Old 01-11-2006, 11:50 PM
69redbird 69redbird is offline
Default Disk Brake Question
Hey,
I have a question about disk brakes, I have drum brakes all the way around my 68 bird, and i want to run disc brakes all the way around. My question is can I use disk brakes without using the brake booster? I dont have one now just a master cylinder. I dont want the extra weight up front. Thanks
Old 01-12-2006, 02:30 AM
screamingchief's Avatar
Sure you can use manual disc brakes,just be sure to use a propely sized master cylinder for your brake setup.
Also need to use the manual brake location on the pedal lever,still no biggie though...
My '72 firebird is a factory manual disc/drum brake car,so even GM did that on occasion.
Old 01-12-2006, 03:06 AM
rfb92345's Avatar
rfb92345 rfb92345 is offline
Send a message via Yahoo to rfb92345
We run manual 4 wheel brakes on my son's '69 f'bird.
Old 01-12-2006, 12:18 PM
Thanks,
Were can I look for the correct master cylinder? Is there a website?
Old 01-12-2006, 01:32 PM
rfb92345's Avatar
I will check with him and see just exactly waht master he is running.
Old 01-12-2006, 02:54 PM
Rob B's Avatar
Rob B Rob B is offline
I switched from manual front drum to manual disks on my car years ago (OEM setup, not aftermarket stuff) and used the same master cylinder and proportioning valve from the drum brakes. Had no problems or anything goofy happen just as long as you have a dual master cylinder. I've done it this way and many people I know have done the same on all different years X and F bodies. Switched out spindles, brake set-up, and brake hoses and away we went.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 01-12-2006, 02:59 PM
Rob,
Do you have to switch out the spindles, and does a dual master cylinder have both front and rear compartments? How would i know if i do have a dual? Thanks Again
Old 01-12-2006, 04:12 PM
RAIV55 RAIV55 is offline
I was thinking that drum brakes utilized residual check valves in the master cylinders and these had to be removed when switching to disc brakes.
Old 01-12-2006, 04:16 PM
Rob B's Avatar
Originally Posted by 69redbird
Rob,
You'll have to switch spindles, you might have fun trying to find original OEM spindles. Yes on the master cylinder, yours is a dual, just take the lid off and you'll see 2 reservoirs.
Old 01-12-2006, 05:15 PM
Rob,
Most kits I see include the spindles, so I guess those will work? Just have to tell them my year and make of car? Thanks
