Old 08-04-2009, 06:08 PM
Scott M's Avatar
Scott M Scott M is offline
Exclamation WANTED: 1968 FIREBIRD HARDTOP; AUTUMN BRONZE
Looking for something from solid project to driver quality.
Ideal car would be a stick, deluxe parchment interior and A/C.
Thanks.
Old 08-04-2009, 10:10 PM
4dblnkldude's Avatar
There is a decent 68 probably two hours northeast of you in plumsteadville. Original 350 car, not autumn bronze, but does have deluxe interior. You want a phone #?
Old 08-05-2009, 05:26 AM
Scott M's Avatar
Question
What color?
Send via PM, please.
Old 08-08-2009, 03:40 PM
1969z280 1969z280 is offline
Scott:
The following link is for my 1968 400 4-Speed Firebird that I posted on yenko.net:
http://www.yenko.net/ubbthreads/show...e/0#Post410581
Old 08-11-2009, 12:48 AM
JLHarper's Avatar
JLHarper JLHarper is offline
I was watching the Steve Martin movie "The Jerk" the other day and saw a "brown" 68 in the garage scene with Jackie Mason.
If you have seen the scene, I was wondering if thats the Autumn Bronze color?
Whatever it was, it was a very nice looking color, imo
Old 08-12-2009, 04:23 PM
JLHarper's Avatar
I saw this one while doing my daily search. I dont know the "brown" colors for 68 so thought I would post. Looks clean.
http://raleigh.craigslist.org/cto/1315154759.html
Old 11-23-2009, 11:31 PM
pontiac_banshee's Avatar
pontiac_banshee pontiac_banshee is offline
Default Almost ready to post
Here is my 1968 Project Firebird that I will be posting in a few days. RIght now here is a partial list of all the parts. I have to add more parts and tighten up the codes but here they are for now.
NR - New Restoration
NP - New Part
NPA - New Part Aftermarket
NOS - New Old Stock
If you are interested I can let you know up front and get pics. The car has just been stripped of ALL paint and the body work has been done and primered ready for paint this spring. The car had less than 40K original miles and when you look in the doors they look like a car with 20K original miles completely solid and original. The trunk had to be replaced becuase of a race project fuel cell gone bad and the from floors were rusted from the inside out so I had them replaced. Everything is super solid. Take a look at the parts that are sitting and waiting and I still have more to add. It would have been easier for me to list the parts that werent replaced but anyways here goes.
GAS TANK
Gas Tank NR
Gas Tank Sending Unit NR
Gas Tank hose to filler neck NR
Custom Tankinc.com Internal Electric Fuel Pump Assembly N
Gas Tank Straps NR
Gas Tank Straps Hardware NR
REAR BUMPER
Rear Bumper NR
Bumper Bolts NR
License plate Light NR
Bumper mounts Restored
REAR SUSPENSION
Leaf Springs (5" lift) NPA
Leaf Spring Bushings NPA
Leaf Spring Pads NPA
Leaf Spring shackles NA
Competition Engineering "Competition" traction bars NPA
Competition Engineering Rear shock mount NPA
Monroe Coil-Over shocks NPA
1972 Nova 8.5 10-bolt with 4:10 Gears - Completely gone through with all new bearings. New Richmond Gear Set - Rebuilt by Vanderlays on the east coast
Custom 10 bolt to 12 bolt cover NPA
Mr Gasket 12 bolt Aluminum Finned cover RS
Stainless Steel hex cover bolts
REAR BRAKES
Front Cadillac Rotors NA
Front Cadillac Calipers NA
ScareBird.com custom caliper Mounts NAP
Caliper Brake Hose NA
Rear Brake Hose NA
Rear brake lines NA
Emergency brake cables NPA
Emergency intermediate brake cable NOS
TIRES RIMS
American Racing T71r 15x7 15x8 NPA
BF Goodrich Radial TA's NPA
American Racing Lug Nuts NPA
DOORS
All body panels have been stripped of ALL paint, body work was completed and pre-paint primer was sprayed on.
Original (bird) factory windows.
