Unmachined
Notes: *raised intake runners to reduce short side radius. *reduced CSA, but larger capable size for larger engines *significant improvement on exhaust *efficient modern combustion chamber *more room for porting *11/32 valve stems instead of 3/8 *short side radius technology *significantly less bronze guide protrusion *protruded intake runner to accept stock intake location *improved spark plug location *improved water jackets to eliminate head gasket issues. *complete area for shaft or stud rockers *maintained CSA around pushrod area *OAL valves only 5.700 inches |
exhaust
Now that's solid progress!!!
Are they sand-cast? If so, that's a nice casting job. 356-T6 alloy? What "improvements" to the coolant passages?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
These heads will be available in with or without water. How many no water jacket guys out there? Lynn Last edited by NHRASuperStock455SD; 08-16-2009 at 01:53 AM. |
Lynn,
Great work, I was just chatting with a friend of yours last night about the status of the project. Calvin Hill Hill Performance 708-250-7420 Last edited by 65nss4spdGTO; 08-16-2009 at 02:12 AM. Reason: typo |
thanks Calvin, more pictures
Congrats Lynn!! very nice looking casting, any idea on production time?
Lynn,will current RA V intakes and exhaust bolt up without any mods?Tom
Are you also making an intake to work with these?
What about cam shafts? I assume a standard core will not work? They look great. Awesome to see you making progress. Do you think they will allow you to run these in SS?
68 Firebird Are you running with the wind or breaking it? |
FYI,cams are no problem,Comp and Bullet can make them.I just got one last week from comp.Tom
Will these work on OEM and Aftermarket block?
What rockers? I had no idea this project was in the works. Nice job lynn. |
Lynn |
I assume by the pics and the fact that you mention push rod bulge that the intake ports have been moved?
Nice job. I'm sure we will be seeing more RA5 GTOs and T/As
Systems under stress fail catastrophically |
Will you sell these complete bolt on or bare?
Lynn Last edited by NHRASuperStock455SD; 08-16-2009 at 02:11 PM. |
Yes and it looks awesome to say the least. It will be a single plane intake with the ability to adjust the size of the plenum based on the application desired, or hood clearance limitations. I think we might need two version, maybe a short profile version for stock hoods, but it depends on the demand for such a thing.
True, but they are available. I have worked with a couple of cam companies that are willing to give us pricing based on multiple runs. This will reduce cost of everyone going onesy twosie to the cam companies. Purchasing all together will allow purchasing advantages. Quote:
I will probably be the first to build a RA-V SS/AM car about 420 cubic inches with twin dominators.
Yes, I am doing a crate motor engine as we speak for the first dyno testing. It will be stock Pontiac block, eagle crank, eagle rods, 4.182 bore and 4.25 stroke. We will dyno with unported heads single 4 and then dual 4. We then will port the heads completely and start over. This will be with all standard street/strip engine components with stud mounted roller rockers. It will be my standard RA-V crate motor available complete or unassembled through RamAirV.com
Yes you can also use the after market blocks. Quote:
We will be sending heads to a rocker shaft company for proper sizing of shaft rockers to offer kits and searching for economy. |
Lynn |
Lynn, What should we expect these heads to flow as cast on intake/exhaust. Im sure you have done a much better job on the exhaust than the factory. Can you also include the bore size that you used on the flow bench. Thanks, Don.
