Old 12-04-2004, 09:23 AM
tremo's Avatar
tremo tremo is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Bill93711:
They might look OK where you are only covering the top of the dash. They look like crap on a 69. <HR></BLOCKQUOTE>
Good advice Bill. I'm looking for a '69 and was wondering about dash caps vs. a refinished dash from Just Dashes.
From what I recall from my first '69 LeMans, it would be hard to get a good glue job around the gauges and AC vent. It's a shame they don't just make a top dash cover as this is the main area that cracks.
Hmmm...I see a business opportunity here!
Seee-ya,
Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor
* Engine alive and kickin' March 2nd, '06
* RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers
* QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi
* Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+'
Old 12-08-2004, 08:02 AM
gto_guy gto_guy is offline
Granted mine`s a 68 and not a 69 but it still goes around the center ac vent and side ac vents.I`m a perfectionist myself and I`m telling you that a good quality dashcap is hard to tell from an original accept for being hard plastic instead of soft.I would do it again before I spent $500.00 for one from Just Dashes.Here`s some pics of my so-called crappy looking one.
www.cardomain.com/id/gto_guy
Everyone should believe in something,I believe I`ll have another drink.
Old 12-08-2004, 11:42 AM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
I will get you guys a pic of my "crappy one" too. I will be installing one on my 69 GTO Conv next (no A/C). The extra 500.00 will go elsewhere! Nice 68 BTW
Old 10-26-2005, 01:16 PM
gr8dain's Avatar
gr8dain gr8dain is offline
I got my cover from PY last year and I am just now getting to the point of installing it. I figured that it was a driver and not a show car, so I thought I would give it a try. If it turns out crappy, then we will have to see what's next. I see where I am really going to have to apply pressure while the sealant is drying, but I have heard that I should not use the tube of glue that came with it.
Anyone else use a different glue than was supplied? If so, what was used.
I will hopefully have good pics when I am done. As a side note, I am changing the interior color from green to black. The dash cover did not match the color of the "dye" I got for the glovebox door etc., so I am painting the cover as well to match. I hope that it is not too glossy and glare prone.
Dain
Dain
69 GTO Hardtop 4spd 400cid
mid-resto
Old 10-26-2005, 04:36 PM
TJH TJH is offline
Bill- You'll have to tell us how you like the Just Dashes restoration. I had a 1970 dash done by them several years ago, and to be honest, it wasn't what I expected. The radii on some of the edges seemed to have become more washed out than on the originals, and there were other small details that I immediately picked out.
After going both routes, my thought is that a PROPERLY and CAREFULLY instaled dash cap is every bit equivalent to the work done by Just Dashes. They both have their issues, and I really can't say that one's quality is noticably different than the other.
And, when you're saving $600-plus, that can buy a lot of "understanding" when it comes to minor details. This is particularly true when those same areas exhibit different, but equally annoying, issues on the high-dollar restoration from Just Dashes.
Old 10-29-2005, 11:59 AM
Guy Mazza's Avatar
gr8dain, Just get a bunch of old phone books, or any other soft bound heavy, large book, and pile them on top , nice & even, snug. Let the silicone/glue cure overnight (or longer is possible) before removing books.
Old 10-29-2005, 01:03 PM
69 projects 69 projects is offline
All this talk about caps has caught my interest. I have a core and my car came with a new cap uninstalled in the box. I think I'll put them together and see how it works - there's lots of good info here. My thought on it is that if the cap is tight you can easily file or cut away some of the core to ensure a good fit. Just don't get carried away
Old 11-01-2005, 02:30 PM
UPC-WU2's Avatar
UPC-WU2 UPC-WU2 is offline
I put one on my '71 GT-37 driver.
Old 11-06-2005, 11:02 AM
63pig 63pig is offline
I have had a "Nu dash" cap on my 69 GTO for the past three years, and I have had no problems. As a matter of fact, you have to look real hard to see that it's a cap, because I took my time when I installed it. I drive my car...it's not a Trailer Queen...if it was a Trailer Queen, then I'd spend the $700 bucks to send it to Just Dashes.
Throw away that clear sealant glue that comes with the cap, and get some 3M seal adhesive (I used the yellow stuff)...make sure you have resored all of your bezels first, and you may have to do a little trimming around the glove box door to get a proper fit.
Apply a bead of the sealer about 1/4 inch away from edges so that the sealant will reach the edges, but not spurt out all over the place, lest you have a great mess to clean up.
The advantage of a dash cap is you don't get those nasty finger impressions in your padded dash from frightened passengers when you are doing 130 MPH on the highway...but then again...Trailer Queens can't see the highway from under the covers...
Perhaps in 10 years I'll spring for the restored dash when I'm tired of driving the old girl...if that ever happens.
Old 11-13-2005, 02:02 PM
Bill93711 Bill93711 is offline
Default Are you Happy?
As previously stated I'm not a fan of the phoney dash caps for a 69 ,especially one with Air. Just wondering--Are you happy with it or do you wish that you did it right to start with??
Old 11-13-2005, 05:11 PM
Ron Landis's Avatar
Cool JMHO...
I've seen the '70s and the '69s. The '70 piece was more convincing, but still noticable. The '69 I refused to use. Again, considering dollar amount, I can see where there would be cases where the cap is "good enough", but definately a situation where you truly get what you pay for. 'Nuff said. I'll see if I can locate my '69 piece, and if someone would like to pay shipping, you are welcome to try it. If you like it, just send me the balance, which would be a fraction of original cost. Fair enough? Ron
Old 11-16-2005, 12:16 PM
68addict 68addict is offline
Default not to hijack but how about 68s?
Quick question, as I saw a 68 posted here...By dash caps, are you guys refering to the Repro Pads sold by Ames for example? Mine is Non-ac...and for a driver, I do not see buying a used one for up to 500 as I have seen advertised....
Thank you.
Old 11-18-2005, 08:40 PM
THEGTOCHISM's Avatar
THEGTOCHISM THEGTOCHISM is offline
Pontiac die hards may notice, but 90% of the rest of the world won't. I put one on my 69 and it looked great. spent the other $500.00 they wanted for the dash restoration on other parts i needed. Also i didn't like the down time until i got the restored dash back. I sanded the cracks on my old dash to remove the hi spots and filled it with the same repair stuff i used on the endura nose. then cleaned and installed. I thought it looked decent for a driver .
Old 11-20-2005, 01:51 AM
DanC's Avatar
DanC DanC is offline
If yours is non-air and has side vents I'll gladly take you up on that offer!!! And will send you a prepaid FedEx shipping label, talk about easy!
DanC
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
