Old 12-31-2008, 10:26 AM
OINK 1's Avatar
OINK 1 OINK 1 is offline
Question Digital TV/ Pontiac Gregg /HELP 1/2" stud ! where r u
Do I need to get a special antenna?
I want to keep the 20" CRT tv in the back of my 1968 Bonneville Station Wagon.
I have installed the correct 80 amp alternator and invertor, so we're all good in that department.
(I have it straped in a FAT childs safety seat.)
Will the Wabbit ears antenna I have on the car work, or do I need to go to a 12' full size antenna?
Does anyone know the drag coefficients of standard Rabbit ear antennas versus 12 ft. long multi-element antenna? How much should I adjust my dial in ? Will cross winds affect it?
I race up @ Douglas, Wyoming, it gets really really windy, is there a danger of the Station Wagon rolling over ?
Pontiac Gregg
Greg Merrick
Old 12-31-2008, 10:41 AM
Carl A Carl A is offline
I say go cable better picture!!!
Old 12-31-2008, 10:45 AM
gto-owner's Avatar
gto-owner gto-owner is offline
Look in the Lobby, under the post "Rave" lots of good info there
"sic vis pacem para bellum"
Old 12-31-2008, 10:53 AM
TransAmboy455's Avatar
TransAmboy455 TransAmboy455 is offline
GO HD
1976 Sterling Silver Trans Am Retro Fit 455 WIP
http://www.youtube.com/user/transamboy462
Old 12-31-2008, 10:56 AM
OINK 1's Avatar
Angry Carl A /Pontiac Gregg
Carl, I HAVE tried the cable, but as it reels out the back of the car, the car gets lighter and I almost always break out !! So I switched to the antenna. Carl, you need to help me with ALL the questions !! Also, with the cable, I'd have to pay the disconnect/ reconnect fees everytime I go to a different track. Having the cable reel teched at check in time was a new and difficult problem for them, some times it take up to 5 mins. to tech it !!
Pontiac Gregg
Greg Merrick
Old 12-31-2008, 11:09 AM
fasteddy's Avatar
fasteddy fasteddy is offline
I use the 12 footer on my GP. I put it as far back as I could. The wind is not an issue because the I have half inch cables securing it. It does make for some dandy wheel stands. Oh-I put the HD converter in the trunk next to the power inverter and battery.
fasteddy
Old 12-31-2008, 11:30 AM
The new Fiber Optic Cable is the only way to go so small you can really carry a big spool
no need to rewind, now I'm just talking me now no need to rewind,I'm picking a direction and going for it and not stopping- exept for red lights
Old 12-31-2008, 12:04 PM
fasteddy's Avatar
I have attached a good example of placement for best weight distribution and reception.
fasteddy
Old 12-31-2008, 12:18 PM
Well hold on now thats the ticket ---A TRUCK-- I will have to rethink my thunking.
Old 12-31-2008, 02:00 PM
MandevilleBird MandevilleBird is offline
You guys are old school. Ya gotta go with the dish. It'll work from inside the car so, no wind resistance....and you get lke 200+ channels!
Old 01-01-2009, 06:38 PM
mash mash is offline
the dish is an advantage on the roof when you have tail winds
Old 01-01-2009, 09:23 PM
GR8ONE68's Avatar
GR8ONE68 GR8ONE68 is offline
Talking You might be a redneck if:
You have a UHF-VHF-FM antenna mounted on the back of your truck!
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac
Old 01-02-2009, 01:39 AM
BVR421's Avatar
BVR421 BVR421 is offline
One day into the new year and you guys are already skeerin me
Old 01-02-2009, 11:32 AM
Most of those won't work with your tv without a digital converter box.
You need the stealth antenna:
If you add the 30" wheels, you'll have directional capabilities, also.
Old 01-02-2009, 12:19 PM
OINK 1's Avatar
Thumbs up TV antenna help/ Pontiac Gregg
I just want to say thanks ! Great laughs, what a way to start the new year !!
Laughter, the best medicine.
We need more posts like this !!
Pontiac Gregg
Greg Merrick
