Old 07-11-2006, 12:27 PM
Aaron75's Avatar
Aaron75 Aaron75 is offline
Default chasis ground
Could anybody send me or post shots of where the chasis ground is connected to the engine block or the battery?
I recently had my engine compartment wires replaced and ever since the gagues haven't been grounded properly. I'm thinking there's probably supposed to be some wire that grounds the engine and chasis as the ground for the battery is only connected to the block.
Thanks for the help.
Aaron
Old 07-11-2006, 06:20 PM
70KGOLD's Avatar
70KGOLD 70KGOLD is offline
What car do you want?
Old 07-11-2006, 06:40 PM
Aaron75's Avatar
Default gack!!
sheesh i'm not all that swift today am I.
Sorry, its a '70 gto (455) but i'm sure that part doesn't matter.
Thanks.
Aaron
Old 07-11-2006, 08:11 PM
70KGOLD's Avatar
Yes it matters. On my 1970 GTO The ground from the battery goes to a head bolt. Then I have a ground connected to the rear of the engine (on the head) to the (Firewall) its a flat copper strap. You can never have enough ground.
Old 07-11-2006, 10:00 PM
gtoformula's Avatar
gtoformula gtoformula is offline
I have a 1970 GTO hardtop with a 400, auto trans. There is also a ground strap that runs from the front passenger side frame rail (a bit back from the radiator) to the passenger side inner fender.
Old 07-12-2006, 12:28 PM
Aaron75's Avatar
Default Thanks guys
I agree, one can never have enough ground, especially when my guages like to blink w/ my turn signal. Nice!!
How are the copper straps attached? I am at a loss here as I've no experience w/ how things were done back in the day and I had someone else pull my engine. This means i couldn't 'put things back the way they were'.
It would be great if i could get a shot or two. If you don't have a place to post it, i'd be super greatful if you could forward it to my email.
Thanks again guys.
Aaron
Old 07-13-2006, 08:58 PM
Bob70Goat's Avatar
Bob70Goat Bob70Goat is offline
sounds like there maybe a bad round on the printed circuit board for the gauges
"One ought never to turn one's back on a threatened danger and
try to run away from it. If you do that, you will double the danger.
But if you meet it promptly and without flinching, you will reduce the danger by half."
- Winston Churchill
Old 07-19-2006, 05:42 PM
Aaron75's Avatar
Default ok, no pix
can i get a bit more description regarding the correct location?
I've got this image... http://ultimategto.com/1970/70_00083_11.jpg showing the ground at the fire wall. When you say connecting to the head, do you mean the support for spark plug wires? Is there another location where it should be?
I see a whole on the front passanger side frame rail, but i cannot find a whole on the inner fender would it be up around the washer fluid container?
Thanks guys.
Aaron
Old 07-19-2006, 06:08 PM
That pic has the ground wire attached to one of the accessory holes on the back of the head.
Old 07-19-2006, 06:39 PM
Aaron75's Avatar
Default hmm
that seems to be a reoccuring theme amongst some of the '70 engine compartments that i've been looking at. This isn't the correct location?
i've noticed a bunch of early goat owners seem to think it should go on the driver's side, not the passengers.
Aaron
Old 07-20-2006, 08:49 PM
Held for Ransom's Avatar
Per the GTO assembly manual...
And, one of my cars (firewall is stripped, but it was attached to the lower hole but I believe it should have been the circled hole) I will look for the strap and see if I can get another picture of the mounting.
ID:	59538   Click image for larger version
ID:	59539   Click image for larger version
Old 07-23-2006, 10:57 PM
Aaron75, was your GTO built in Fremont (Z in the VIN)? Sometime in Feb. or Mar. it looks like the Fremont plant changed the location of the strap on the firewall (may have been earlier at other plants), to under the voltage regulator. I've also included pictures of the mounting location on the head, the components used and, at some point, they added an extra ground to the wiring harness.
ID:	59868   Click image for larger version
ID:	59869   Click image for larger version
ID:	59870   Click image for larger version
Old 07-24-2006, 10:59 AM
Aaron75's Avatar
Default yes it was
thanks so much!! It was made in fremont. These shots are perfect. Looks like i stuck it in the wrong spot but i'll definatel make the change.
Is this the only strap, or do i have to worry about the frame to passenger inner fender (can't find those holes either).
Aaron
Old 07-24-2006, 05:43 PM
I'm not going to say some plants didn't install them, but I've never seen them there. And the assembly manual doesn't mention it either. Do I have your trim tag info entered into my database? PM me, please.
Old 07-24-2006, 06:48 PM
Aaron75's Avatar
Default you don't have the info...
PM you?
where would i find the trim tag info?
Aaron
Old 07-24-2006, 06:56 PM
Aaron75's Avatar
Default nevermind
about the pm i figured that out. Where do i get the trim tag info?
Aaron
Old 07-24-2006, 10:52 PM
The trim tag (or body tag) is a stamped metal plate and is located under the hood, near the master cylinder. Format will look like...
ST 70-24237 BF 0123 BDY
TR 258 B80 10 10 PNT
08C 012345 678910
Again, private message me.
Old 09-07-2006, 09:15 PM
Update, forgot to add the other added wiring harness ground wire pictures.
ID:	64535   Click image for larger version
Old 09-03-2010, 09:21 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
PERFECT!!!! thats the ground I'm missing.
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
