Old 02-21-2011, 10:29 AM
77GP's Avatar
77GP 77GP is offline
Default 4x4 help
I have a 90 Chevy truck and cant seem to get the 4 wheel drive to function. It has the shifter down on the floor to engage it. Sometimes it will sound like its grinding a gear when I try to put it in gear but not always. When I do put it in gear I get nothing. What should I start looking at first, is there such a thing as an easy fix sometimes on these without mega money involved? I am not 4 wheel drive literate. One other thing is that when I got it, I thought the lights lit up on the shifter showing if it was in 4 low or high, I dont see that now.
1974 Grand Prix Model J
Old 02-21-2011, 10:30 AM
Chances are the Plunger on the front axle is junk. Pretty typical on those.
former." --Albert Einstein
- Winston Churchill
Old 02-21-2011, 10:35 AM
77GP's Avatar
Is that expensive?
Old 02-21-2011, 10:36 AM
67drake's Avatar
67drake 67drake is online now
Agreed.
This thread might help- http://forums.maxperformanceinc.com/...light=actuator
‘55 Catalina
Old 02-21-2011, 10:40 AM
Originally Posted by 77GP View Post
Is that expensive?
Last one I bought was around 100.00
- Winston Churchill
Old 02-21-2011, 11:25 AM
77GP's Avatar
I read alot on those threads posted. Are you guys talking about the actuator being same as plunger you mentioned?
Everthing points to the actuator, GM one on ebay 60 bucks
But I realize it could be other things. I didn't even know there was fuse or that temp had a part in it. Learned alot today
Old 02-21-2011, 11:43 AM
Yes the Actuator. If it's a GM unit on erape be sure it's the revised [ updated] version.
I've had better luck with the Dorman units than the GM ones in the past.
Mike
- Winston Churchill
Old 02-21-2011, 11:47 AM
My cost thru Carquest is around 80.00 for a OE replacement, upgrade is around 110.00 and requires an adapter harness.
If you're gonna keep it update the unit.
- Winston Churchill
Old 02-21-2011, 11:59 AM
77GP's Avatar
Thanks Mike, I would rather do Carquest parts anyways.
Old 02-21-2011, 12:07 PM
57-2001 is the oe style
Upgrade replacement depends on axle code stamping. Most use a 600 601 actuator. Harness is a 600 600.
IIRC it adapts round pins to rectangular.
- Winston Churchill
Old 02-21-2011, 01:45 PM
beemergary's Avatar
Its probably the actuator on the front axle. Make sure there's POWER going to it. There's also a switch that turns it on at the transfer case. Check the connection at the axle. Summit may even sell the actuator since everybody had problems with them including me and everybody else. I think the light would come on when actuator engaged.
Old 02-21-2011, 03:28 PM
77GP's Avatar
Well I did go out and check the fuse, looks good. Put it down in 4Low and drove it just a second, I could tell something was going on by the way it drove and I could hear the front whining a little. With this rain today, I will have to wait to further investigate. Does that narrow anything down?
Old 02-21-2011, 06:52 PM
gman005's Avatar
gman005 gman005 is offline
i had the same problem it was the a actuator i bought mine at car quest they had it in the doorman section. it was around 65.00 bucks you need to use it about once a month other wise it sticks.
Old 02-22-2011, 12:15 AM
stimpy stimpy is offline
also make sure theres no mechanical linkage to the transfer case, if there is sometimes it can get worn at the bushings and need to be adjusted as if its off a little it won't engage the gears they will grind or pop out when torque is applied . . what series truck and transfer case .
Old 02-24-2011, 10:41 AM
67drake's Avatar
http://www.fullsizechevy.com/forum/g...blems-4x4.html
‘55 Catalina
Old 02-24-2011, 01:50 PM
77GP's Avatar
Well I went out and checked the actuator as described in Drakes post, pulled it out, turned key on and put it 4L, actuator did come and and go back in when I disengaged it. What would be next thing to check? Thanks again
Old 02-24-2011, 04:07 PM
transfer case ..
