| SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
I have for sale the following roller set up used on KRE D Ports
5.2" 6000 series SS valves 2.11 intake 1.66 exhaust Comp 919 roller springs and retainers U/D 310/314 solid roller cam If you want to upgrade your KRE D ports to a roller set up. This is the stuff. Used 1 season. This roller cam is worth 50 HP over a 290 B6 solid flat on 310 KRE D ports and a 463. 500.00 plus shipping
68 Firebird Are you running with the wind or breaking it? |
Can you list complet cam specs?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
310/314, 279/283 @ .050, 200/204 @ .200, .4267 lobe, 108 LSA
Intake open 51 BTDC close 79 ABDC. Exhaust open 89 BBDC close 45 ATDC. That is with the 4* advance, 104 ICL
TTT
Will separate if interested. The valves and springs used 1 season with approx 80 runs.
1 set of 16, 2.11 x 5.2" 45* Ferrea SS 6000 series valves $90.00 1 set of 16, 1.66 x 5.2" 45* Ferrea SS 6000 series valves $90.00 1 set of 16, Comp 919 springs with retainers $150.00 U/D 310/314 solid roller cam. $225.00 Plus shipping
Bump
These are RA1V length valves. Will work with e heads as well.
No one wanting to step up to a solid roller cam?
1 set of 16, 2.11 x 5.2" 45* Ferrea SS 6000 series valves $75.00
1 set of 16, 1.66 x 5.2" 45* Ferrea SS 6000 series valves $75.00 1 set of 16, Comp 919 springs with retainers $125.00 U/D 310/314 solid roller cam. $200.00 Above prices plus shipping. Or all for 475.00 shipped
Have any pics of the valves? Why did you change them out?
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
I can take some pics.
I switched to this roller set up last season from a flat solid. I sold the KRE heads this winter with the original flat cam stuff and now have the roller stuff left over. I am going to be running Wenzler heads this season.
Sold. Thanks PY.
