Old 09-04-2009, 12:45 PM
Schurkey Schurkey is offline
Default Oil pan interchange
From what I can tell from the forums here, it seems that the same oil pan works for all chassis.
I have a couple of "big car" pans; and I'm able to modify to accept the five-tab rear seal.
Does a '77 Firebird need a different OEM oil pan than the "big cars"?
I'd like to avoid using a windage tray that needs aftermarket main cap studs/bolts to mount it.
What OEM-style windage tray will fit a pan suitable for a '77 Firebird? 3/4??? Full-length???
Thanks, folks.
Old 09-04-2009, 12:57 PM
The pans that came on the birds had a baffle built in to keep the oil in the sump on those better handling TA cars which the big car pans did not have.
Old 09-04-2009, 02:21 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
And it didn't work all that well. I'm re-baffling mine now.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 09-04-2009, 03:05 PM
The pans are all basically the same, mounting-wise.
The scrapers all mount to the engine not the pan.
All the scrapers (factory or factory style) will fit with all the pans.
Some of the aftermarket pans may have a scraper as part of the pan setup.
Old 09-04-2009, 04:54 PM
I'd love to see photos!
Yeah, but sometimes there's interference between pan baffles and the windage tray--I had to deal with that on my Chevy. Just didn't want to take for granted that it would work with the Pontiac!
Excellent. Now I just have to locate a windage tray...
Is there a distinct preference for the full tray over the 3/4 tray?
Old 09-04-2009, 05:06 PM
Region Warrior's Avatar
The GM Pontiac parts catalog lists the same replacement part # for all models 76-81.
Old 09-04-2009, 05:26 PM
Murf'sDad's Avatar
'76 - '81 never came with a windage tray. Not even the provisions to put one on.
Stewart
Old 09-04-2009, 05:30 PM
Murf'sDad's Avatar
Here's a thread where B-Man showed me his modded pan http://forums.maxperformanceinc.com/...d.php?t=609229. The baffle I'm building is almost the same.
I have an extra 3/4 tray in great shape. I'm going with the full length tray but only because I have it.
Stewart
