Old 02-21-2011, 06:53 PM
61 Tin Man 61 Tin Man is offline
Default thermostatic vacuum switch
61 pontiac thermostatic vacuum switch for the vacuum operated tripower. Are these available? If so, where?
Old 02-22-2011, 09:30 AM
Ron Landis's Avatar
Wink Actually...
I have one out of a '64 unit...if it would work on yours. I dunno.
Old 02-22-2011, 01:04 PM
IM Sent
Old 02-27-2011, 11:20 AM
Ron Landis's Avatar
Question Curious...
anyone know if there is a difference between what was used on '64 GTO units and a '61 unit? Two ports....triangular head and @ 3" long. Bolts into front of intake w/2 bolts. Cannot get my pix to load. Thanks. Ron
Old 02-27-2011, 02:25 PM
Stuart's Avatar
Stuart Stuart is offline
I looked up the part number, and it appears they used the same switch from 1959 through 1964.
Old 02-27-2011, 02:54 PM
Ron Landis's Avatar
Thumbs up That's...
pretty much as I thought. Thanks!!! Ron
Old 02-27-2011, 10:03 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Control Unit
Pictured is a 1960 factory illustration showing the triangle thermo switch. These show up on the auction site at times, but most are in poor condition.
Name:	60 Tri-Power (1).jpg
Old 02-28-2011, 09:13 AM
Ron Landis's Avatar
Thumbs up That's ...
the one. Can't really comment on condition other than it looks fine and I believe I was fair on the price. Looks like they may be rebuildable? Part is headed out today. Thanks, PY!
Old 03-04-2011, 02:10 PM
Received the switch, and they are rebuild-able. As long as the actual sender is still operable.
