:11 AM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
46 d-port on my 3625 lb 74 ventura stock 2bbl cam with 1.65 rockers best et 14.35 @95.47 MPH I also have wenslers(2) on a IA block but its not in a car but expect it will run low 12;s in my 91 GTA [img]/infopop/emoticons/icon_mad.gif[/img]
Old 09-19-2002, 06:50 AM
Mike Davis's Avatar
66 GTO E-heads,421,3.73 gears,3850lbs with driver,mild solid, 11:40's on street tires through muffs,10:40'S on 150hp spray
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 09-19-2002, 09:49 AM
rompn63's Avatar
rompn63 rompn63 is offline
I run 980's on the Redskin. 2.02" intake 1.76" exhaust 3665lbs 9.96 @ 135
Old 09-19-2002, 11:40 AM
Steve C. Steve C. is offline
Edelbrock 6050 castings, 75cc chambers, 324/242 cfm @ .600" (28").
Prior to that #16 D-ports/ 280+ cfm @.600"(28")
( '70 F-body, about 3650 race weight, 450ci sm. journal block- 10.459 @ 129 on the motor)
'Damn right it's a street car'
Old information here:
  #38
Old 09-19-2002, 12:34 PM
Jeff Pimental's Avatar
Jeff Pimental Jeff Pimental is offline
1968 #16 stock 12.3@111mph, 3600lbs. now home port on new project.
  #39
Old 09-19-2002, 03:23 PM
GONZO's Avatar
GONZO GONZO is offline
Round ports on street and occasional strip duty
E-heads on mostly strip duty car
http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com
Come on get off that lawn chair and drive that car like it was meant to be driven.
69' 400 RAIV Judge Conv... 12.86@107 Factory Stock
69' 400 RAIV Trans AM .....12.48@110 Factory Stock
69' 400 RAIV Judge HT..... 13.07@104 Factory Stock
73' 455 SD Trans AM........13's?? not run yet
66' 455 GTO Convert.........12.20@112 non original
63' 421 SD Catalina...........restored fast as h*ll
  #40
Old 09-19-2002, 06:05 PM
David Holmberg's Avatar
E-Heads, Ported by Pontiac Dude...
