Old 06-26-2008, 11:57 AM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
I said it before, and I'll say it again... WDCreech, that is one bad MOFO!!!!!!!
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 06-26-2008, 12:24 PM
cgeise's Avatar
cgeise cgeise is offline
Ok - this is tough - as the car has never been run all out - it would flip over at the starting line - - but at 9.90
163.40 MPH
60 foot is where ever I want to be - remember - throttle stop
123 mph at the 1/8 with over 3 sec of stop on
535 IAII Tiger heads
Powerglide
4.1 rear and 33" tire
c-15 fuel
All the calculations say the car would run 8.20 at about 165 -
weight is aprox 2250
Old 06-26-2008, 12:50 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
But that's why they make them there wheelie bar thingies, isn't it?
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 06-26-2008, 12:55 PM
cgeise's Avatar
Trust me - they are on there - way to many good super gas cars have been destroyed by not having them on - Its a scary thing
Old 06-26-2008, 01:40 PM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Talking Still street driven but probably shouldn't be!
65GTO 3500lbs
497cid 12.9:1 110octane No Power Adder
Factory Block/Crank/D-ports
T400/9.5"4200stall/3.91/30"x9"Radial Slick
Footbrake/6550DA/4900ft Altitude
1.50 60ft
[email protected] 1/8th
[email protected] 1/4
PHILLYGOAT
http://ourworld.cs.com/GOAT490/myhomepage/auto.html
Old 06-26-2008, 03:24 PM
1970 Trans Am
Pump gas street car (10:1 cr)
Full interior and full exhaust
Race weight about 3750 lbs.
IA2 block / 505cid
TH400 transmission / tight 8-inch converter / 3.73 gears
(also use a TH200-4R overdrive trans)
1.51 60-ft / 10.63 / 127.05 mph
(96 degrees, 42 percent humidity, 3442 density alt, 30.14 barrometer)
http://www.popularhotrodding.com/fea..._am/index.html
Old 06-26-2008, 04:07 PM
9secdport's Avatar
9secdport 9secdport is offline
Default ET
462 14.5:1, 62 dports naturally aspirated
3250 w driver
1.30 60'
[email protected] 1/8mile
[email protected]
New 523" IA2 With KRE hi ports on the way ?
old combo
70 firebird 3250# race weight
462 #62 d-ports best 9.60 @ 140.20
naturally aspirated
new combo
70 firebird 3280# race weight
523 HiPorts by EIC Motorsports
[email protected] N/A
Old 06-26-2008, 04:34 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Red face
Since the Dude sez "all the way to 15's", here's mine:
'72 Formula 455 w/ A/C
N/A
3925#
467" - 4.200" x 4.21"
Barton 7F6 heads
TH400, GM "L88" converter
3.08 gear
MT 275/60R15 tire
1.84 60'
12.93 @ 106
Regards,
"455HO" Lloyd
Old 06-26-2008, 06:15 PM
BILTIT's Avatar
BILTIT BILTIT is offline
'74 ventura (80% street/20%strip)
462 9.5:1, 670 D-ports, 91 gas
3750 w/driver
TH350, conti 10''
3.73, 275/60 MTDR
1.64 60'
11.97@111
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 06-26-2008, 07:18 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
1963 Lemans 3450# w/Driver All steel but the hood. All factory Glass
No Power Adders
535 IA II with Semi WP E-Head (R.A.C.E. Ported) 12.9 to 1 Comp
Turbo 400 Manual Reverse 9" ford 456 14 32 15
3400 DA (PSN 2008)
9.801 @ 136.7
1.36 60'
6.22 1/8
Through Full Exhaust And mufflers
Seats and Carpet
Antique Licence plates
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 06-26-2008, 08:00 PM
60man's Avatar
60man 60man is offline
Since I don't recall seeing any full size barges on here yet....I'll break the ice..
