Old 01-19-2011, 12:57 AM
fbrown fbrown is offline
Default 68 Power Window Boot
I can't find and information (pictures) in the 68 service manual or body manual about the power boot.
I assume the car would be punched out at the dimple labeled 3.
Also does anyone know what the hole labeled "1" is for.
I also assume the the door is puched where the dimple is.
The boot is bigger on one end and looks like it could be bolted or riveted to the door and car. I assume that the smaller end is installed in the door and that it would be positioned with the flaps pointed down.
I would really appreciate it if someone could confirm that this is the correct way before I start punching holes.
96 Roadmaster Wagon
2014 Infiniti Q50S Hybrid
Marietta GA
Old 01-19-2011, 02:13 AM
PaulatFast PaulatFast is offline
You have your holes and dimples labeled correctly. Hole A is for the antenna lead. We screwed the grommet to the door.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 01-19-2011, 04:21 AM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
It will be at a little below your arm rest on the door panel. It is 327 am i will look at it beter in the day light.
