Old 04-14-2010, 11:09 PM
ELKHORNAOG7 ELKHORNAOG7 is offline
Question converters from years ago
Years ago you had a drain plug on the converter with the converters of this day and age there is no plug, can a bung be welded on the new ones and a drain plug be installed so the converter can be drained------BOB
Old 04-14-2010, 11:24 PM
guccieng's Avatar
guccieng guccieng is offline
wouldn't that adversely affect the balance?
John J.
Old 04-15-2010, 09:35 PM
SRR's Avatar
SRR SRR is offline
The only drain plugs I ever seen were on MOPAR's.
― Calvin Coolidge
Old 04-16-2010, 12:51 AM
lust4speed's Avatar
I think the drain plugs on the converters were like the cast iron trans cases and other things that were not worth the effort and expense. If a trans goes, then you are going to throw away a cheap converter or pay to have a good converter cut opened and professionally rebuilt. So the plug is pretty unnecessary on a regular oil change and worthless on a major rebuild.
Mick Batson
Old 04-16-2010, 01:23 AM
WDCreech's Avatar
WDCreech WDCreech is offline
You could get a bolt together, and problem solved. I have two Chance bolt togethers and, on occasion change the stall.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 04-16-2010, 11:22 AM
TransAm525 TransAm525 is offline
You can drill and tap your converter with a very small Allen plug. Just pack the drill bit and tap with grease to catch the metal shavings, allow the fluid to drain, then plug. Be sure to use a thread sealant or fluid will leak past the threads when the engine is running. The procedure isn't really necessary unless you are swapping to full synthetic transmission fluid, or draining burned fluid (in which case a transmission rebuild is probably warranted). Any balance issues will be negligible as long as you use the smallest plug feasible. The procedure is outlined in various GM and Haynes manuals if you need a reference of where to drill.
Old 04-16-2010, 03:39 PM
What do you mean by bolt together,is this a converter--- or the fluid coupling from years ago-- who makes them so I can look them up and read about them------BOB
Old 04-16-2010, 03:55 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Ron Sessions' book details how to do this to drain a torque converter without removing it. I personally cannot see a reason to drain the converter as if I need to get bad fluid out usually the transmission is going to get rebuilt anyways which means new converter.
Old 04-16-2010, 04:30 PM
I can: I bought a 12" Continental converter and would like to get the Amsoil synthetic out of the old D5 converter before switching over.
Old 04-17-2010, 10:18 PM
Can anybody else also tell me some thing about this bolt together ---BOB
Old 04-17-2010, 10:30 PM
goatless's Avatar
goatless goatless is offline
High-end racing converters. Scroll down on the link-
http://www.racingconverters.com/converters.html
1966 GTO
Old 04-18-2010, 01:06 AM
WDCreech's Avatar
If you get a Chance bolt together and want to change the stall, call Marty Chance and he'll walk you through it. He's a heck of a nice guy to work with. Great customer service!
Bill
Old 04-22-2010, 08:36 PM
jdb jdb is offline
Default drill and tap
I worked at a transmission shop for an eternity, when rebuilding transmissions the majority of rebuilds needed new converters but on occasion we use to drill/tap and flush out converters IF end play, hub and stator checked out ok.
