Old 08-05-2007, 11:58 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
It's fine to run the nitrous off the line if you can hook it. Also, when you do not have a purge kit installed, there will be a slight delay before the "Shot" kicks in. I recommend a WOT switch, they work and they are cheap. Finally, if you don't have a bottle heater or way to raise the pressure in the bottle you'll only get a full nitrous pass 1-2 from a full bottle. UNLESS it's super hot out side and mother nature is heating for you! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
