Don't think I agree with that - You can still have a lean idle with a big cam. You are correct that very rich conditions will dilute the oil, but a rich idle isn't a given parameter of a tight lobed cam with a large overlap. I'm sure that there are a bunch of engines out there that fall all over themselves because of a lousy tune, but they also really sound unhealthy. A true ground pounder tuned correctly creates vibrations clear into your soul.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Actually it was strapped in the front and rear.
[email protected]'t remember the tq off hand but it was less than 500.I was expecting more from this size engine and cam.And more rpm.Not much of a power curve either,more like straight up then back down.
Run your 290b with 1.65 rockers with a set of SD KRE 290cfm heads you will have same idle more or less with high ten potential.Get some due on here to run a duno simulation....I forget what it is but I'm sure it is in the 550 to 600 hp range at around 6000rpm depending on rocker ratio.
My mistake, I guess I didn't see it in the video. I didn't think anyone would chance it though.
Anyway like I said nice car and I hope to have another 65 someday myself. |
I wonder if the two-roller dyno unit had anything to do with torque being down compared to horsepower? The old Clayton dyno's had a hard time with wheel spin due to the small rollers and it wasn't unusual to have three guys sitting in the trunk during the run to provide extra traction. Could you post the results?
Ditto lust "clear to your soul"
MudBird |
When guys say they have a large or big cam they always refer to duration it seems.My car has large lift for a street cam in the .650's but smaller duration compared to many at around a 230/240 @.050.I wouldn't say it has a nasty idle as in rough but it sure trumpets out the back especially if its idling in park.
IMHO The car sounds great with the 290b cam! Your not going to change the impression of the average person by trying to make the idle rougher. What does an engine with the Comp 300b sound like? I think thats the part #, the one bigger in the catalog. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
I wouldn't run the engine improperly tuned for the sake of a rough,racy idle.Performance comes first,if it sounds like a 10 sec car then it has to be able to back it up.
What pushrods?? Stud girdle??? The 290b6 should pull strong to 6000+ no problemo. Also,was that cam degreed when it was installed? With the 6X heads and the compression your running,you really dont wanna go any bigger than that 290b6 cam. Also,what sorta exhaust are you running,tight LSA cams absolutely abhor restrictive exhaust tracts,a restrictive exhaust system can cost big chunks of power with the tight LSA cams. Can be lots of reasons for what your seeing,just gotta work thru the usual suspects in a logical way to eliminate any & all possible issues,it's a process,and it can be tedious at times,but you gotta expect to put in some work to reap the gains. As for a SR cam to replicate the 290b6 when you upgrade the heads,here's my choice: Brand & part no.:Comp custom high tech .420" SR lobes #51-000-5 Grind & lobe no.: AKA: the 290b6 roller "clone" cam. ( lobe # 4009/4023) Tappet type: Solid Roller Tappet Spec = intake/exhaust: (notes) Adv.duration = 290°/304° (I/E split = 14°) (note: rated @ .020") Dur. @ .050" = 254°/266° (I/E split = 12°) Dur. @ .200" = 171°/180° (I/E split = 9°) Lobe lift = .420" Lift @ 1.5 rr = .630"/.630" (Gross lift) (To get Net lift subtract lash below) Lash = 106° LSA = 106° ICL = 106° ECL Seat events: IO = 39° BTDC IC = 71° ABDC EO = 78° BBDC EC = 46° ATDC OL = 85° Events @ .050": IO = 21° BTDC IC = 53° ABDC EO = 59° BBDC EC = 27° ATDC OL = 48° Compare that to the 290b6: Brand & part no.: Comp Cams Part no.51-659-5 . (catalog grind) Grind & lobe no.: Grind no.290b6 (lobe #6061/#6013) Tappet type: Solid Flat Tappet Spec = intake/exhaust: (notes) Adv.Duration = 290°/304° (I/E split 14°) (note: rated @ .020") Dur. @ .050" = 255°/266° (I/E split 11°) Dur. @ .200" = 160°/172° (I/E split 12°) Lobe lift = .360"/.356" Lift @ 1.5 rr = .540"/.534" (Gross lift) (For Net lift subtract lash) Lash = .026"/.028" LSA = 106° ICL = 106° ECL = 106° Seat events: IO = 39° BTDC IC = 71° ABDC EO = 78° BBDC EC = 46° ATDC Total O/L = 85° .050" events: IO = 21.5° BTDC IC = 53.5° ABDC EO = 59° BBDC EC = 27° ATDC O/L @ .050" = 48.5° Does'nt get any better/closer than that! What's the diffence you ask??? Look at the additional lobe lift and the .200" duration numbers and you'll see. ![]() And that SR cam will absolutely love better flowing heads!!! But I'd definitely work with the current combo some more before making that leap. ![]() Sooner or later though,those trips wont be able to keep up. Bret P. |
