Know why they started back, but wonder why they quit for those few years after 63?
Besides making engine swapping easier. |
I'm not sure why they quit after 63.
Maybe time consuming?
i wanted to win the prize..what did i lose anyway?..
My 67 FB 400 has a 6 digit production # that matches GM's build sheet.
There is no vin stamp. I've seen other 67-400's and 326's the same way.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
The Engine Unit Number may have been one reason to drop the VIN on the engine in 64.
They tracked the engine to the car/VIN with the EUN, so didn't need the VIN on the engine in 64.
I could tell you what you DIDN'T win....but then I'd have to kill you....
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
The 67 Firebird I am working on has a 67 400 2bbl as it's engine foundation. No VIN stamp on the block whatsoever. Could have been a service part but it was so complete right down to the 066 cam that I assumed it came from a Catalina, plus it is a YC stamping. Can you guess how it ran with headers, dual quads and an 066 cam?
There is a VIN stamp on the cowl under the cowl cover along with one on the firewall near the blower motor area.
Bob Woodard Brighton, MI 2012 SRT8 Charger - 12.70 @ 111mph |
I had this exact same question. I have a '67 Firebird 400 with the correct YT block, correct casting code of 9786133, with a casting date of A05, or January 5th. This seems to correspond to my car's build date of the 5th week of March according to the cowl tag. Correct 670 heads, etc.
However, my block has a number stamped in the VIN area near the water pump housing, but it's clearly not the car's VIN. It appears to be SR8-3841. I have no clue what these numbers are, but I do think this is the born-with engine for this car. Does anyone have a better idea of when precisely Pontiac started stamping VINs on the blocks? I've read that it was "late in the model year," "during the middle of the '67 production run" etc, but nothing more specific than that. |
ive been told it was later on in 67
Wouldn't that make it on the 68 model year cars though?
Not if they started, say, May 1st or something like that. The normal '68 production lines wouldn't have started churning out '68s until around August 1st or later, I think. That would give you 3+ months of '67s with VIN stampings on their motors.
From the factory, 63 and earlier blocks got the complete VIN, 68 and later got a partial vin. Supposedly no vin 64, 65, 66, part of 67 I think the body vin (not vin plate) is only visible when the heater airbox is removed from firewall. frames also got a vin stamp as did transmissions in certain years |
I'm pretty sure the engine unit # was also stamped on my trans(4-spd) case along one edge by the bell housing.
Maybe your trans is too. Course both could have been changed together.
