Old 01-16-2009, 06:41 PM
70RAlll 70RAlll is offline
Originally Posted by Dens71TA View Post
Kooter, do you have a picture of the front valance panel? Is it painted black on the bottom?
Dens71TA-
here are pictures of the lower metal valance you asked about. These pictures came from the lowest milage(18,000) survivor 1970 RAIV left. Matt (PY's screename Tellyhavilli) bought it from the original owner and sold it to the guy in Alberta Canada where I flew to see for an inspection. Notice the original design of the lower spoiler, didn't use the 3 long center mount bolts with the 1" long spacers. Plus I added a few more interesting pictures. Notice the extra ground strap on the passengers front side of the carb to ground the air cleaner/scoop.
Plus the yellow/black vacuum break used on 1970 RA Quadrajets,unlike the dual port metal ones used on regular 4 bbl 1970 Firebirds.
. Also, notice the throttle cable bracket.....it is black phosphate,not silver as we see so often.....that one suprised me.....
This car is absolutely untouched. Only work ever done was the drivers side head was replaced under warranty with a SR 614 head(date code visable) It was pretty neat to inspect. The stripes were crooked,there were paint runs, panels mis-fit/aligned etc etc etc .. It was just neat to see how sloppy these cars were originally put togather,especially compared to how nice and neat we all restore our "prized cars".....
ID:	154647   Click image for larger version
ID:	154648   Click image for larger version
ID:	154649   Click image for larger version
ID:	154650   Click image for larger version
Old 01-19-2009, 04:39 PM
ramair kooter ramair kooter is offline
Default engine close up
someone tryed to get the shaker working and removed the switch and the throttle solenoid. we found the switch in the center console. i removed the right exhaust manifold to seal a leak and found no signs of cyl. head removal either side. most vacuum hoses have been replaced. belts and some hoses replaced. battery cables original. THANKS FOR POSTING THOSE PICS RA 111.
ID:	155000   Click image for larger version
ID:	155001   Click image for larger version
ID:	155002   Click image for larger version
ID:	155003   Click image for larger version
