Old 08-15-2006, 10:27 PM
Geeto Tiger's Avatar
Geeto Tiger Geeto Tiger is offline
Default Pictures of your 61-63 Lemans/Tempest
I love to see these car/wagons, can you post your pictures of them?
I'm the Dude. So that's what you call me. That or His Dudeness... Duder... or El Duderino, if, you know, you're not into the whole brevity thing...
Old 08-16-2006, 10:28 AM
White Warrior White Warrior is offline
Here are pix of my Race car and my LeMans Convertible.
ID:	62258   Click image for larger version
Old 08-16-2006, 10:42 AM
tom s tom s is offline
my wagon
Old 08-16-2006, 11:02 AM
jusjay's Avatar
jusjay jusjay is offline
Heres mine, 1962 conv. I have had this car for 15 years now and drive it almost daily. I live about 30 miles south east of Tom S. and I have had the good luck to have seen most of Toms toys.
ID:	62264   Click image for larger version
ID:	62265   Click image for larger version
Old 08-16-2006, 01:12 PM
FT LB's Avatar
FT LB FT LB is offline
Here's my work in progress...
Old 08-16-2006, 01:48 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Tim, looks great!
Pat
Old 08-16-2006, 03:30 PM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
My two 4-4-4's
Old 08-16-2006, 10:13 PM
R 70 Judge's Avatar
'63 Le Mans 326 Auto - Currently in the chassis shop getting a mild makeover.
ID:	62321   Click image for larger version
ID:	62322   Click image for larger version
ID:	62323   Click image for larger version
James
1970 Trans Am
Old 08-16-2006, 10:59 PM
My '63 that I can't seem to get my arms around - was supposed to be ready for Norwalk, NOT.
Shooting for Sept. 10th at the Grove.
ID:	62334   Click image for larger version
ID:	62335   Click image for larger version
Old 08-16-2006, 11:55 PM
jusjay's Avatar
Where are all the 61-62?
ID:	62338   Click image for larger version
Old 08-17-2006, 12:49 AM
wolfs63's Avatar
wolfs63 wolfs63 is offline
Default wolf's 63
63 lemans 455 pic from norwalk
Name:	Untitled 1_1.tiff.jpg
Old 08-17-2006, 06:47 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
This is the only one I have pictures of... go figure.
ID:	62397   Click image for larger version
Old 08-18-2006, 02:42 PM
Hey 63Banshee, that one looks a lot like my first Tempest. This is a picture of it circa 1966. (I had it with me when I lived in Texas in '69)
Old 08-18-2006, 05:31 PM
63Banshee's Avatar
Coo
Old 08-21-2006, 09:52 PM
tiacguy's Avatar
tiacguy tiacguy is offline
Heres a pic of my 61 with 62 rear trim LOL.
Apache Warrior, do you have mounts under the block also? Or are the ones in the front it?
ID:	62768   Click image for larger version
Old 08-21-2006, 10:36 PM
R 70 Judge's Avatar
What does your car run in the 1/4?
James
1970 Trans Am
Old 08-21-2006, 10:46 PM
tiacguy - I had motor mounts fabbed for down below also.....stock location.
Also have a really nice fabbed trans crossmember for my Jerico DR4!
Old 08-22-2006, 10:49 AM
tiacguy's Avatar
R70Judge, I have three engines for the car. With the 474 its run as fast as 9:72 @ 138.00 on motor.I currently have a 462 in it that was built for N2o and its run 10:13 @ 134.00 on motor. ( what a pig ) I didnt shoot it yet. Im also in the process of building an IA-2 that will go in next season. Im currntly deciding on which way to go with this motor as far as combination. Ill need to buy better cylinder heads for it also as my Edelbrocks wont fit the bill. This car is a complete street legal car not a stripped out shell type race car.
Apache Warrior, Id like to share some info on your engine install. Youd be better off mounting the front of the engine with a full one piece motor plate accross the front of the engine either behind the timing cover or water pump. And the use of a mid plate between the engine and trans. Your looking for trouble mounting to the cylinder heads. You dont want to be putting undo stress on the head bolts. Your head gaskets will fail. Dont use solid motor mounts or it will crack and fail the #2 main. Please veiw this as constructive criticism Im trying to help. Scott.
Old 08-22-2006, 11:10 AM
Thanks - I do not have solid mounts and the cylinder heads are studded.
The individual engine plates should be fine - the gentelman who fabbed them has them on many other customers cars with success.
Old 08-22-2006, 11:36 AM
tiacguy's Avatar
Ok, Than Ill wish you luck with your project.
