Old 06-16-2007, 01:43 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default My New Wenzler II's
I finally talked my wife into opening up and take pictures of my new Wenzler II heads. When she gets back from Denver, I'll try to get her to take some pictures of the combustion chambers and exhaust ports.
I know these are not mainstream heads anymore. If my T/A goes 100% race car, I'll use them on a 1970 4-bolt 455 block I have.
I imagine many people here have never seen a set. They have 80cc chambers and Comp 895 springs and RAIV round port exhaust.
I'm trying to find a set of rocker shafts if anybody has a set laying around.
ID:	94746   Click image for larger version
ID:	94747   Click image for larger version
ID:	94748   Click image for larger version
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 06-16-2007, 02:41 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Thumbs up
Sweet set of heads!What are the "as is" flow numbers.
Old 06-16-2007, 02:53 PM
Johnny406's Avatar
Thanks!! They should flow 288CFM @ 28" and .600 lift. Looks like they need a little cleaning in the intake passages. They are probably a bit overkill for what I'll use them for, but...
Old 06-16-2007, 03:36 PM
Stock Edelbrocks will go over 280 at 28" right out of the box with a extremely minor clean-up. No real porting.
At one time Larry's stuff was the only game in town and I give Larry credit for bringing out his heads but there are far better and cheaper heads today for the same flow numbers.
Old 06-16-2007, 04:34 PM
R 70 Judge's Avatar
My old stock Wenzlers --
Intake
.100 68
.200 135
.300 184.3
.400 225.2
.500 265.4
.600 286.1
Exhaust
.100 66
.200 119
.300 155
.400 185
.500 192
.600 195
Just for reference...My new highport heads flow 295cfm @ .400 lift.
If you have the right guy port the Wenzlers, they can go 370cfm at .700 lift. Jim Robertson (link in my signature) does very nice work with Wenzler heads.
James
1970 Trans Am
Old 06-17-2007, 06:51 AM
Johnny406's Avatar
I got a really good deal on these. I'm hoping someone on this planet has an extra set of rocker shafts they would sell. New ones are expensive.
We'll see what I do with my car. I'm running 30 spline axles in a 8.5 10-bolt. My tranny is a well built but still a TH350. I'm going to enjoy this 400 for a bit and collect parts for down the road...
Old 06-22-2007, 02:50 AM
Johnny406's Avatar
Default New Pictures
A few more pictures
Still looking for rocker shafts
ID:	95335   Click image for larger version
ID:	95336   Click image for larger version
ID:	95337   Click image for larger version
Old 06-22-2007, 06:45 AM
PONTIAC DUDE's Avatar
Thumbs up FWIW:
We are a T & D dealer.
We do lay-a-way.
Old 06-22-2007, 08:51 AM
Geoff Geoff is offline
Johnny,
Looking at the pic of the chamber, the spark plug hole looks like it is only about 1/8" away from the deck surface. Or is it an optical illusion/angle of the pic?
Old 06-22-2007, 09:54 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Originally Posted by Johnny406
I finally talked my wife into opening up and take pictures of my new Wenzler II heads .
Sounds like an opening line to a story in Penthouse Forum
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 06-22-2007, 10:03 AM
Johnny406's Avatar
Old 06-22-2007, 10:26 AM
Department X Department X is offline
They look pretty good to me, I like the different stuff.
Old 06-25-2007, 06:44 PM
tempest455's Avatar
tempest455 tempest455 is offline
I always wondered how his wife kept the aluminum shavings out of the laundry???
Tempest455
Old 06-25-2007, 10:42 PM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
I WOULD GET LARRY AT BRANDWINE TO PUT IN STEPPED WASHERS WHERE THE HEAD STUDS GO...THE HEADS ARE SOFT AND TEND TO CRUSH,AND THEY ALL CRACK IN THE CENTER EXH PORT, NEAR THE BOLT HOLE.
