Old 04-04-2003, 09:08 AM
pontiac1966-1 pontiac1966-1 is offline
i have had alot of trouble with my 1966 pontiac starchief executive. when ever it rains or is damp, it seems like all the juice from my battery is drained and the car wont turn over. i have checked all of the grounds, i have replaced both battery cables, i have checked alternator, battery is new. every thing has checked out ok. any ideas to solve my problems would help.
every day is a good day to work on a pontiac
Old 04-04-2003, 11:49 AM
Make sure the connection to the starter is clean and tight.
Also that the block to starter is clean and tight.
There is a connection or union in the wiring harness just behind the alternator wiring,make sure it's ok and not corroded or broke.There's a fusible link in there too.Check it.
johnta1
Old 04-05-2003, 07:45 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
Just because the battery is new dos'nt mean its o.k.
I run into this all the time. (I mean with new parts).
There is a leak. However at 12 volts theres not much potential for arching in damp conditions.
I would start with the battery.
Did it do this with the old battery?
Is there any one part you replaced before this started happening?
Good Luck
Old 04-05-2003, 10:02 PM
TIAUTOMAN TIAUTOMAN is offline
GROUNDS GROUNDS GROUNDS GROUDS
Old 04-06-2003, 08:40 AM
sviguy sviguy is offline
only when wet? cracked cap?
can you hear me now? is this thing on? test 1 2 1 2
Old 04-06-2003, 12:35 PM
aac1431 aac1431 is offline
Funny thing, I just had the same exact problem with my 98 Ram. Only when it was wet or damp outside it would not start. Battery cranked fine, etc, etc. I finally did a tune up on it and the the plugs were way out of gap and also the distributor rotor/contacts were corroded. Been running like a champ since then. So that is the place I would start.
1969 GTO convertible, starting it soon..............
Where have all the good ones gone?
Old 04-06-2003, 04:07 PM
In his question he said it has 'NO' power. I took that as meaning no cranking,lights etc.
Cap,ignition wires won't affect this.
But,if he does have cranking power,then I would look into those things.
johnta1
Old 04-06-2003, 06:13 PM
their is still power, the headlights still work but their isnt enough power to crank the engine. i have checked every thing over and over. it is an unsolved mystery
Old 04-06-2003, 06:27 PM
Try a good starter or solenoid.
Also did you check the joint where the wires connect in the wiring loom?
johnta1
Old 04-06-2003, 06:28 PM
that is the only place where i havent looked
