Now you just need a white 72 to round out the set!
![]() Congratulations - but where are the pics?
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
I'll take and post some pictures in the near future. The car is heavily rusted and is missing the original engine. Please be on the look out for a 455 HO with a partial VIN ending in 112769. The original M22 is present.
Boss- Mr. San Marco's 72 Lucy blue auto TA was born on my birthday so that would be the one I'd like to have.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
http://www.starspangledbannerchallenge.com/ |
Enjoy the resto Rob. It was good dealing with you.
Those are the Camaro hard plastic 70-71 lower door panels. While I haven't seen any documentation on it, it seems that as the padded Firebird lowers ran out, they started using the Camaro lowers on the Firebirds since they were likely already planning the change for '72. This car being an 05B build likely came with them.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
We've kicked this around before & it appears that they saved the soft lowers for Custom Trim interiors... I don't recall seeing an original 71 Custom Trim interior with the hard ones... which have been in reprodution for about 5 years now...
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
| The Following User Says Thank You to 2manyT/A'S For This Useful Post: | ||
I bought a set of KR's for my car only to find out later that my car should be wearing KN wheels. Around where I live, none of these guys would have been the wiser, but I'm so damn stupid I couldn't live with it. A great member here fixed me up with the right wheels. It's an affliction. I don't know why this fabulous red '71 Formula is even for sale, I would never let it go. It's beautiful and the guy in New York did a great job restoring it, bent rivot or no bent rivet.
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
Slightly off topic.......looked at a 70 Formula 400...cowl tag has an A stamped past the W66 stamp which designates vinyl top color (black) ....but NO sign of the top on the car OR invoice...
Mistakes on tags did happen.
Ya know, being a shop owner and always wanting to be professional I hold back on comments or stay away from them, but not this time...
I will make this short... Transamric, GO F*** yourself |
Take a look at the right side rivet on my tag. Looks just the same as the red car's rivet.
http://forums.maxperformanceinc.com/...d.php?t=695444 |
| The Following User Says Thank You to njsteve For This Useful Post: | ||
Yeah, I agree with Steve on this. Trim tags have a pretty exposed life since that portion of the firewall was used to store wrenches, beer, roach clips maybe? while under the hood.
I don't know of one car I've restored or had restored that the trim tag didn't come off so the firewall can be cleaned and prepared properly with the red oxide 'dipped' look on the body followed by the application of the trim tag and finally the black out over it all. I actually appreciate the way the Formula trim tag appears. The red oxide shows under the tag just as it's supposed to. The assembly line blackout on the firewall was less than perfect and when red oxide shows under assembled parts or lack of blackout I really dig it. One other nuance some may not know, but the color of the car is also often times on the trim tag. Overspray from spraying color on the bulkhead prior to installing the fenders would get on the top of the firewall and trim tag. In these two examples you can see the blue and silver along the leading edge of the trim tag. Very sexy stuff if you can emulate that during restoration.
| The Following User Says Thank You to 165th For This Useful Post: | ||
So much for your professionalism!! ![]() Since when are you so threathened by a simple question. If I'm wrong, I'm wrong. What's that to you? BTW, I'm a shop owner too. That has exactly what to do with this??
looking at 165th's trim tags, you can see 1 has sealer in the holes. is there any rhyme or reason for this, as the other doesn't? i know i have cars with and with out, just wondering.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
In my observation...and we've kicked this one around before......70 & 71 Van Nuys builds had the cowl tag rivets filled with seam sealer & Norwood builds were generally not....
However...it appears that it may have depended on WHO was installing them. Also,where I live,it rains ALOT.....so anybody under the hood seeing a puddle over the tag may have picked the sealer out to drain the pond....... (actual size/shape of tag was different on VN vs Norwood builds) Also,not picking sides on this one........BUT,this 71 HO did get tossed into the "shark tank" and if I was the "restorer" of this this car.I'g be pretty happy that the cowl tag is the ONLY thing that drew LESS than positive attention/comment. My opinion...It's a stunning car/restoration & the cowl tag is not up to calibre of the rest of the restoration....it's just a 40+ year old tag that has suffered a bit of trauma over the years...
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! Last edited by 2manyT/A'S; 07-03-2013 at 04:39 PM. |
FWIW - Here are a couple of shots of the (undisturbed) cowl tag on my old '72 Formula 455 car.
Being a 1972 model, it was from Norwood assembly, of course.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
| The Following User Says Thank You to Lloyd-TX For This Useful Post: | ||
I seem to recall something on this way back........did we ever find out what the hand stamped #'s were by the right rivet?
Needs a bunch of TLC but it's got a lot of potential.
| The Following User Says Thank You to RAJ7395 For This Useful Post: | ||
it seems that a lot of 72's have those pesky little numbers stamped on the trim tags..... i actually have two sets on one of mine....
