73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 10-10-2008, 02:52 PM
TA-71 TA-71 is offline
Default Core Support Bushings
My core support bushings are shot on the Can Am, one side literally disentegrated when I took it apart. I know no one makes a replacement set for the Can Am, so what are my other choices?
Thoughts?
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 10-10-2008, 10:25 PM
77 Canamman's Avatar
Lightbulb
Per the Parts Place site (www.thepartsplaceinc.com):
They do not list the core support bushings separately, but I believe that they are included in the kit... I would inquire to make sure that they are.
BODY MOUNT BUSHING KIT-ALL SHOULDERED RUBBER BUSHINGS AND BISCUITS FOR RUBBER POINT CHASSIS MOUNTS. HARDWARE SOLD SEPARATELY
HB2132Z - (1973 - 1977 GTO/LeMans) BODY BUSHING KIT (KIT IS MADE OUT OF RUBBER WITH STEEL SHELL INSERTS. TWO OF THEM ARE SOLID RUBBER PLUGS & THE TOP CAP BUSHINGS HAVE STEEL WASHERS MOLDED INTO THEM JUST LIKE FACTORY. THESE REPLACE ALL GM NUMBERS: 330942 (4), 457915 (12), 330955 (4), 377801 (2), 6271662 (2) & 330951 (4) - ALL BUSHINGS HAVE THE GM NUMBER ON THEM) - 28 PIECE KIT- $249.00
BODY MOUNT HARDWARE KIT-INCLUDES ATTACHING HARDWARE FOR OUR SUBFRAME BODY MOUNTING BISCUIT SET. KIT INCLUDES BOLTS AND WASHERS.
HB5361G - (1973 - 1977 GTO/LeMans) BODY MOUNT HARDWARE KIT - $29.00
Ames lists just core support bushings for '73-'77 A body and '75-'77 GP..however, they must be in development, since instead of a price, it says "inquire"...
PS445 -1975-1977 Core Support kit-GP ... INQUIRE.
S393 - 1973-1977 Core Support kit, A body... INQUIRE.
I will look to see if I have any new or used core support bushings left over from my projects.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 10-13-2008, 09:30 AM
I called the parts place on Friday, their kit includes all the body bushings but no core support bushings.
I dug out what was left of my old bushings over the weekend, and one side is fully intact, so if I could find a suitable material, that was the correct thickness, I could make my own. Anyone have an idea where I could find a couple sheets of urethane?
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 10-13-2008, 11:46 AM
Question
Have you contacted Ames to see if and when they plan on releasing their bushings?
Old 10-13-2008, 12:13 PM
No, but that is a good idea. I will post back once I get a reply.
Thanks!!
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 10-14-2008, 11:52 AM
Well I just heard back from Ames, and they only carry the body mounts. So back to square one.
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 10-14-2008, 01:04 PM
Lightbulb
Did they mention when they are releasing them? If they are in the catalog, they are in planning.....
Old 10-14-2008, 01:49 PM
The sales person I talked to would not comment on future products, so who knows if they are planning on adding them.
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 12-14-2014, 11:36 PM
leeklm's Avatar
leeklm leeklm is offline
Just dug up this old thread while I have been working on bushings in my 73 GTO. I was very confused when noticing there were no body bushings in my car in the "Number 3" position on either side of the front seats. In addition, the #4 and #5 locations (next two back) only had the rubber cushion on top of the frame, and no bolts.
What confused me even more is that those positions do in fact have the square cage nuts in the body! I thought for sure that someone in the past did not put it back together correctly, until I looked in the manual and confirmed it is correct. Strange.
My bushings are not all that bad (just old and a little soft), so not sure I wanted to spend the $250 on the kit mentioned here at the Parts Place. Anyone have experience with that Kit? Good quality?
On a side note, I had ordered a body kit for the 73 X body, and those mounts will work for the front 4 locations (which you can also purchase separately for $16), but the rest are not compatible.
Old 12-15-2014, 11:18 AM
picon3 picon3 is offline
I bought the kit from Parts Place and it worked great (good quality) with various bits and pieces left over that we didn't use on the 73 GTO build. Paul~
Old 12-15-2014, 01:09 PM
miltmilton's Avatar
miltmilton miltmilton is offline
For what its worth, I measured the thickness of the core support bushing on the Can Am and compared that to the core support bushings for my 65 GTO. While the shape of the inner bushing is different, the thickness was the same. I went ahead and installed them and will be putting the front clip back on in a couple of weeks. We'll see if the fenders and hood come close to lining up.
milt
