Old 07-22-2002, 05:20 PM
drewhelm1974 drewhelm1974 is offline
I was wondering if I could get a Guesstimate on a combo I am building. Here's what I have....
74 455 bored .030 over
standard crank
Lunati Bracket master II cam - 292/230 .490 110sep
Performer intake
1 5/8 headers
holley 750 vac sec
HEI ignition
compression ratio between 9.5:1 and 10:1
I haven't decided on the 6X-4, 96, 66, 5C or 15 heads, suggestions?
Any help would be greatly appreciated!
69 Firebird, .060 over 455, UD solid roller 254/262 @ .050, Scorpion rockers, home ported 6X-4 heads, Holley 850 DP (bone stock), Holley SD intake, with Summit 3 inch x-pipe and goerlich Xlerator mufflers. 12.27 @ 115mph.
02 Midnight Blue LS1 Ram Air Trans Am WS6 (440 rwhp)
http://firstgenfirebird.org/show/closeup.mv?CarID=642
standard crank
Performer intake
1 5/8 headers
holley 750 vac sec
HEI ignition
Old 07-22-2002, 07:38 PM
shovelrog shovelrog is offline
have you played with the simulated engine dyno at www.pontiacwarriors.com
smokem if you got em
Old 07-22-2002, 08:01 PM
For most people, about 460HP, but for you about 560HP if you use the 5C heads.
Nice Lunati cam.
Old 07-23-2002, 11:13 AM
Huh? Does that mean I get the extra 100 horses from the stickers? hehehe
5C heads, huh? I need to find some....
Old 07-23-2002, 11:15 AM
That web page is unavailable.
Old 07-23-2002, 03:39 PM
Mr-Bratt's Avatar
Mr-Bratt Mr-Bratt is offline
<font size="2" face="Verdana, Helvetica, sans-serif">Same thing I have been getting there all week I wanted to see the difference between the Nunzi 2041 cam I am using now and his 2042, oh well I guess I must wait, was thinking of doing a quick switch before norwalk, But since I have not ran the car I could get a better idea of the change if I run it first with this one, Jim
Old 07-23-2002, 05:59 PM
PROBRD PROBRD is offline
I ran it through a program I have and guessed at a few things but came up withabout 450 hp gross and 340 net hp. Should run around 12.90 in a 3500lb. car.
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
Old 07-24-2002, 07:04 AM
Roy Zink Roy Zink is offline
How about a 455...60 over....#64 heads.....performer intake with Rochester quadrajet.....RA IV cam....dual point ignition....hedman hedders???? Horsepower??? Somebody told me that with those heads I'm up near 11:1 compression...any truth??
Thanks Roy
Old 07-24-2002, 09:41 AM
Thanks Roy
Not sure on horsepower, but depending on what else you've done to the block and heads the CR shouldn't be that high. If they are 87cc heads, .060 overbore, standard stroke, standard 6.7 cc dish piston, deck height is .020, gasket thickness of .039, CR would be 9.97:1. If the heads or deck have been milled the CR can go up quickly.
Old 07-29-2002, 11:05 AM
Minor changes....
It is a 71 block, standard bore and crank. Does that change the numbers much? It will be run through a 2.5 inch Flowmaster exhaust.
Thanks!
Drew
