Old 02-18-2010, 12:42 PM
ccie3611 ccie3611 is offline
it looks like that...
ID:	197716   Click image for larger version
Old 02-18-2010, 01:43 PM
2manyT/A'S's Avatar
WOW!
That is the car that MOST of us here DREAM of finding (make mine a stick with Honeycombs)
AMAZING.
Correct me if I'm wrong but I don't see one bit of aftermarket CRAP anywhere on it.
Nicely optioned & documented.
Have you gone looking for the build sheet yet?
If/when you find it,will you photograph location/placement for us before removing?
What are your intentions?
If you keep it,hopefully you will maintain/detail it as the original/survivor that it is.
Just went back for a close look at your pics.
I spotted the "corvette" plug wires.
Does it have the optional unitized ignition?
Also note the lack of bright pedal trim on brake/gas pedals.(I believe the bright trim was standard on early secondgen Esprits & became part of custom trim in later year T/A's)
Notice the body colored inserts in outside door handles? (standard with custom trim)
Spotted replacement LF sealed beam.
Is the RS still original Powerbeam?
GREAT FIND!
How about posting some chassis pics?
Old 02-18-2010, 02:02 PM
thanks 2manyT/As - i agree on the stick but hey how many survivors are there out there :-). i do have a 72 with an m22 that i'm restoring right now, its blue/black just like the survivor. (and yes! its very convenient to just walk over to the survivor every time i have a question about what is correct)
It is bone stock nothing added nothing taken away.
I plan on finding the build sheet this spring (i'm suprised at myself that i haven't already done that - ha!)
It would be a crime to restore this car, i intend to drive it now and then and do only what is needed to keep it running and safe to drive.
Old 02-18-2010, 02:15 PM
it does have unitized igintion, the previous owner took the ends off the wires so he could slip on the heat protectors on the wires to help preserve them (i realy didn't like that) - unitized wires are very hard to find - however i do have a nos set with 71 dates.
Old 02-18-2010, 03:28 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
that car was about 10 miles from where I sit here at my work, amazing how they are out there and you never know when or where they will turn up. Is the car still in Texas? some more underhood detail shots would be good if you can post them since the car is so close to an untouched original
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 02-18-2010, 03:30 PM
yes - i live in Flower Mound
Old 02-18-2010, 03:47 PM
RicksGTO's Avatar
I work in Flower Mound and Lewisville, let me know if you ever have time to show the cars off, would love to meet you and see both of those '72 T/A's!
Old 02-18-2010, 04:38 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
What a GREAT find. Love the Lucy Blue T/A.
Congrats!
Regards,
"455HO" Lloyd
Old 02-18-2010, 04:40 PM
few more misc pics
ID:	197724   Click image for larger version
ID:	197725   Click image for larger version
ID:	197726   Click image for larger version
ID:	197727   Click image for larger version
Old 02-18-2010, 04:50 PM
Lloyd-TX's Avatar
Originally Posted by ccie3611 View Post
blue71ta - yes it has an interior like i've never seen. the inserts in the seats and doors are a very soft cloth. i did some research and found that the cloth is called "potomac", it must be a very rare option.
The Potomac Cloth seat inserts and door panels are VERY rare indeed. Don't have access to the numbers, but VERY few T/A's were so ordered.
Regards,
"455HO" Lloyd
Old 02-18-2010, 04:56 PM
and believe it or not, both my 72 TAs have the potomac cloth interior, verified with PHS. its just luck that the two 72s i found had it. the 72 i'm restoring took a long time to find, i specifically wanted a 72 blue with black interior and a 4speed all numbers matched, i bought it about 5 years ago at that time i had never heard of that option.
Old 02-18-2010, 04:59 PM
7072PMD's Avatar
7072PMD 7072PMD is offline
i have noticed throughout my various cars dealings that the black seats hold up better that blue, white....etc. and yours look real nice. you must have the YB block if equipped with unit dist. can you take any pics of the carb area showing the various surrounding vacuum lines, this has to be done with the air cleaner off of course. thanks
Old 02-18-2010, 05:01 PM
Lloyd-TX's Avatar
Thumbs up
NICE!
Matching Lucerne Blue '72 T/A's, both with black cloth guts. One M22 and one M40.
WOW!
PS - is your M22 T/A an A/C car also?
Regards,
"455HO" Lloyd
Old 02-18-2010, 05:03 PM
Lloyd-TX's Avatar
OP posted a pic of the "YB" block code earlier.
Regards,
"455HO" Lloyd
Old 02-18-2010, 05:04 PM
yes, it has the delux interior, A/C, back seat console, 8 track. (talkin about my other 72 here not the survivor)
Old 02-18-2010, 05:12 PM
never noticed it before but the hard fule line has been replaced with a hose - hmm..
ID:	197731   Click image for larger version
ID:	197732   Click image for larger version
ID:	197733   Click image for larger version
Old 02-18-2010, 05:23 PM
CaptCrunch CaptCrunch is offline
I cant believe the paint on the engine held up so well..........
  #38
Old 02-18-2010, 05:27 PM
i think the previouse owner repainted it (in ther car) but i'm not sure, maybe pontiac paint will hold up.
  #39
Old 02-18-2010, 05:40 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
...Why is there BLUE OVER SPRAY on the inside of wheel well..?? is this suppose to be there..??
  #40
Old 02-18-2010, 05:42 PM
Lloyd-TX's Avatar
Argh - just noticed that the "unobtanium" correct rear upper A/C compressor bracket is missing.
Dunno if your M22 car has the correct bracket, so here's a couple of pics of the correct HO bracket on my Formula . . . As you can see from these pics, the correct bracket is "scalloped" to clear the passenger side air cleaner snorkel pre-heat tube.
Proper repro hard fuel line from pump to carb is available from PY, and fits well.
ID:	197737   Click image for larger version
ID:	197738   Click image for larger version
ID:	197739   Click image for larger version
Regards,
"455HO" Lloyd