Pioneer pshrods 5/16.I cant find the length.I had to get longer than stock because the lifter plunger was down in the body further than on the comp lifters that i was using with previous cam. No stud girdle.Comp guide plates,7/16 studs. Cam was not degreed.I'm suspecting this 'could be' a contributing factor.I run an E-brock geardrive with a 3 keyway crank gear.VERY hard to see the lightly stamped markings for +4,-4 or 0.There is a good chance i might have used the wrong keyway and installed it 'retarded' *4. It does pull to 6000 and beyond with no problem,it just stops making power at 4900. I'm replacing my 1-5/8 headers with 1-3/4. I run 6x heads to keep a 'stock' look and i didn't have money at the time for alum.heads.I think to get low 11s/hi 10's the KRE heads would help a lot. |
Jim LeHart (Mr P-body) has had very good sucess with the 290-b solid flat tappet cam. His recipie in 6X-8 heads with Comp Magnum 1.65 rockers is 150 seat pressure at 1.600" installed height, 340 lbs open. Valve size, 2.110"-5.095" long.
A fwiw, if and when the time comes and you change push rods and are using 5/16" upgrade to a thicker wall section rather than the typical .080"-.083" diameter. Manton 0.118" wall is a good one. Also Smith Brothers. |
#38
Absolutely power lurking in that exhaust IMO. IIRC my suggestion was for headers with bigger primaries,I believe I suggested 1 7/8" with 3.5" collectors as what I would prefer to see on there,but agree going to the 1 3/4" x 3" headers is better than what you have. I'm gonna be using 1 3/4" x 3" headers (hedman) on the 400 for my '70 Lemans/GTO race car with a very similar custon Crower solid cam (hell the back-up engine I'm building for that engine has a 290b6 ready for it),and even with what,50 some less cid I feel that size header is marginal @ best,the only saving grace to my situation is what exhaust there is will be 3" all the way back to the dumps in front of the rear axle. And yeah,I'll bet $$$ that your cam is installed advanced,probably quite a bit. And I'd put some stiffer pushrods in there,the pioneers are likely .065" wall,and I feel .080" wall chro-moly is the minimum,and the .118" wall pushrods are even better. I'd also think long and hard about adding the stud girdle too. Most combos like yours with solid cams like that peak right around or just over 5500 RPM. Also,the chassis dyno sheet you posted showed it was a mustang dyno,and I have heard thru the grapevine that those can give hit or miss results for some,but somebody else like Harry K. would probably know a lot more about that than I do. Oh yeah,the rwtrq was much healthier than the hp that was for sure,I think that was like 486 peak lb/ft @ the wheels,and something like 390 lb/ft average on the best run. So that too makes me think the cam is installed advanced past what's recommended as well. The KRE heads are always a worthy consideration when looking for more power than stock heads are typically gonna make,I'd get 'em thru SD if I were looking to buy,those guys do real good work. Gotta go,finishing up my ignition panel installation/mock-up in the race car,and I'm burning daylight,then I shift to messing around in the garage working on misc. stuff for either my '72 firebird street car,or my brothers '68 S code 390/C-6 Ranchero GT. ![]() Bret P. |
#39
Thanks.Yes you have answered the same questions a few times for me.I WILL degree the cam,even if its 'on' at least i will have eliminated that as a problem.Not sure if i can fit headers bigger than 1-3/4,my 1-5/8 are tight in places.
I will call SD for heads. |
#40
Though often one tube on each side gets re-routed around/over a frame rail to make that happen,and the primary tubes themselves are a "slip fit" into the collector,also these sorta headers typically use a sub-flange on the head that repositions the flange bolts,so that inturn eliminates the hassle of trying to get to "that bolt". Most folks that use these sorta headers swear they'll never go back to the "traditional" style of headers. I'd likely be talking to Mark @ maddog myself. HTH Bret P. |
