Old 10-21-2010, 08:18 PM
bankbook's Avatar
bankbook bankbook is offline
Talking CV-1 Turbo track outing today!
Ok so here it is.
Went to track for 2 reasons.
1. test and tune
2. Get licenced
Was able to make 4 runs before track was shut down for rain delay.
First run was to the 330 mark and shut down( to license)
Second 1/2 track
2 3/4 track runs as follows
1st-11.0 at141mph
Ran a 10.0 at 135 mph
Then lined up to get out of the tens, making the two 9 second and below license runs... and then the rain hit. Damn it!
Oh yeah that was only on 4.5 pounds of boost!!
The car hooked pretty well, as I was both on the foot brake and t brake.
I need another day to get the carb and electronics dialed in the way it needs to be.
This set up has more than enough power to set it deeep into the 8's for sure.
I am trying to get some of the videos posted up. Stay tuned.
I am truly impressed and happy with the performance of the car today. When that turbo kicks in it's like a 300 pound weight pushing you into the seat. G forces are addictive.
Turbo, turbo, turbo!!!
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 10-21-2010, 08:32 PM
quick66's Avatar
quick66 quick66 is offline
Congrats....sounds like your making serious power...keep us posted...Gene
'66 GTO 3600lbs w/driver, e-heads,474 N/A . best 60' 1.305...best 1/8th ...6.205 @ 110.14...best 1/4 9.794 @ 136.15 through mufflers on e-85
Old 10-21-2010, 09:07 PM
Hope you can get the rest of your runs in soon. Wonder what 10 psi is going to be like. Thats going to be a fun ride dont forget toilet paper!
Old 10-21-2010, 09:15 PM
Ron H's Avatar
Ron H Ron H is offline
What were your 60' and 330 incrementals on the 10.00 134 run?
Is this a Cal trac car?
Good thing you have alot to feed the power/speed addiction for awhile!
68 Firebird
Are you running with the wind or breaking it?
Old 10-21-2010, 09:25 PM
bankbook's Avatar
60ft--1.681
330-- 4.340
1/8-- 6.463 @ 114.50 mph
1000ft 8.406
1/4-- 10.0 135 mph
Let me know what that all means. lol
DOC'S TA
Both 4 speeds!
Old 10-21-2010, 09:53 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Great job but you have along way to go before you will ever see low 8's.Not saying it's not possible but 1,400 hp to the wheels is what you need at that weight. Trust me it's not easy.Good Luck I will be cheering you on.
walterd walterd is offline
Interesting increments, last weekend I was running a 150 shot, 461 e head, 3600 lb
60 1.525
330 4.189
1/8 6.443 109.23 MPH
1000 8.412
1/4 10.086 133.90 MPH
Looks like your setup was pulling harder for sure!
Old 10-21-2010, 09:54 PM
R 70 Judge's Avatar
Originally Posted by bankbook View Post
60ft--1.681
330-- 4.340
1000ft 8.406
10.20 @ 141
Killer set up BTW! You're making me wish I followed through with my turbo project.
James
1970 Trans Am
Old 10-21-2010, 10:01 PM
bankbook's Avatar
Thanks,
Oh I agree totally. There is enough Hp to handle it with the boost turned up. But that is along way from today. Just fun getting back on the track.
Remember that I lifted and coasted through way before the end of the traps.
DOC'S TA
Both 4 speeds!
Old 10-21-2010, 10:03 PM
bankbook's Avatar
Nope, stock suspension with South side machine bars and the exception of moving the shocks inboard. Contemplating the options for over the winter.
DOC'S TA
Both 4 speeds!
Old 10-21-2010, 10:22 PM
That would help alot Robert.Maybe a mini tub
Old 10-21-2010, 10:27 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
sure it felt great to finally make some passes... definately is going to run really strong. now turn that boost up would you!!!!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 10-21-2010, 11:49 PM
R 70 Judge's Avatar
Originally Posted by Gach View Post
I thought it said Ran a 10.0 at 135 mph
That's what the calculator said according to his 660' and mph.
James
1970 Trans Am
Old 10-22-2010, 12:07 AM
badassgoat's Avatar
badassgoat badassgoat is offline
Had fun today Rob. Good to see you making passes in that beast for a change instead of ripping it apart and rebuilding it! Sorry I had to bail early. As it turns out, I could have stayed longer and seen the real passes. My daughter's friggin flight was delayed an hour and she didn't end up showing up till almost 7 PM instead of 5! Grrrrrrrr. It was good to be at the track and smell some burnt rubber and c16. Hopefully, next time we can both be laying down 9 second passes or better...
69 'Blackbird'
535 CID IA II SD Wide Port E-head Pro Systems Dominator
Old 10-22-2010, 09:33 AM
bankbook's Avatar
Here is an I pHone video of the 10 run.
Notice how easy I launched it. Listen to the turbo "whistle".
http://www.youtube.com/watch?v=RmlrubLOYX8
DOC'S TA
Both 4 speeds!
Old 10-22-2010, 09:57 AM
X72GPX's Avatar
X72GPX X72GPX is offline
Send a message via AIM to X72GPX
Nice!!!!!!!!!!!!!!!!
Old 10-22-2010, 10:21 AM
ponjohn's Avatar
ponjohn ponjohn is online now
You're making some serious power. Good luck!!
What does the cage consist of?
Old 10-22-2010, 10:37 AM
Gach's Avatar
Gach Gach is offline
She is cranking..nice real nice.
Old 10-22-2010, 10:45 AM
bankbook's Avatar
10 point certified for 8.50
Weld in sub frames.
DOC'S TA
Both 4 speeds!
Old 10-22-2010, 11:03 AM
rumair rumair is offline
get the 60' down to the 1.40's and you should be in the 8's no problem.
