Old 03-01-2008, 09:00 PM
AdamHoud's Avatar
AdamHoud AdamHoud is offline
Default Secondaries not opening?
So after a long while, my engine is completely running. I just did a final valve adjustment to fix one ticking. This is a street 350 with 4bbl Q-Jet/stock iron intake, and dave ray small body hei dist. The q-jet was done by Jeff Walker. Can I get some suggestions what would cause the secondaries not to open?
1973 base firebird
Original 350, with 69' #46 heads, crower 60240, 9.3:1 cr
Old 03-01-2008, 09:10 PM
hal101's Avatar
hal101 hal101 is offline
choke not all the way open
Old 03-01-2008, 09:33 PM
BB1968's Avatar
BB1968 BB1968 is offline
Check and see if you can open them manually. Make sure the choke is open and check to make sure the gasket is not interfering....BB
Old 03-01-2008, 09:37 PM
snakepod's Avatar
snakepod snakepod is offline
Are the throttle blades opening? If not check the gasket to the intake, for binding. If the secondary airvalve is not opening, check to make sure that the lockout from the choke is not interfering. Also make sure the choke pull-off is releasing.
Old 03-01-2008, 09:42 PM
Malky Malky is offline
How do you know they are not opening? They will not open just revving the engine in neutral.
Old 03-01-2008, 09:47 PM
AdamHoud's Avatar
The choke is opening, and runs great on the primaries. When driving it around town or on the freeway it downshifts and runs great but no noticeable change. I never said anything about revving the engine in neutral.
1973 base firebird
Old 03-02-2008, 08:11 AM
snakepod's Avatar
With the motor off, open the secondary airvalve by hand. Have someone depress the gas pedal all the way. Look and see if the secondary throttle blades open up, or if they are stuck. Also make sure the air valve spring is not too tight. Make sure you have the correct choke pull off as well.
Old 03-02-2008, 10:44 AM
David Jones's Avatar
Jeff Walker built it? Well there's your problem..........
While your depressing the throttle make sure the cable is capable of opening it up all the way
Old 03-02-2008, 12:55 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Well I would have called Jeff and asked him for his opinion/advice. He is one of the good guys here and I assume will work with you to solve the problem.
Old 03-02-2008, 01:11 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Already responed to Adams PM and included my phone number.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 03-02-2008, 03:56 PM
BVR421's Avatar
BVR421 BVR421 is offline
A qjet that is close to perfect in setup you will neither hear nor feel the secondaries as they open.
Old 03-02-2008, 09:51 PM
I agree. I haven't seen any evidence yet that the secondaries AREN'T opening. That is the point I was trying to make in my previous post.
Old 03-03-2008, 01:29 AM
goatman65's Avatar
I have heard that you shouldnt feel them open,but for a street car 'feeling' the secondaries open when you nail the throttle is part of the fun.For a strip car,different story.
Old 03-03-2008, 06:30 AM
Cliff R's Avatar
Cliff R Cliff R is offline
You shouldn't reall feel them "kick-in". When set correctly the transition onto the secondaries should be smooth and seamless. Even so, when going to full throttle, you should see a dramatic increase in engine power output as it gets into the higher rpms.
If the engine power is WAY off, feels "flat" clear across the rpm range, etc, it still doesn't mean that their is a carburetor problem. If the mechanical throttle plates work during a static test, and the secondary airflaps aren't binding on the link, and open freely by pushing down on them, the problem is likely someplace other than the carburetor......Cliff
Old 03-03-2008, 10:51 PM
AdamHoud's Avatar
Yes, I think everything is actually fine, the transition is very seamless. Jeff Walker does great work.
1973 base firebird
