Old 07-04-2008, 05:10 AM
superblue72 superblue72 is offline
Default 400ci pontiac motor mounts
I have a six cylinder engine in the ventura right now. I'm looking at a 400ci engine, where could i get the right motor mounts? or could i use the mounts that the six already has?
Old 07-04-2008, 01:26 PM
69f bird's Avatar
69f bird 69f bird is offline
You will need the frame-side mounts for a Pontiac V-8. The aftermarket mounts are not 100% right. They can likley be "massaged" to work. They are the same for the 68-74 Venturas and the 67-69 Firebirds.
For the motor side, the same rules apply (68-74 Venturas and the 67-69 Firebirds). If you are doing something with significant power, consider the Mity Mounts...they privide a solid connection for the drivers side mount, otherwise, stock mounts will work.
All of my cars are Hybrids...they burn gas and rubber!
'73 Ventura, Spotts 462 roller
10.785 @ 122.79, 1.507 60 ft
2850 lbs. plus driver, 3150 race weight
'69 Firebird Convertible, Spotts 455 with long branches
12.561 @ 107.62, best on old 455
4290 race weight
'72 Formula 455 HO
numbers matching auto, work in progress!
Old 07-04-2008, 04:45 PM
from the list here http://www.mitymounts.com/pontiac.htm
should i get the mounts for the 67-69 firebird w/ 400ic or 71-72 Ventura for the 350?
Old 07-04-2008, 06:04 PM
72Ventura's Avatar
72Ventura 72Ventura is offline
They are the same part number.
The beatings will continue until morale improves!!!
Old 07-05-2008, 05:18 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Yup, same mount. I run them and they have been good so far.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 07-08-2008, 12:06 PM
Kyflier Kyflier is offline
You can get the frame mounts from Tamraz Automotive parts. They usually have a couple of sets listed on ebay. Get the ones for the 67 to 69 Firebird.
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 07-08-2008, 12:42 PM
engineer engineer is offline
have some new old aftermarket mounts (anchor no. 2254) for $36 for a pair shipped to lower 48. Pm me if interested.
Old 07-08-2008, 02:14 PM
The car has a 6 cyl engine, he is needing the frame mounts as well
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 07-08-2008, 08:23 PM
"I have a six cylinder engine in the ventura right now. I'm looking at a 400ci engine, where could i get the right motor mounts? or could i use the mounts that the six already has?"
Guess I read it as he having a 400 engine and needs the mounts? He will need both the frame and the engine mounts for the V8 installation.
Old 07-09-2008, 01:32 AM
where do i get the framing mounts?
Old 07-09-2008, 10:08 AM
BILTIT's Avatar
From above.
Derek B.
Old 07-09-2008, 11:45 AM
69f bird's Avatar
The aftermarket frame-side mounts are not quite right...we could NOT get my motor bolted in with them. We grabbed the original set from my '69 Firebird, and they fit perfect. We didn't bother to try to figure out what was different.
4290 race weight
'72 Formula 455 HO
