Old 02-06-2011, 03:11 PM
clyons's Avatar
clyons clyons is offline
Default Engine paint
At some point the 350 H.O. in my car was painted black. I want to return it to pontiac 66-72 metallic blue. I'm looking for pictures showing what surfaces were blue coming from the factory. Is it possible to paint it without pulling the engine. What issues will I encounter?
Old 02-06-2011, 05:12 PM
Cammer-6 Cammer-6 is offline
going to be pretty tough to get to everything
You may at least need to jack it up and pull a mount off to paint around that.
Factory painted them with flywheel,oil filter but no accessories in place.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-27-2011, 05:32 PM
binskyhere's Avatar
binskyhere binskyhere is offline
Which paint company has the closest color for my 67 Firebird? I see a lot of ads for our metallic blue color but I want one that lasts as well.
Thanks!
Eddie
Old 02-27-2011, 09:12 PM
bird of fire69 bird of fire69 is offline
i like the bill hirsch paint you can order it in quarts or spray can . you can find it online, i believe it is the closest to the orignal color.
Old 03-02-2011, 07:07 PM
mgr52 mgr52 is offline
I would also be interested to hear if you can paint the engine without removing it but I am skeptical
Old 03-03-2011, 04:14 PM
clyons's Avatar
I've been looking at it. My thinking is, if i can see it, i can paint it. If I can't see it who cares. I bought the Hirsch paint mentioned below after reading up on it.
Old 03-03-2011, 04:37 PM
let us know how it goes, would love to see it afterwards
Old 03-03-2011, 05:11 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
+1 Best metallic Pontiac Blue on the market.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 03-04-2011, 11:25 AM
Joebowtie Joebowtie is offline
I have painted engines in the car before. I remove all the items you don't want painted and cover the frame , A arms and any thing else by folding aluminum foil over them. It works great. Joe
Old 03-04-2011, 06:01 PM
69 RA GTO's Avatar
69 RA GTO 69 RA GTO is offline
Does this paint have the slight green tint to it like I see on ALL 69 original motor parts or the standard light blue that is sold every where?
www.69judgeregistry.com
Documenting ALL 1969 Judge and Ram Air GTO cars. If you have one of these cars we would love to hear from you
Old 03-08-2011, 04:11 PM
clyons's Avatar
Spray or brush or both?
Old 03-08-2011, 04:24 PM
jcruz's Avatar
jcruz jcruz is offline
I've painted the engine without removing as well. You're right, you can't get to everything, but you can certainly get to everything viewable when the hood is up.
I used a spray bomb -- carefully masking everything. Get the car jacked up and you can get the oil pan, etc.
It's not a perfect job but it certainly beats looking at chevy orange
69 Firebird/TA clone
Old 03-08-2011, 05:32 PM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
Plasti-Kote #227 Pontiac Metallic Blue works for me. Make sure to shake it good.
I have detailed several cars using this in spray can. Just have to cover or tape off what you don't want paint on. Removing pulleys and brackets works best on the front.
A little patience goes a long way!
[email protected]
Old 03-08-2011, 09:19 PM
I use spray cans. You can spay every angle you need to. I have used spay tips with tubes ( wd 40, carb cleaner) to get to the remote spots. Joe
Old 03-08-2011, 10:54 PM
Birdguy's Avatar
Birdguy Birdguy is offline
Dupli-color DE1616 is also a technically correct reproduction of the original color. I had my local O'Rielly store order me 3 cans and it laid down very well.
Old 07-16-2013, 05:21 PM
clyons's Avatar
Default Engine paint finally done
Well it took a while to get up my nerve. I took most everything off the top except the carb and everything off the front including pulleys, etc. I left the exhaust manifolds and oil pan alone. Used spray and brush on Bill Hirsch pontiac metallic blue. While I was at it I did all the engine bay, fire wall, radiator, etc. in satin black enamel. Masking and Patience are the key. I'm really happy with the outcome.
The paint near the exhaust ports and some spots on the intake are already taking on a
nice burnt hue making it look more "original".
I tried to attach my first jpeg here.
Name:	PY Eng Paint.jpg
Old 07-17-2013, 09:50 AM
indetrucks's Avatar
indetrucks indetrucks is offline
Looks good from here man!
Old 07-17-2013, 12:13 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
WOW! That motor is pristine . I also use 1616 and am working on getting my OHC painted while in the car. I have tested several Pontiac engine paint vendors and the 1616 paint seems to be the best so far. Plasticote although a nice paint does not lay the paint down with uniformity. It tends to glob the paint even when you change the speed of ho it is laid down. It is the brightest paint so far and does look pretty good unused. I have not painted the complete motor yet but I will post pics when it is done.
FWIW it is worth I found ordering the 1616 paint much easier and cheaper at Amazon.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 07-17-2013, 12:36 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Looks good, I use the Plastikote 1616 and like it alot. Best engine color ever 66-70 . Now just lose the Edelbrock stuff and put a black small snorkel Bonneville style air cleaner and plain blue valve covers on it and move the ground cable to a studded front headbolt
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 08-28-2013, 08:06 PM
Keydet86 Keydet86 is offline
Send a message via Skype™ to Keydet86
Looks great. Just sent you a PM. Looking to do the same. I have some questions I am hoping you could answer.
