Old 10-22-2010, 12:26 PM
steve's Avatar
steve steve is offline
aha ! i am not as crazy as i sound !
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 10-22-2010, 12:31 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
I have a 73 400 virgin Block & Crank std , cleaned ready to go.If anyone is interested.
Old 10-22-2010, 12:35 PM
steve's Avatar
northern canada !
Old 10-22-2010, 01:11 PM
Region Warrior's Avatar
Only 1 more, and i'm DONE!...well maybe 2...
If gon'a build just "one" for street.
I vote out 67 blocks unless your gon'a use 67 hds, or bore out large enough to remove most of the cylinder chamfers for 68 and up heads. Maybe not that big a deal???
Other then that, any 68-74/78-79 "X" blocks.
"N" crank. Why didnt GM use'm the 78-79 "X" engines? Anyone???
King bearings(local spd whrhse stks them at good price).
60lb Melling select o/p and hardened shaft.
16, 62, 13, 96, 6X-4 hds.
12's and 48's i've seen where less then 72 cc. But if you want to enhance the cb while reducing cr. 670's are sweet for enhancing flow...
SRP pistons and "Ace's" forged rods.
Somewhere round a 744 cam spec cam or 230-240 range.
Highest ratio rkr arms and have cam ground from there by Bullit.
A GOOD link style chain. Still look'n for better one myself.
68-70 intake with 76-79 carb.
Long branch mans w/2.5" exh. 2.25 from muffs.
71-79 acessaries as lond as have matching setup.
Old 10-22-2010, 01:13 PM
BTY, i have a good extra 69 block with N crank been save'n jic.
May be able to talk me into sell'n.
Old 10-22-2010, 02:22 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
You pretty much described my engine. Except for the block.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 10-22-2010, 03:15 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Originally Posted by chiphead View Post
I should buy a lottery ticket then. I've found two early 400s (one complete runner, one a checked block) for $100 each. STD bore, never blown up. One of them is my current engine.
Agreed only as crazy as chiphead! LOL I'm not buying the idea there are any "Stock/standard" bore 400's with a useable cylinder after 40 yrs. especially for $100. If you can find these blocks at "Welfare" prices you better buy as many as you can find because it will fund your retirement on the resale. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 10-22-2010, 03:28 PM
taff2's Avatar
taff2 taff2 is offline
I recently had a bit of luck, I picked up a '72 455 motor complete which had supposedly been rebuilt before being stored under the bench, when I called to pick it up the guy gave me a pallet full of Pontiac bits including a 3" mains 455 N crank,a nos set of MT ali rods,TRW pistons ,mini starter,Mallory dizzy etc and loads of stock bits-timing covers,6x heads,400 block etc. When I inspected the 455 it has HS roller rockers,Moon timing cover,7H1 heads converted to big valves,TRW pistons etc,all old school Pontiac but still well worth the £500 ($750) I paid! The worst thing though was when he said that I could have also had the TEN Pontiac blocks that he had recently thrown in the dumpster 'cos he was fed up of tripping over them
Old 10-22-2010, 04:22 PM
Stewart
Not nessesary a bad thing. Which one do you have?
Old 10-22-2010, 04:23 PM
steve's Avatar
see that ! another log on the fire ! dreams can come true.....
Old 10-22-2010, 05:11 PM
Murf'sDad's Avatar
Mine's a '76 557 block, .030" over with SRS pistons and Ace's 4340 ultralite rods, re-balanced. The rest is in my signature. I can't see any problems with the 557 block at the rpm level I'm running with the seriously lighter-than-stock reciprocating assembly.
Stewart
Old 10-22-2010, 05:51 PM
I agree on your build MD. Shouldnt be a prob.
But what do i know. Only mess'n with them since i was about 10 yrs old...
DAM, just realized how long its been since the 1st time helped my father on his 57 Super Chief around 65.
And my older brother from 68-75.
Old 10-22-2010, 06:02 PM
steve's Avatar
That makes you close to 55 ? You got 15 on me and probably 35 more on me in Pontiac/car experience. I'm listening.....
Old 10-22-2010, 07:38 PM
Murf'sDad's Avatar
Sounds like we are close to an age.
A story from an old boss: An incident happens in a city, a chase is underway. He hears the call and, off duty, responds. Pulls down on a car and they stop. "Why did you stop?", asks the officer. Response was, "Young guys are pussies, old guys will fcuking' kill you, that's why we stop".
Old guys rule. Never forget that an old guy is just too tired to mess with you and doesn't need the aggravation. You will die!
FWIW, Stewart
