Old 01-24-2008, 02:49 PM
Nuts an Bolts Nuts an Bolts is offline
Default Won't start !!! after its warmed up !!
Hey everyone ! I have a fresh big block, new starter, new battery, and it cranks over fine and fires , but after it warms up and I turn it off, it turns over very sluggish and won't fire till it cools down a bit... Whats going on ?
Old 01-24-2008, 03:04 PM
6704gto's Avatar
6704gto 6704gto is offline
THE STARTER MIGHT BE GETTING HOT FROM THE HEAT OFF THE MANIFOLDS AND WOULD FIRE UP TILL IT COOLS.DO YOU HAVE A HEAT SHIELD ON UR STARTER
Old 01-24-2008, 03:35 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
what kind of starter???
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 01-24-2008, 03:56 PM
Colorado_Goat's Avatar
Colorado_Goat Colorado_Goat is offline
Timing may be pulled back too far. What do you have it set at?
A bad day fishing beats any day working!
Andre's Avatar
Andre Andre is offline
This is not unheard of with a fresh motor and super tight tolerances combined with a less than great starter and insufficient cold cranking amps.
Try a battery with a CCA of 1000. Another option would be a high quality hi torque starter.
Old 01-24-2008, 05:26 PM
patox's Avatar
patox patox is online now
Send a message via MSN to patox
I have the very same problem...
At cold start, it fires up very quick, just a turn of the key, but after some driving, it starts to turn over very slow.. and sometimes need more than a few try's before getting started.
Last week, I drove it for like 1/2 hour in a very warm day (35°C), I stop it for like 20 minutes and when I tried to start it up again... slow turns.. until the batery get dead.
I have to use a spare batery and cables and it finnaly fire up... then I drove it home (5 minutes, not long enought to charge a dead battery), and let it rest. After the weekend, I come back with a fresh battery and cables. I was very surprised to see my car firing up at the first turn of the key (before jump-starting it), just like it does any regular day.
Only conclusion, there is another problem, not just the battery charge.
Had any one suffered/solved this problem before???
Thanks!
Old 01-24-2008, 05:27 PM
patox's Avatar
Last week, I drove it for like 1/2 hour in a very warm day (35°C), I stop it for like 20 minutes and when I tried to start it up again... slow turns.. until the battery get dead.
I have to use a spare battery and cables and it finally fire up... then I drove it home (5 minutes, not long enough to charge a dead battery), and let it rest. After the weekend, I come back with a fresh battery and cables. I was very surprised to see my car firing up at the first turn of the key (before jump-starting it), just like it does any regular day.
Thanks!
Old 01-24-2008, 05:36 PM
slowgto slowgto is offline
Your battery cables might be too small, or you might not have the GM high torque starter.
Old 01-24-2008, 05:43 PM
patox's Avatar
I think I have the original 67 400" starter.... Is there any way to confirm it?
Maybe old cables could be the problem.
Old 01-24-2008, 08:43 PM
Andre's Avatar
Also make sure all grounds and connections are good, and positive cable is shielded from heat of manifolds. heat shield on solenoid would also help. Hot start problems are pesky
Old 01-25-2008, 01:37 PM
Cardo's Avatar
Cardo Cardo is offline
Get a hi-torque mini starter.... i had the same problem and have not had it since i changed the starter.
Old 01-25-2008, 03:10 PM
6D6GOAT's Avatar
thats what i was getting at
My T56 Install
My Turbo Build
Misc Build Pics
Old 01-26-2008, 12:07 PM
428PHIL's Avatar
428PHIL 428PHIL is offline
Had my stock starter converted to hi-tork and never have had a problem. Running headers, 464 cubes, roller cam,etc. I do have a heat shield on the starter.
Old 01-27-2008, 11:59 AM
Colin_McF's Avatar
Colin_McF Colin_McF is offline
I had this same problem also and what fixed mine was to use a remote solenoid (Ford).
I got this info from a posting on this site but i cannot find it.
if you search remote solenoid there is lots of very good info.
Colin
Feb 14/1994-Nov 29 2012
Rest in Peace sweetheart.
http://picasaweb.google.ca/68Firebirds
"Never forget where you're from"
Colin
Old 01-27-2008, 04:02 PM
Habanero's Avatar
Habanero Habanero is offline
Are your points adjusted right?,,,, i know with new motors sometimes the timming needs ajusted to a new mark ,,, try having some one crank it over when warm while you turn the distributor a bit to see if you can find the right spot.
ALWAYS POWER!!!! ALWAYS PONTIAC!!!!
http://www.cardomain.com/id/habanero
Old 01-27-2008, 04:33 PM
wase's Avatar
wase wase is offline
Yeah, thats it, make sure you have good battery, properly sized cables and at least, a high torque starter. Also to ensure fast start-ups make sure the tune up is good, meaning timing and dwell, cap, rotor ,wires and plugs. Also make sure that the carb is O.K., as there could be some flooding or vapor locking happening. Do any thing to keep the running coolant temp in an acceptable range. Pontiacs tend to heat up the starter and solonoid from the exhaust heat. Some cars came with a heat shield on the starter. Aftermarket parts can help but I like keeping things factory. Good luck
Old 01-28-2008, 02:39 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
Heat sink will cause that issue plus poor grounds, I would start with those first.
Make sure your ground is good to the engine or frame - scrape paint and other material off and get the bolt nice and tight, cable should be at least 4 awg. Make sure alt. ground is good as well. If that is good already and assuming the engine tune is good then heat sink could be the issue. You can fab. an aluminum cover to keep heat off the sol. or get a wrap like DEI makes for example to cover the unit. I had the issue then went to a Hi Torque mini starter.
Old 01-29-2008, 10:16 PM
Bill H's Avatar
Bill H Bill H is offline
Default Remote
I also used the remote solenoid and adjusted my timing. No more problems. Got the remote from Summit.
67 GTO HT
1968 400 Engine YE
TH-400
#13 Heads -J069
Q'Jet .
8.2 Eaton Posi/3:55
Old 01-29-2008, 11:01 PM
carcrazy carcrazy is offline
If everything is in good condition and that you have adequate wires sizes and good ground and you're still having the problem, get a RobbMc mini starter. Very high quality and also gives you increased clearance if you have headers.
Old 12-10-2008, 02:30 PM
patox's Avatar
Sorry to bring this tread back from the death, but had any one tryed this starter?
http://store.summitracing.com/partde...5&autoview=sku
Any comments will be apreciate!
