Another mystery part, at least for me. This is hanging off the radiator core in front of the radiator. The line looks like it connects back to the transmission.
It's a 69 Firebird non-air automatic..... Thanks, John 1969 Firebird resto...doing my part to keep PY profitable....
69 Firebird/TA clone |
Aftermarket tranny cooler.
Let's go racing! www.outlawpontiacs.com/members/B-Man2.php www.outlawpontiacs.com/members/B-Man.php
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
I'm going to demonstrate my utter ignorance here...have mercy....
I'm guessing tranny coolers are only for an automatic transmission?? My project car had/will have a manual transmission and the one pictured is an automatic. I'm transplanting the 350 but not taking the tranny. In that case, the cooler wouldn't be needed, right? Thanks, John 1969 Firebird resto...doing my part to keep PY profitable....
Thats right, you will not need the aftermarket cooler for a standard transmission car.
1969 Pontiac Firebird Convertible |
Yep! Aftermarket tranny oil cooler. With a manual transmission, the heat generated by the coupling the drivetrain (dumping the clutch) is transfered from the clutch friction disks and flywheel to the surrounding air via convection.
With an automatic transmission, there is no solid mechanical link between the engines crank shaft and the drive shaft. Torque is transmitted thru the torque convertor via the transmission oil itself. I know it sound wierd but the transmission fluid is directed by a stator and constantly sheared between impellor and turbine wheels in the convertor. The impellor blade (connected to the flexplate) rotates at engine speed and forces the transmission fluid thru several directional vanes. These directional vanes dischare the tranny fluid onto the leading edge of the turbine blades. The inertia and shearing forces of the discharged fluid turn the turbine blade and the rest of the transmission. This constant shearing produces heat which must be dissipated. Therefore, a transmission oil cooler must be used to prevent overheating.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Good info!
It'll be going in the trash when I move the motor! Thanks a bunch, John 1969 Firebird resto...doing my part to keep PY profitable....
Yipes! And I thought I had a lot of work ahead of me on the CBird! You have inspired me to get out there with that shot, sir! Thank you!
1968 P/S coupe 1968 convertible
1968 Firebird convertible 1968 Firebird Pro-Street coupe 1984 Mazda RX-7 GS...sidelined DC Solar yellow, 'bout to go 2+2... 1983 Mazda RX-7 GS...8100 rpm corner carver, 2300 lbs, 'new' DD |
Mar3,
If you only knew....that's nothing! But, I've been at it over a year now and I haven't found anything yet I can't tackle without some planning, some $$, and the right tools. John 1969 Firebird resto...doing my part to keep PY profitable....
