Old 02-06-2009, 02:34 PM
KELLIS2's Avatar
KELLIS2 KELLIS2 is offline
Default This is mine 64 Tempest from north of Finland
Maybe the only one in this shape in my country http://forums.maxperformanceinc.com/.../jumping38.gif
Kyllä lähtee...
  #122
Old 03-12-2009, 09:22 PM
aubi65gto's Avatar
aubi65gto aubi65gto is offline
Talking
Here's mine
  #123
Old 04-07-2009, 12:07 AM
gtome's Avatar
gtome gtome is offline
I see alot of split bench seats in these cars, im looking to recover mine, does anyone make em?
  #124
Old 05-13-2009, 02:08 AM
richard sargent richard sargent is offline
Default Catholic Fathers car
20 years ago I took a 2 door post lemans that was owned by Catholic church of Seattle and i cloned it when you could get GTO parts cheap! Factory black car with red buckets and radio delete. I did hood, core support, stab. bar front rear, quick ratio box, kybs, emblems, 4 speed, tilt, 64 wood wheel, 64 round bar, 64 tach, alum. dash insert, map light, remote mirror, 3.23 posi, pwr steering with quick ratio box, power brakes,splitters.I took a 455 and put dished pistons then ran everything on the top end to 64 gto, you name it, every hose line and bracket etc. Only stuff not correct are some bolt heads, timing cover, dip stick, 67 ho exhaust. SD performance ported the heads 245 cfm 65 tripower cam, quiet exhaust. Later I added 17 inch Cragars style wheels with bfg drag radials only because traction was not there period. I went thru great pains to to make look stock wiClick image for larger version
ID:	168436th 100 plus horsepower and drive like a new car.
  #125
Old 05-18-2009, 10:56 PM
mtnxtreme1963 mtnxtreme1963 is offline
Originally Posted by John_TTD View Post
here is mine:
full road race suspension, big brakes.... 215 cubic inches of fury LOL
The six that is replacing this one is pretty sick.
~J
Nice, what size tires and wheels you got on it?
  #126
Old 05-18-2009, 11:02 PM
Originally Posted by MarkC View Post
Found this "european" lemans that was assembled in Holland north of stockholm. It has a tired 400 in it and factory 4sp/console. Everything is solid but I am sure there is bondo in places on the q-panels. When I get the dough Im callin the dude for help. I couldnt help picking up a dual 4 bbl setup from Jegs on my last visit home in NY.
The wires in this car have gotta go and I will move a modern fusebox to the under hood area.
What size tire wheel combo you got, any rubbing issues?
  #127
Old 05-18-2009, 11:58 PM
225-45-17 american classic with bfg radials no rubbing issues.
  #128
Old 07-13-2009, 11:51 PM
ProFlow ProFlow is offline
http://www.lateral-g.net/members/campisi/
Some completed pictures
Chris
NY
ID:	174809   Click image for larger version
ID:	174810   Click image for larger version
ID:	174811   Click image for larger version
  #129
Old 07-14-2009, 11:56 PM
Default Made a few upgrades to the Tempest lately.
Installed a new 8.5" 3.42 rear end, Eaton posi and 30-spline Moser axles. New adjustable upper and billet aluminum lower control arms from Currie Enterprises.
Added some 2008 Corvette Z06 rear disc brakes, matching front brakes will be installed soon. Rear rotors are 13.4", the fronts will be 14".
Also upgraded the wheels and tires for better cornering power, 18X9" rear wheels with 275/40-18 tires. No cutting or hammering was required, no wheel spacers were needed.
After the upgrades to the car are completed I'll probably trim the rear coils to drop it down an inch or two, right now there's no interior in the car.
Been going crazy with the Tempest lately.
  #130
Old 07-15-2009, 08:43 AM
67blackcherry's Avatar
67blackcherry 67blackcherry is offline
Location: The conservative enclave in a land of liberals; South Orange County, CA
Me thinks that's an understatement.
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house...
  #131
Old 07-16-2009, 04:59 AM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Originally Posted by Scot Thompson View Post
Here is mine...just now getting on the road after 4 years of work. Today it has a YC 455 (462) with hydraulic roller, T700R4 with 2500 stall lockup converter, quick ratio steering box and 4 spoke Grant wood wheel, Griffin custom radiator, new GM wiring throughout, 3.25:1 Safe-T-Trac, Classic Air A/C system, killer stereo (for a convertible) with hidden iPod Nano (plays 2000 early rock songs), RAM AIR Restoration ceramic manifolds with 2/5" exhaust thru Dr. Gas X pipe and Xelerators, Global West suspension with disks up front and factory braces with boxed trailing arms in the rear with finned drums. Body is unrestored with lots of original parts. Wheels are AR Torque Thrust IIs, 16". Not being a GTO I felt free to modernize and upgrade the car rather than restore it. It drives great and goes like stink! It has been a fun... but very long, project.
Scotty
Is that the pale blue color that was available then? Mine was the pale blue, and I'm thinking of going back with it eventually. Looks as good on your car as I visualized it.
