Old 01-22-2008, 05:30 PM
Rob Roy Rob Roy is offline
Default opinions on autofeed screw guns
I have to build a sprung dance floor for my wife's dance studio. Found a vendor that sells a do it yourself floor. Plans call for two layers of alternating 1/2" plywood with 120 screws in the top layer of each board. I'm looking at approx. 5000 screws to be driven. So I'm thinking I should splurge for an autofeed screwgun and wondered if anybody had an opinion on any certain brand. Thanks in advance, Rob
Old 01-22-2008, 08:31 PM
Don Brown Don Brown is offline
Default Autofeed screw gun.
I have a Milwaukee with sharpfire and it works great. If you are goiing to get one, get the one that is interchangeable, hooks right to the drill and has a 30 or so inch extension for doing floors. You can get the screws online. GREAT time saver and easy on the back.
Old 01-24-2008, 11:06 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I had a QuikDrive to do cement backer board and it worked great. Sold it for most of what I paid for it when I was done.
Sprung dance floor? Shall we send you all of our used Pontiac valve springs?
http://www.pontiacpower.org/
Old 01-30-2008, 06:25 PM
thanks guy's, ended up going w/ senco 300 s2, home depot give me a good deal, along w/ all the osb and plywood. Old valve springs?
Old 01-31-2008, 11:22 PM
fiedlerh's Avatar
The Senco should work fine. Gymnastics floors are two layers of wood (with padding on top) and a bunch of springs between them to provide cushion. Is that how a dance floor is?
Old 02-03-2008, 05:22 AM
pretty much, same concept. 3/4" foam every foot square glued to plywood. plywood layed down (foam down), then osb screwed perpendicular to the plywood. dance vinyl floor on top.
Old 02-03-2008, 11:54 AM
The Boss's Avatar
The Boss The Boss is offline
I've got the Senco 300, nice tool, best thing is you won't hurt your back or your knees!
I bought it for my guys to use when putting in subfloor for tile. It paid for itself in labor savings the first day!
And go racin' in the street.