60 Full Size Ventura / Race only
#4,126 with me on board
IAII 508 with KRE 325 D-ports , 13.6 - 1
TH-400 & 4:30's
60'-1.50
1/8 mile - 6.90 @ 100
1/4 mile - 10.90 @ 124
Legal NSS car with interior but through open exhaust..
Hummmm...guess I should check avatar for a update ???
Oh well ...I'm lazy..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 06-26-2008, 08:15 PM
Goathead's Avatar
No Power Adders
3400 DA (PSN 2008)
9.801 @ 136.7
1.36 60'
6.22 1/8
Seats and Carpet
Now correct that down from 4100' to sea level, and the truth comes out. That car is fast....
Old 06-26-2008, 09:31 PM
I ran a 11.55 at 117 in my all steel 64 GTO Convertible with a 400 engine many years ago. Hurt a lot of parts including the car to get there. Young and Foolish. Some say that is a pretty good time for a vehicle of that type with a tire that will fit under the wheel houses without mods.
I have driven a Vega that was faster than 9.40s but that was the best I did with the car. Have to admit that the Old Man (Pontiac Dude) and many others have got me covered on this topic pretty good.
Old 06-26-2008, 09:57 PM
mels80ga mels80ga is offline
My car is slow, but I have a lot of fun with it. It is a 1980 Grand Am, all steel-3400#. Street driven, bracket raced every Sat. in footbrake class. I drive to the track, remove the breather, let the air out of my ET Streets and race. 406 with #62 heads, pump gas, 3.73, full exhaust. 350 auto with redneck 10" 2800 converter.Ran 7.69 @88.25 with a 1.73 60' NA, and 7.15 @ 94.79 with a 1.59 60' on a 125 shot.
Mel
Last edited by mels80ga; 06-26-2008 at 10:05 PM. Reason: Forgot the 125 shot on the 7.15..
Old 06-26-2008, 11:11 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Thanks, Chris! I just felt that I shouldn't represent it as something that it wasn't. By the time I came back and saw my mistake, it was too late to edit the post.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 06-27-2008, 12:08 AM
JKrull66's Avatar
Snuck up on you first round HEE HEE Tons of fun...LOL But you got me in the end
John
66 GTO HT Cruiser
POLARIS 900 RZR
Old 06-27-2008, 09:29 AM
Goathead's Avatar
I know the feeling. The '68 bird had that tendency. It came pretty close to setting down on the wall from above, and then the bars went on...
  #38
Old 06-27-2008, 04:18 PM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Post 461 cu.in.
400 block,4.250" Crower Billet crank.
035 over,with non wide port E-Heads.
flow at 332@700 lift intake.
exhaust flow 235@700.
roller cam is 700 net lift.
276-280@050 duration.
Car with driver is 3070lbs.
60ft at 1.28-1.30 average
single 1050 holley.
victor intake.
  #39
Old 06-27-2008, 04:22 PM
Thumbs up
Best pass so far is 9.26@145mph. Had lifter bore issue last year and have yet to put motor back in car.Made some minor changes to hopefully improve ET by 3-4 hundreds. Would really like to get car into the high 9-teens with this combo.Hopefully by end of summer, will have car up and running again.
  #40
Old 06-27-2008, 09:54 PM
GTO's Avatar
GTO GTO is offline
First time out at Grand Bend going for my license it ran 9.59@140. 6.13 in the 1/8. 1.35 60'. 1970 455, 4.25 stock crank with Ross NOS pistons and Chevy 6.8 Oliver Billet rods. Ron's 4" toilet on alcohol. Could not weigh car but think it's about 2800 with me in the seat. E-heads are non wide ports. First time with injection and alcohol so I was just playing around, LOL! It started with a 9.8 off the trailer but was very lean. Richened it up and ran 9.7. Once more and ran 9.59. My day was over and we packed up. Ran at an airport race the weekend after and I richend it up again and it ran a 6.13 with a 1.45 60'. We're going to Armdrop soon and am hopeing to run in the 9.30's-9.40's. With a little NOS added I should be in the 8's. ... Eric
Runner Up Q16 Norwalk 2013!
