The TH400, were you putting it in low gear during the burnout? A 200-4R will hold low usually, but if you are leaving either unit in drive, it will shift through the gear during a burnout. 200-4Rs don't seem to have excessive converter charge that kills thrust bearings like a TH400 can. I test the 200-4Rs in my test vehicle all the time and converter charge pressure is usually 15-40 psi, not 70+ like some TH400s will have.
www.jakesperformance.com Racing Automatics and LSx Engine components |
I greatly appreciate your response. I did have the th400 in low when I did this. I cannot put the th2004r in 1st yet because I still need to modify the original column linkage to drop down that far. It will go to 2nd but not 1st. Years ago had to grind a little off the stop on the column to get the 3 speed to work with the 2 speed column, guess I will have to do this again. If I decide to go with the billet drum (already have the servo) can you sell me the part and I have a local shop install it, or would I have to ship you the unit? Seems to run very well, hate to remove it at this time. I may take it easy on it and ship it over the winter. Dont want to ruin anything if you think 500lb ft is too much.Again, thanks very much.
The CPT unit may have heat treated parts. Run it until it breaks.
I can sell you a billet drum but you may be OK if that heat treated drum is as good as Art says it is.
Considering the cost to upgrade to an OD trans or Gear Vendors, you might consider upgrading the TH-400 with a low gear set and dropping the rear gear ratio back to 2.73-3.08. About the same on the starting line with lower rpm's for "normal" driving, etc.
A LOT less money and still excellent street performance with lower cruising RPM's....Cliff
