Old 06-30-2008, 06:49 PM
lreGTO65 lreGTO65 is offline
Default 65 GTO Tail lights
I dont know about everyone else but mine are really dim, especially during the day. Im always nervous someone is going to rear end me. I did the normal tricks. Painted the back of the housing white. Buffed the lenses' themselves. Put new bulbs in them, made sure all the connections were good. But still not too much better.
Wondering if anyone has tried LED tail lights? In the new '65 im building im thinking I might try it, but that will be manly a race car only. But if it works ill do it to my REAL GTO.
Old 06-30-2008, 08:10 PM
xgoater's Avatar
xgoater xgoater is offline
I was having a very similar problem with my utility trailer lights. The tail lights were on, but so dim you could hardly see them. It ended up being a weak ground wire - once I cleaned and made sure it was a good ground, the tail lights were much much brighter. You may want to check your ground and see if that helps.
Old 07-01-2008, 02:30 PM
FFD FFD is offline
Keep informed on how the LED works out. Like most older cars tail lights not the best. Chrome paint works better than white. Another easy. Thin gauge stainless strip polished up around the bulb is good also. Also try a search someone tryed brighter bulbs with good and bad results. Think it was sandman joe but not sure
Old 07-01-2008, 04:17 PM
mwritter's Avatar
mwritter mwritter is offline
I've got LEDs in my '65 and they are BRIGHT. They are still partially blocked by the grilles, but a 1000% improvement over the stock bulbs. Got mine for about $18 at Autozone.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 07-01-2008, 10:55 PM
ReelFun's Avatar
ReelFun ReelFun is offline
Do you just replace the bulbs with the LED bulbs or does it require any other modification?
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 07-02-2008, 10:08 PM
mwritter's Avatar
Old bulbs out, LEDs in. That's it.
Matt
Old 07-04-2008, 01:14 PM
mike hayes mike hayes is offline
Did you get red LED lights or white?
Mike
Old 07-05-2008, 02:35 AM
goatman65's Avatar
Same problem with my 65.Do you know the LED brand and bulb #? I tried one once and it wouldn't even light up.I don't remember what brand I tried.
Old 07-05-2008, 10:25 AM
mwritter's Avatar
It's been a while, so I'm having trouble remembering. I think there were only two options at Autozone, and I cross-referenced the original bulb PN with the LEDs. I think they had a list of regular bulb numbers which they replaced on the packaging.
Matt
Old 07-05-2008, 11:59 PM
goatman65's Avatar
I'll check the local Autozone,thanks.
Old 07-07-2008, 08:41 PM
classic396 classic396 is offline
Default bulbs
I have found most led replacement bulbs do not last very long.Check Dakota Digital for replacement led circuit board lights. I put them in my 69 chevelle, and they are awsome. I will be at the Goodguy's in Columbus this weekend, and someone always have them for sale there. I will post where you can get them when I return. Dale
Old 07-09-2008, 07:00 AM
Tim john Tim john is offline
The LED's will also work out very well for the parking lights. You may have to however trim the steel ring just below the glass bulb to fit the factory socket. The original 1157 bulbs do not have this trim ting so a little modification is all that it takes and the LED's will fit right in, a much better light source, again you may want to enhance the background with white or chrome paint to get the most out of the LED's.
Tim john---
Old 07-09-2008, 08:02 PM
When I checked autozone a few months back they only had read and the salesman told me they would not show up well in a red taillight, said they were more for the clear taillights on newer cars, are you guys using red led's?
Mike
Old 07-09-2008, 08:42 PM
Lonster Lonster is offline
Default Check older post...
I think this is a common problem. Check out this thread http://forums.maxperformanceinc.com/...d.php?t=525293 It has the socket and part # at Advanced Auto to help the problem...
Don't make something a crisis when it's a crossroad.
Old 07-09-2008, 09:39 PM
Default led
My luck with the replacement led lights like the 1157 led, were all junk in a few months. I sold them at my shop for a short time, and almost all came back. many caused shorts, popped the taillight fuse, and melted the socket. Maybe some are better now, but the will not reflect off of your taillight inner housing, no matter what color you paint them. They are a direct facing loght only, not like incadescent lights, that are 360 degree light
