Old 08-24-2007, 01:12 AM
Sammy B's Avatar
Sammy B Sammy B is offline
Default Need help finding a part - Firewall Grommet
Anyone know where I can find one of those grommets that goes in the firewall (next to the heater case. It's the one that has the vacume lines and heater harness going though it. I've tried Year One, Ames, and our host with no luck. I'd love to re-use the one I've got, but I've torn it into about a hundred pieces.
Sammy
1967 Lemans: 455 swap in progress (stock crank, stock rods, TRW slugs, mildly ported 6x heads, Stump Puller hyd roller, 1.5 PRW aluminum rollers, Comp hyd roller lifters, Performer RPM, q-jet, RA exhaust manifolds, 2 1/2" exhaust, ebay HEI), 200 4R, and some suspension stuff
Old 08-24-2007, 10:04 AM
jeffhhs76's Avatar
jeffhhs76 jeffhhs76 is offline
Ames performance definitely has them. Our host may have them as well
Jeff
Old 08-24-2007, 03:35 PM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
Saw them on Ebay, can check there too.
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
Old 08-24-2007, 09:18 PM
boltbuster's Avatar
boltbuster boltbuster is offline
Question
Sammy...
How many holes were there in your original grommet? If there were only three, I think that I can help you out. My 67 goat with factory a/c has a four-hole grommet, and I never found any source for one of those.
Kerm
Old 08-24-2007, 11:56 PM
Sammy B's Avatar
I'm not with the car right, but I'm 99% sure that there were three vacume line holes and one for the heater/ac harness. The ones on ebay and at Ames only had one hole, so if nothing else, I could just buy whatever Ames or PY sells and drill holes. If I knew that they didn't make them any more, then I would have been more careful removing my old one. I just figured that it was a commonly available part.
Sammy
Old 08-28-2007, 10:35 AM
Bob Kazian Bob Kazian is offline
I believe you are looking for the grommet that mounts to the blower motor housing under the hood of AC cars. It is not currently reproduced.
I gave a mint one to Steve Ames a few years ago to see if he could get it reproduced. There was some problem with the design of the four holes that prevented him from doing it.
It is a round grommet with four holes. Three are for the vacuum lines and one for a wire harness.
Best bet is to find a good used one. Maybe someday it will be reproduced.
Bob Kazian
Taylors, SC
[email protected]
Old 08-28-2007, 11:16 AM
Sammy B's Avatar
Yep, that's the one. Sorry to hear that they're not being made at this time. If nothing else, I'll just make my own somehow. I really trashed the old one.
I put a post in the 'wanted' section, but if anyone is reading this here and wants to help a brother out, shoot me an email: sammy[at]inexair.com
Thanks,
Sammy
Old 08-30-2007, 07:59 PM
Andre's Avatar
Andre Andre is offline
I think I got one for you. Give me till the weekend
Old 08-31-2007, 10:13 AM
Sammy B's Avatar
Thanks Andre! Let me know how much you want for shipping and the part, or... I just took off an almost brand new set of KYB Gas Adjust shocks off the front of my car. If you want them, they're yours.
Sammy
Old 10-09-2007, 11:37 AM
Tony_D Tony_D is offline
Bob - have you approached Soft Seal? They advertise that if you send them a part they will reproduce it.
That said, I tried to get them to reproduce the rubber bumper that goes on the ash tray door but they wouldn't do it. However, I would think there would be more demand for this firewall grommet.
Just a thought.
Old 10-09-2007, 03:47 PM
Just a thought.
I know Steve Ames well, so that's why I went to him. I haven't tried Soft Seal and I don't have the mint original that I once had to send to them anyway.
Bob Kazian
Taylors, SC
[email protected]
Old 10-18-2007, 12:02 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
This is what the 66 AC harness/hose grommet on my parts car looks like.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 10-18-2007, 03:46 PM
hawk36 hawk36 is offline
Unhappy Me 2
I also need one for my 66. As does a friend. Please advise if a source is discovered.
Both require 4 holes, and both broke in small pieces while removing, even with great care. Thanks.
Old 10-18-2007, 07:22 PM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
Go this link . and pT# 990411 page 89 cost $5.25 each . http://www.restorationspecialties.co...alog%20PDF.pdf. It sure appears what your looking for.
Scott
If you always do what you always did
You always get what you always got
Old 10-18-2007, 08:16 PM
Wink may try it
I'll get hold of them. These have a large hole, medium size hole and two small holes, but if this one has 4 smalls, it is thick and fits close to a 1 3/16 hole, it would be well worth a try. Will let you know. Thanks!!
Old 10-18-2007, 08:38 PM
Sammy B's Avatar
What do you know, somebody does make them! It doesn't look exactly like what I had, but close enough to make it work. Very cool!
Thanks Kate67!
Sammy
Old 10-19-2007, 05:41 PM
A-body A-body is offline
Sammy/Hawk
I have one if one of you guys wants it. It appears that most of it's life it spent part in, part out of the hole, so it has a small crease in it, plus it is twisted. I put it in a hole in the firewall, and it stayed in the groove, but the small crease was still visible. $5 delivered. Sammy, you asked first, I'll give you first shot at it.
Gary
ID:	108482   Click image for larger version
Old 10-19-2007, 06:20 PM
Thanks Gary. If Sammy doesn't want it, I will take it. With luck, maybe I can at least get the hole measurements, etc., and make a mold. Let me know.
[email protected]
Thanks.
Old 10-19-2007, 10:09 PM
Sammy B's Avatar
It's all yours Hawk. I've now got an oil pressure line and temp line running through that same hole in the firewall. I don't want to hack up an original part that somebody else could use. Thanks A-body.
Cheers,
Sammy
Old 02-26-2011, 10:28 PM
Old Goat 67's Avatar
I know this is an old post, BUT does anyone know a source for these grommets?
Charles