Original door panels
Original Arm Rests
Arm Rest Pads NR
Rear mirrors NOS
Window Fuzzies Front & Rear NR
Door edge Stainless protector NR
Interior Door Handles NR
Exteriror Door Handles (Concourse quality) NR
Door light switches NOS
Door jamb vents NR
All new seals for doors NR
Exteriror
Front "Firebird" emblems NOS
Front bird emblems NOS
wheelwell trim NOS
Lower body trim panel NOS
Rear gas tank door bird NR
Trunk "Pontiac" emblems NR
ENGINE
1968 Pontiac YH 370 HP 4-bolt 428
REBUILT WITH 0 MILES
BOred .030 over with TRW forged pistons
Stock Rods with ARP rod bolts
RA oil pump
16 Heads rebuilt to factory specs with RA III valve springs
New Pushrods
Rhoads Lifters
7/16 Rocker Arm studs
CompCams Magnum steel rockers
RAM Air III equvilent cam
Double Roller timing chain
Pontiac Hurricane Intake
Butler Racing aluminum Valley Pan
GM Cast Aluminum rocker covers
Holley 850 Speadbore (rebuilt)
Holley Modified Chrome mechanical fuel pump (gutted for factory look)
Mallory adjustable fuel pressure adapter
Earls aluminum fittings and hose
Mallory Unilite distributor w/vacumn advance
Flex-A-Lite aluminum fan with extension NPA
Mini Starter NPA
flexplate SFI Rated NPA
ARP Flexplate bolts NPA
Power Steering Pump NR
Power Steering Pump Hoses NR
Power Steering pump Pully (Chrome) NPA
TRANSMISSION
1968 Turbo 400 rebuilt
B&M TransPak kit
???? 3500 Street/Strip converter
Air-Flow deep transmission pan with cooling tubes
ENGINE COMPARTMENT
MSD 6A electronic ignintion amp NPA
Hayden 17" electric fan NPA
Hayden Radiator sensor system NPA
3 Core aluminum HP radiator NPA
Factory radiator Shroud NOS
Radiator and heater hose NR
Heater Core NR
Wiper Motor NR
Wiper motor bushings NR
Battery Cables NR
Delco "nostalgic" battery cover NR
Rear Window louvers (plastic RARE) NPA
Windshield NR
Back Window NR
American WIre Custom wire harness (front to rear) customisable with additionl accesory capability built in. NPA
Factory Radio AM/FM Conversion 45 watt per channel with MP3 input NR
Pioneer 4x8 Rear speakers Speakers NR
Kenwood front dual speaker conversion NR
Rear seat devidor NR
Sun 2 5/8 classic gauges - Oil Pressure, water temp, oil temp, vacumn, volts NPA
Autometer 2 5/8 gauge angle spacers NPA
Automerter 2 5/8 Fuel Pressure gauge (liquid filled) NPA
Autmeter 2 5/8 cup NPA
Autometer Stainless braided Fuel pressure line NPA
Hood Tach (with extendted warranty) NR
Front turn signal lenses NOS
Front turn signal housings NR
Front Spoiler (camaro) NOS
Front Spoiler brakcets NR
Door sill plates NR
Rear spoiler (69 Trans AM style) NR
Fuel lines NR
Brake Lines (front to rear) NR
Transmission Cooling lines NR
Hurst Dual gate shifter (2nd generation Camaro/Firebird) NR
SHifter cable NOS
Gas and Brake pedals NR
Ignition switch NR
Dash Switch Bezels NR
Cigarette Lighter NR
Glove compartment NR
Astro Vent balls NOS
Astro Vent Pulls NOS
Dash Pad NR
Dash grip NR
Dash Bird Emlbem NOS
Steering Column joint NR
Steering wheel - Walnut afterarket NPA
Rear window mirror set NOS
Dome light bezel NR
Dome light lens NR
Seat covers - Bucket Seats NR
Seat Covers - Rear seat NR
Comes with set of Ralley II wheels (off trans am)
Engine stand
Engine Hoist with Adjuster adapter
Set of 4 wheel dollys for moving car around shop
Old 11-24-2009, 01:15 AM
Forgot to mention the complete subframe was removed and media blasted and painted with POR-15. Of course new bushings for subframe, radiator support and upper fendder support. All suspension parts were treated to the same media blasting and POR-15. THere isnt a part up front that wasnt replaced except the front link (which was solid). Includes a oversize sway bar also. It has a 1969 Chevelle front disk setup with, of course, all new parts. The restored and plated brake booster and new brake unit along with new disc/disc proportiong valve mounted right next to the new wiper motor/washer unit.
Old 11-25-2009, 09:49 PM
Scott M's Avatar
Lightbulb
Originally Posted by 1969z280 View Post
Scott:
That's not Autumn Bronze.
Old 03-15-2016, 12:33 PM
Scott M's Avatar
Exclamation
Still looking.
Brian Baker is my love slave.
Old 06-24-2016, 01:09 PM
Scott M's Avatar
Still looking.
Pump gas and hydraulic lifters are for minivans.
Old 06-24-2016, 02:23 PM
Not mine, I just saw the ad and thought of you.
http://sfbay.craigslist.org/eby/cto/5645309985.html
Old 06-24-2016, 09:15 PM
Scott M's Avatar
Exclamation
Nice car. Horrendous wheels, though.
I'd rather restore one my way.
Thanks for keeping an eye out.
Old 09-19-2016, 01:27 AM
neill neill is offline
Default 68 fb 400
see my ad, https://nanaimo.craigslist.ca/cto/5722521423.html original autumn bronze/ parchment/400/ hd 3spd/336 safety track car
69 Firebird, 462 turbo 400 3000 stall, 8.5 323 rear
Old 09-19-2016, 07:21 AM
sleddog's Avatar
sleddog sleddog is offline
Here is the Autumn Bronze. I really like this color.
https://tse3.mm.bing.net/th?id=OIP.M...=0&w=226&h=171
Sleddog,
Iowa
Humility is not thinking less of yourself, it's thinking of yourself less. C.J. Lewis
God Bless the U.S. and the people that defend it ...
Old 09-21-2016, 01:43 PM
Scott M's Avatar
Still looking.
Old 10-06-2016, 11:54 PM
1965gp 1965gp is offline
I think one was just posted in for sale section
Old 02-17-2017, 04:15 PM
Scott M's Avatar
Exclamation
Still looking.
Old 01-02-2018, 11:35 AM
Scott M's Avatar
Still looking, compadres.