  #132
Old 07-16-2009, 05:01 AM
INJUNTOM's Avatar
My '64 Conv:
Name:	Easter 06 229.jpg
ID:	174971   Click image for larger version
Name:	Easter 06 231.jpg
  #133
Old 07-16-2009, 05:05 AM
INJUNTOM's Avatar
My '65
Originally a 6 cyl 3 spd w/console. I have a '66 389 with Muncie 4 spd for it, all GTO trim, new blue interior, and a set of Drag Stars. Will be a couple years before I get to it:
  #134
Old 07-16-2009, 05:18 AM
INJUNTOM's Avatar
Here's my '64 Wagon:
Was a one owner car until last year. Came from a mountain town near the CA border by Reno, NV. I have the first registration stub where it was registered in San Fransisco in '65
A few things done already:
-Dropped it a little in front, and threw on some rally wheels, wider tires, dual exhaust, rear brakes, and changed all the fluids.
-Rear bumper redone
-P/S system I took off my convertible, single piston disc brakes, and Airlift rear bags and compressor.
-700R4 transmission
-Changed front sheetmetal to better stuff, Steam cleaned and painted engine while sheetmetal was off. Went black on the engine so that it could be painted in the car.
-Seats redone
-Stereo
ID:	174975   Click image for larger version
ID:	174976   Click image for larger version
ID:	174977   Click image for larger version
  #135
Old 08-21-2009, 05:10 PM
chipster's Avatar
chipster chipster is offline
Default 65 Tempest
Back in one piece, first time on the road since 1974...still need to weld in a couple of patch panels and finish paint.
ID:	178883   Click image for larger version
ID:	178884   Click image for larger version
  #136
Old 08-21-2009, 05:51 PM
INJUNTOM's Avatar
Dig the Offy covers. I have a set too, and they are seldom seen.
  #137
Old 08-22-2009, 01:38 AM
dracowizard's Avatar
dracowizard dracowizard is offline
Default Nice Touch b-man
Wow bart,thats some sweet mods to the T. Hard to believe everything fits under thee so well without any mods. Was it very difficult to add the corvette brakes?
Gotta Luv some old Muscle..
64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror
3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna
Silvermist w/BlackVinyl Top
http://s161.photobucket.com/albums/t201/dracowizard/65/
  #138
Old 08-22-2009, 02:06 AM
The hardest part was prying open my wallet, I'm a cheap SOB.
The brake kit I bought was pretty easy to put together, it was well-engineered so it was pretty much a bolt-in deal. The emergency brake cables will need a custom bracket, they're from Lokar and are actually made for a late T-bird. These were recommended to me by the guy who sold me the brake kit, they're a fairly easy to adapt to an A-body.
The Corvette has small internal drum brakes inside the rear rotors for the emergency brakes, my 2002 WS6 T/A has the same type of setup.
  #139
Old 08-30-2009, 10:42 AM
Blackwood Goat's Avatar
Blackwood Goat Blackwood Goat is offline
Default 64/65 Lemans/Tempest
Originally Posted by richard sargent View Post
20 years ago I took a 2 door post lemans that was owned by Catholic church of Seattle and i cloned it when you could get GTO parts cheap! Factory black car with red buckets and radio delete. I did hood, core support, stab. bar front rear, quick ratio box, kybs, emblems, 4 speed, tilt, 64 wood wheel, 64 round bar, 64 tach, alum. dash insert, map light, remote mirror, 3.23 posi, pwr steering with quick ratio box, power brakes,splitters.I took a 455 and put dished pistons then ran everything on the top end to 64 gto, you name it, every hose line and bracket etc. Only stuff not correct are some bolt heads, timing cover, dip stick, 67 ho exhaust. SD performance ported the heads 245 cfm 65 tripower cam, quiet exhaust. Later I added 17 inch Cragars style wheels with bfg drag radials only because traction was not there period. I went thru great pains to to make look stock wiAttachment 168433
Attachment 168434
Attachment 168435
ATTACH]168436[/ATTACH]th 100 plus horsepower and drive like a new car.
Rich
Just surfing through,when I came to your car. Great Job! Rich
If everything seems under control,your just not going fast enough. Mario Andretti
________________________________________
May God have mercy upon my enemies, because I Won't. General George Patton
  #140
Old 09-06-2009, 06:54 PM
xavionics xavionics is offline
Default '65 Le Mans
Hello all. I'm a newbie here and a long-time Poncho fan/owner.
1965 Le Mans hardtop
326 2bbl, power glide
Bone stock survivor. Wheel covers are from my Grandma's '65 Tempest Sport Coupe, long since gone. I have had this one for about 20 years, never had a suitable place to tear it down and redo it, not that it needs it.
Highlights: Decent, original condition. PS, PB, factory A/C (needs R-12 or changeover), buckets w/console/floor shifter, had custom dual exhaust installed
Lowlights: Carb is so-so, engine is ugly, needs better stance.
ID:	180374   Click image for larger version
ID:	180375   Click image for larger version
ID:	180376   Click image for larger version
