Old 01-19-2009, 08:30 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
Default Noisy Valvetrain
I have a noisy tap on number 8 cylinder rockers that I can't get to quite down, so I'm looking for any suggestions you guys might have. I have a 428 with KRE "D" heads and a Comp Hyd. Roller cam. I've adjusted the valves several times using several methods. I also changed the hyd. roller lifters, push rods, and roller rockers ( Crower ), and I still have tapping on the number 8 cylinder valves only. All other valves are quite. Any ideas?
Thanks. Bob
[SIGPIC][/SIGPIC
Old 01-20-2009, 01:08 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Sounds like the oil galley plug was left out of the rear of the passenger side oil galley. This plug is inside the block about 2" in from the 15/16" access freeze plug in the rear of the block. I drill a .040" hole in the galley plug I install in the rear of that oil galley. It gives positive lubrication for the distributor gear.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 01-20-2009, 09:02 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Did you happen to check the valve guides on that particular cylinder when you changed out the parts?.....Cliff
Old 01-20-2009, 12:12 PM
6T5 Cat's Avatar
Thanks for responding guys.
Paul-drilled gally plug was installed and eng has great oil pressure.
Cliff- no I didn't check the heads personally, but I did have them gone over. I'll have to check with the shop and see if the guides were checked. One thing I forgot to mention; the tapping is llouder after the eng warms up. I feel it has to be something with the head, as everything else has been changed. I guess I'll have to pull the head and have it gone over.
BTW, I received the 10" continental torque converter I ordered from you last week...thanks for the fast service.
[SIGPIC][/SIGPIC
Old 01-20-2009, 08:53 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Could it be a pushrod? Sometimes you get a tapping noise when the pushrod holes have not been clearanced for high ratio (1.6, 1.65) rockers...
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
Old 01-21-2009, 01:33 PM
6T5 Cat's Avatar
69Goat1, thanks for the response. The KRE heads come clearanced for 1.65 rockers, but I checked them anyway and found the clearance to be good. I'm thinking it has to be something with the valve spring. Thanks. Bob
[SIGPIC][/SIGPIC
Old 01-21-2009, 04:24 PM
gtofreek's Avatar
I wasn't thinking about it being aluminum head. They will grow quite a bit and loosen up your valve lash accordingly. How much are you lashing them? 3/4-1 turn? Or only 1/4-1/2 turn?
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 01-21-2009, 11:26 PM
6T5 Cat's Avatar
Paul, lashing them at 3/4 turn. I guess I'm just going to have to put up with the tapping, it's not that loud, just annoying.
[SIGPIC][/SIGPIC
