Old 02-03-2010, 02:58 PM
Pontiac Performance Author
Default RAM AIR 3 CAMS
I just recieved an Elgin 909 RA3 duplicate and although the .050"dur. and .271" lift checked out, it didn't have the 30 deg constant dwell over the nose. I ordered up a Melling SPC3 and it had the same deficientcy.Any one out there have a good RA3 cam they can sell me ?
Old 02-03-2010, 07:48 PM
Formulas's Avatar
Formulas Formulas is offline
A 744 factory copy Ken ? If so i have a new one, ordered it from Warrior Racing in a engine rebuild kit, never used the cam..
Its a fat lobe cam too, which cant hurt
The exhaust lobes look right and are flat nosed. the intake lobes are flat nosed but not as much as exhaust which appears to be all correct for a 744 lobe profile.
Old 02-04-2010, 08:41 PM
I'll take it. 909-980-1451
Old 02-04-2010, 10:02 PM
lust4speed's Avatar
Ken, would you explain "30 degree constant dwell over the nose". I'm lost.
Mick Batson
Old 02-04-2010, 10:44 PM
Formulas's Avatar
Basically the valve is open at max lift the 30 degrees.. thats why the lobes look so different from other cams, the top of the lobe appears flat cuz Pontiac keept increasing duration while keeping the .400 - .410 ish lifts
Old 02-05-2010, 01:11 PM
Kenth's Avatar
Kenth Kenth is offline
The #744 needs at least 125lbs valve springs closed or valve float WILL occur.
Using STD 90-100lbs valvesprings with this cam and the engine stops pulling at or just over 4000rpmīs.
Old 02-05-2010, 06:44 PM
Just heard from the Co. that makes Melling's cams-EPC-and they said they don't claim to make fact. dupe cams. But, I said, The Melling cat. sez it's a dupe for the RA3. EPC sez " there's the problem". I think Melling thinks they are getting a 744 but nobody is checking.
Old 02-05-2010, 08:12 PM
73T/A 73T/A is offline
Ken,I recently had a similar issue with a Melling SPC-8(041) cam.We were degreeing the cam with Cam Logic equipment and also checking the cam specs.The lobe lift was just as advertised .313 but the intake and exhaust durations were not as advertised.We then picked up a second new Melling SPC-8 and the readings were the same as the first one.I then called Melling tech and told them about the issue.They stated that I could mail them the cam and they would check it.I never did send it though.It was my understanding that CMC(Camshaft Machine Company) in Jackson,Michigan ground most if not all of the flat tappet cams be it Melling,Comp,Edelbrock etc.Both of the Mellings had CWC(CMC upside down on them) stamped on them.
2001 Trans Am,WS6 Sunset Orange Metallic (sold)
1973 Trans Am 455,4speed
1970 GTO
Old 02-05-2010, 08:35 PM
straycat's Avatar
straycat straycat is offline
So how long ago did Melling cease manufacturing cams?
Old 02-05-2010, 11:09 PM
Camshaft Machine Company used to make most of the factory "Low Volume" camshafts.
W-30 & W-31 camshafts, RA III, and RA IV cams, Z-28 camshafts, LS-6 and LS-7 (054)
cams, Ford camshafts, etc.
CMC was bought by Crane Cams years ago. After Crane got into trouble CMC was sold as well as the Wolverine Blue Racer cam retail business was dropped.
At one time CMC sold millions of camshafts to most of the other vendors and the cams were reboxed: Isky used to have a cartoon about cams coming into the back of a camshaft business and being reboxed as the performance cam companies "unique" camshafts. He would send you a list of all of the reboxed cams and their sellers.
Tom Vaught
I can find out what the CMC people are doing today with Pontiac cams.
Old 02-06-2010, 06:31 AM
Kenth's Avatar
CWC is the foundry, CMC is one a grinder of many.
http://www.industrynet.com/results.asp?headers=CA0705
The CWC foundry in Roosevelt Park once was part of the Campbell, Wyant & Cannon Foundry Co., founded in 1908, that employed thousands at various plants in the area during the middle of the 20th Century.
