Old 08-28-2004, 08:10 AM
GoatRider's Avatar
GoatRider GoatRider is offline
My stupid question of the week...
How the heck can you have .900" lift without getting valve-piston contact?
Are the shape of the combustion chambers so different that the valve seat area is like .300" farther from the deck than on a "normal" Pontiac head?
Thanks to anyone who answers the rookie on this one,
John
"Nothing Beats an Ol' Goat."
  #42
Old 08-28-2004, 08:40 AM
Tom McQueen Tom McQueen is offline
Goatrider, thats an easy one. You make the valve reliefs in the pistons deep enough to allow for that lift (and still have some clearance....080" intake, .100" exhaust minimum).
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
  #43
Old 08-28-2004, 03:06 PM
GTOGEORGE's Avatar
Tom...........Tom............Tom!
  #44
Old 06-17-2005, 09:34 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Any other websites on these heads? I am wanting to build a All Pontiac motor for my Top Sportsman car over the winter to replace my 588BBC. These are probably going to be the heads I will need. I will need around 1000 hp but I will also need something reliable.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
  #45
Old 06-17-2005, 10:17 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by jimmy daniel:
Any other websites on these heads? I am wanting to build a All Pontiac motor for my Top Sportsman car over the winter to replace my 588BBC. These are probably going to be the heads I will need. I will need around 1000 hp but I will also need something reliable. </div></BLOCKQUOTE>
http://www.allpontiac.com/
We are now taking orders for the AllPontiac Tiger Head.
$2,395.00 per set, with valve guides and seats.
Ready for your valves and springs.
Call Monday thru Friday 1:00 p.m. to 5:00 p.m.
EST. to place your order.
  #46
Old 06-17-2005, 10:33 AM
Kelvin Poe's Avatar
Kelvin Poe Kelvin Poe is offline
Butler also has them listed on their web site under new products. They are listed for $2395 bare or $5495 complete, cnc ported with shaft rockers.tiger heads
'70 Trans Am, full tube chassis, 2360 lbs., IAII Aluminum 529ci, CV-1 Heads - N/A - Best 1/8 mile 5.10 @ 133 mph, Best 1/4 mile 8.08 @ 165, Best 60ft. 1.120 - (SOLD)
2009 Norwalk KRE Quick 16 Winner!!!
'61 Tempest wagon 2Dr, '05 GTO LS2 powered, 12.39 @ 109 mph at Drag week 2015 - https://www.youtube.com/watch?v=jsVRzMXERtA
'64 Grand Prix, Pump gas, 529ci., CV-1 Heads, Holley Dominator EFI. - Single turbo in progress..
'70 Trans Am, Ram Air III 400 - 4 speed.
  #47
Old 06-17-2005, 10:59 AM
slowbird's Avatar
slowbird slowbird is offline
Is anyone running them yet besides AllPontiac? Does anyone know anyone that order them and has recieved them?
  #48
Old 06-18-2005, 09:03 AM
Mr_GTO I just sent you an email
  #49
Old 06-19-2005, 05:34 AM
Mr_GTO's Avatar
Mr_GTO I just sent you an email </div></BLOCKQUOTE>
Why? All i did was do a google seach on it and posted the info I found.
  #50
Old 06-21-2005, 07:18 AM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Will these need "custom" rocker shafts? It doesnt sound as if they are supplying rocker shafts.
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
  #51
Old 06-21-2005, 08:39 AM
rumair rumair is offline
i think T&D and Jesel will be making shafts for the tiger head. i'm sure bob and frank would be happy to talk about specifics with anybody who is interested.
as far as i know bob is the only person who is running the heads right now. they picked his car up a little at VMP, but i would expect to see significant gains when he goes back to the victor intake. they had the new BOP intake on the car at VMP and it was probably costing them some power.
  #52
Old 06-21-2005, 09:12 AM
Brian Baker's Avatar
Regarding the BOP intake...it's not a junk intake. when placed on Bruce Maichle's engine (which makes more power and turns more RPM than Bob's), it picked up over Bruce's "mega-modified" Victor. When these heads were dyno tested back in February, Bruce's Victor was placed on the engine, and it didn't make any more power than with Bob's basically stock Victor. It made the same peak, but the average was off a little bit. However, we could see that at 7000-7200 rpm (where the dyno test was stopped) that the intake was just starting to "stretch its legs". Even though Bob had the 400-cfm heads, because of the cam, it wasn't meant to make serious power above 7000 rpm. Bruce's intake wasn't choking it, it was just not getting the velocity up leading into the port like it does on his engine at 8000+ rpm. And the BOP intake worked better for him than his modified Victor! So it looks like the BOP intake will be best suited for those that an unmodified Victor will not work. Spend the "megabucks" porting the Victor, or buy the BOP and bolt it on. Would like to someone like Keefer or Vaught test a Victor and a BOP back-to-back under pressure.
  #53
Old 06-21-2005, 09:15 AM
brian- my post was not meant to cast the BOP intake in a negative light, merely to point out that it might be too much for bob's current combination. i also heard some discussion suggesting that more converter and gear will also be necessary to make power further up in the rpm range with the tiger heads.
  #54
Old 06-21-2005, 10:11 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rumair:
as far as i know bob is the only person who is running the heads right now. they picked his car up a little at VMP, but i would expect to see significant gains when he goes back to the victor intake. they had the new BOP intake on the car at VMP and it was probably costing them some power. </div></BLOCKQUOTE>
With all due respect there is nothing to suggest that this is the case. As a matter of fact there is evidence to suggest just the opposite. We know the BOP intake picked up 35 HP over the Victor on Bob's motor in a back to back test on the same dyno. This combined with the Bruce M. data would give no indication that the intake is not suited for Bob's application. In fact it was designed for just such an application. Other comparisons of HP due to components on this engine came from different dynos on different days. The bottom line is the car did not ET as expected, however the most credible data suggests that the intake is the least suspect of all the components. I was at VMP and would have loved to see them go back to the Victor for a pass. I am confident the results would have shown the BOP intake superior. With that said more testing is currently underway and will be released as soon as it is available.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
  #55
Old 06-21-2005, 10:32 AM
wade- i guess a good question would be what is the minimum peak (.700+ lift) cylinder head flow recommended for use with the BOP intake? is this the focus of the current testing? i would also have been curious to see the results of a back to back test of the victor vs. your intake at VMP.
  #56
Old 06-21-2005, 11:32 AM
The next testing will be on E-heads. It is our opinion from a design point of view that our intake will have a positive effect when the .600 lift mark is reached providing other aspects of the combination are optimised accordingly. Thanks for the input
Wade Congdon
BOP Engineering
