Old 10-08-2007, 09:52 PM
bristew8 bristew8 is offline
Default torque converter
Will a torque converter from a turbo 400 work in a turbo 350?????
Old 10-08-2007, 10:04 PM
GonicGM's Avatar
GonicGM GonicGM is offline
Yes.
Gregg V.
Old 10-08-2007, 10:17 PM
D. Miles's Avatar
D. Miles D. Miles is offline
As forementioned, yes! but why... back in the old days the trick with a T-400 equiped car was to find a T-350 converter as they were smaller (lighter rotating mass) and a bit higher stall. With that said, unless you have a performance torque converter from a T-400 that you want to use on a T-350... Thanks D. Miles
Going TurboCharged!
Old 10-08-2007, 10:21 PM
The reason is I have a turbo 350 with no conveter that is fresh rebuild and my buddy has a brand new t/c for a 400 turbo I can have for free @ about 2500 stall
Old 10-08-2007, 10:23 PM
By the way I want to thank all the guys on here for your advise
Old 11-02-2007, 10:22 PM
Dan Linebarger's Avatar
Dan Linebarger Dan Linebarger is offline
It is ironic that we call it a torque converter yet rate it in RPMs. Shouldn't the converter be rated in Ft. lbs of torque?
What I am getting at is that the converter needs to be designed to match the torque curve of the engine infront of the tranny.
So, pulling a 2,500 converter out of one engine and putting it in another may not work if the torque curve of the second engine is different.
Men feel younger by driving old muscle cars.
Women feel younger by doing a little "nip and tuck".
Both are expensive and darn well worth it!
Old 11-03-2007, 10:40 AM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default TQ ?
Can I ask a question here? My convertor just went out and I run a stock 350 eng. auto trans. with a th350 trans. and i was wondering if i can put a T C with a stall? I don't know anything about TC's.
Please advise.
Thanks,
Old 11-03-2007, 02:23 PM
Default sure
Please advise.
Thanks,
Sure you can install a converter with a different stall. Make sure to supply the manufacturer with some specific information about your car.
When Butler provided me with a TCI transmission and a 2,800 rpm "Flash Stall" converter, it was after they reviewed some specific info.
Such as: rear end ratio, cam specs, compression ratio, etc.
Keep in mind what rpm your car is turning when driving down the road. If you have a high rear end and at 60 mph you are turning less rpm than where TC is locked up, you will be slipping.
But, before you install the TC, you may want to check the tranny for metal.