The present CWC Textron camshaft-making operation is housed in what once was known as "Plant No. 5," built in 1945. Camshafts began to be made at CWC's Plant No. 3 on Henry Street in 1936, but the camshaft work was based in Plant No. 5 in 1955. CWC was bought by Textron Inc. in 1956.
CWC Textron is a leading supplier of camshafts and camshaft technology to the global motor vehicle engine market.
Alloyed gray iron and ductile iron camshafts made at CWC Textron are running in tens of millions of cars and light trucks around the world. The camshafts are in cars made by General Motors, DaimlerChrysler, Ford, Honda, Toyota and other auto companies.
The workers at CWC-Textron annually produce millions of camshafts.
F.e. #540233 is the, 1961 and on, cast cam core used by many "manufacturers" for "their own" finished product, incl. Pontiac.
ID-#īs is stamped in front. 1 letter or 1 digit or at the back usually a lot of letters and digits. There is also colour codes on the camshaft in front and rear.
Old 02-06-2010, 07:32 AM
Me Notyou's Avatar
Me Notyou Me Notyou is offline
So who makes the right stuff now?
Denn die toten reiten schnell
More doors = more love!
Old 02-06-2010, 08:05 AM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
Ken,
Seen this?
http://cgi.ebay.com/ebaymotors/GTO-p...Q5fAccessories
Stu
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
Old 02-06-2010, 11:11 AM
FWIW,the Melling SPC-8 cam's that we checked had a Melling SPC-8 label along with a WG1014 number on the box.The WG1014 is the Wolverine/Blue Racer part number for the 041 cam.
1970 GTO
Old 02-06-2010, 11:46 AM
The two businesses Melling and CMC are with-in 1/4 mile of each other and the families have worked together for years and years.
Great Info on the CWC company. I wonder if CWC casts up the oil pump bodies for the Melling oil pumps?
More Camshaft History: http://www.engineproparts.com/Crane_Detail.htm
Tom Vaught
ps The problem is that most of these companies have been supplying each other for years and years and you don't really know who is actually making the whole deal themselves. Most likely it is a group of companies putting together a final product like an oil pump. Cover from one company, body from the same or different company, gears from a different company, spring from peterson spring, shaft from a shaft company, etc.
Old 02-06-2010, 02:21 PM
Cliff R's Avatar
Cliff R Cliff R is offline
A little over a year ago, we attempted to get CMC to reproduce the WG-5059 camshafts for Pontiac engines. I was given a direct contact number to a representative from that company. After many left calls and attempts to get a live person on the phone, I gave up on the idea. They must be "fat, dumb and happy" at CMC, because they don't even have the intiative to try to drum up any new business. They had no idea if I wanted 10, or 10,000 of those cams produced? Not a single phone call was ever returned to us. That sort of attitude by an American Company doesn't surprise me at all. I run into it ALL THE TIME trying to get parts made. Some woln't even talk to you at all, and hang up on you unless you want at least 10,000 pieces a month.
Cripe, I can go offshore, the Chinese will make 100 of anything I want, at a tenth the price of any American Company!....FWIW......Cliff
Old 02-06-2010, 03:45 PM
Curly Joe's Avatar
Curly Joe Curly Joe is offline
Arrow another e bay
http://cgi.ebay.com/ebaymotors/Ponti...Q5fAccessories
"Chief" Knucklehead
462 E Heads Solid Roller 91 Octane Nash Stick
Old 02-06-2010, 05:34 PM
Formulas's Avatar
Curly that one looks incorrect. the lobes have to much peak to them.
At least from what i can tell from a pic. i did save it to desktop and then made it bigger to look at..
Its not the hot ticket of a cam anyways unless your going correct resto.
I should of taken a pic of mine..didnt think of it..
Old 02-06-2010, 09:56 PM
I agree!
The "flat nose" on a true RA-744 cam is obvious with the naked eye.
Tom Vaught
Old 02-06-2010, 10:04 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I was thinking about asking Lanier Henry who is a part owner/partner (or damn good friends etc) with Schneider Racing Cams. They are grinding me a cam now FWIW...
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
