Old 12-29-2010, 11:39 PM
quick66's Avatar
quick66 quick66 is offline
Seeing Ron Genovese's 66 inspired me to post this pic. I was at my local track for a funday sunday and met a guy named Sam from Missouri... He took the photo and e-mailed it to me when he got back home . The miracle is that I got staged next to my friend ,Tony with his '63...and I think we were the only two Pontiacs (vintage) on the property....Gene
'66 GTO 3600lbs w/driver, e-heads,474 N/A . best 60' 1.305...best 1/8th ...6.205 @ 110.14...best 1/4 9.794 @ 136.15 through mufflers on e-85
  #382
Old 01-06-2011, 10:59 AM
PN's Avatar
PN PN is offline
Default cecil 12/11/10
last run of the year....the stands were packed!.... only managed 8 runs all year! maybe I will make it to a pontiac event in 2011...
ID:	230001   Click image for larger version
ID:	230002   Click image for larger version
Ultrastreet / Real Street 275 65 GTO
570 IA2 Tiger Head/Single Carb NA
4.79@144, [email protected] - 2900#
Thanks to: Uratchko Racing Engines, John Marcella, CFM Performance, Allpontiac.com, BOP Engineering, PTC
  #383
Old 01-06-2011, 11:43 AM
TOP 452's Avatar
TOP 452 TOP 452 is offline
Send a message via Yahoo to TOP 452
NOT BAD FOR A BEGINER.!!!!!!!!!!
Don
  #384
Old 01-06-2011, 05:30 PM
wreckmastr's Avatar
Nice Car!
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #385
Old 01-06-2011, 05:47 PM
andrewT's Avatar
andrewT andrewT is offline
bada$$ ride you got there man!
  #386
Old 01-06-2011, 07:27 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Cool
X2 .
  #387
Old 01-06-2011, 08:34 PM
wim firebird's Avatar
wim firebird wim firebird is offline
Lelystad, The Netherlands,2010
  #388
Old 01-06-2011, 08:45 PM
dda72's Avatar
dda72 dda72 is offline
Awsome Ride PN! Look forward to seeing you in 2011.
  #389
Old 01-06-2011, 09:34 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Awesome job John, did you change anything from when I saw you at Cecil in July?
[email protected]. 3460#s
  #390
Old 01-06-2011, 11:00 PM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
awesome!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,([email protected])1.578 60' Oct 2010!!
  #391
Old 01-06-2011, 11:11 PM
Here is my 'bird with the little engine in it... Top pic is from 2008 Oct.... first run on engine.... bottom pic is from Sept 2010...decided to go the ''stock'' look
Name:	bird dogdish.jpg
  #392
Old 01-06-2011, 11:45 PM
Default steelies
After having this car since June, 1988, this is my favorite pic so far... i will be buying new steelies for the rear( no chevy rallys!) ... the front rims are 1969 Firestone 15x4's that my uncle ran on his 69 Camaro... i decided to bring them back out...My Dad also ran them in the early '80s on his GTO(The one that Jeff Verdi has for sale)
  #393
Old 01-07-2011, 10:16 AM
PN's Avatar
PN PN is offline
Thanks Guys...it's been a process piecing it back together from being in storage.. I ran my buick for most of the year and just didn't make the time to get to the track with it...I need to do some more detailing, I want to put my GTO grille back in it and a steel bumper on the front...and a stick if the budget allows.
Jack, we basically got the car to hook up better....and it was cooler... we changed rear shocks, and got a front end alignment... I think I went a 9.01 that night I saw you at cecil....
Now that the car is running I am not sure what to do with it....I think I should have built a 275 car...... oh well.
  #394
Old 01-07-2011, 10:25 AM
Wareagle's Avatar
Smile
Cool pics -- out front -were Pontiacs should be .
ho428 - cool pic with that Bowtie behind you .
  #395
Old 01-07-2011, 04:39 PM
andrewT's Avatar
how about some Catalina pictures Brent?
  #396
Old 01-07-2011, 09:39 PM
I try to get one or two up here tonite or tomorrow... Thanks
  #397
Old 01-08-2011, 12:04 AM
slgenge's Avatar
slgenge slgenge is offline
11.74 @114+ mph this year in Edmonton in a 4200 + lbs car
Name:	GTO Castrol.jpg
1964 Catalina 2+2, 389 Tri-Power , 4 Gear , 8 Lugs Sold 2023
1966 GTO, 467 Stroker Mid 11.58@114 Mph
2002 Firehawk Vert, SOM , 6 speed, all the SLP Goodies
1968 Firebird Race Car,525 CU IAll 10.14@133 MPH
1970 442, # Matching 455, 4 Speed W-25 hood
1972 Buick Stage 1 Flame Orange
  #398
Old 01-08-2011, 12:52 AM
XSIVPWR's Avatar
XSIVPWR XSIVPWR is offline
That purple Goat is bad ass!
  #399
Old 01-09-2011, 09:00 PM
Here is a pic from Oct 9,2010... The day it went two 1.578 60fts... It was runnin good until 1st rnd elims... bad miss a little before 2nd gear...probly started 4500rpms... i think it might be a spark plug... just put a set in before that wknd... maybe MSD? still dont know... will do more research closer to season... did check valvesprings for a broken one...all looked ok. checked distrib cap & rotor too, seemed ok...
  #400
Old 01-09-2011, 11:07 PM
Old Man Taylor's Avatar
Attachment 230339
When I had a similar problem it turned out to be plug wires. Also, your car looks and runs a lot like one that a friend of mine owns.
Name:	Greg Minor1_041199.jpg
