Old 05-13-2011, 09:51 PM
cutrone's Avatar
cutrone cutrone is offline
Unfortunately I was only able to make a hand full of 1/8 mile passes .
Typical 60ft times with RN converter were mid 1.6's and with ATI 1.60 & 1.61 .
Both Converters flash to around 4000 give or take .
Where I see the most Improvement is in 1/8 mi. et and Mph .
About 2 tenths and 2 Mph ..ATI just feels locked up tighter and Accelerates harder .
I really need to get out and make some 1/4 mi runs .
69 Grand Prix 428 H.O. loaded "J"
11.51 @ 116
  #42
Old 05-16-2011, 07:21 AM
grandville455's Avatar
Bernie
You should pick up more on the top with less slippage? Thats if the 3.73's are enough gear to keep a 8" tight?.. FWIW I was running 7.39 yesterday@ almost 92 and going out the door at upper 60's Track DA was close to 1600. I think Your SR will pull harder than my HR so u should see 50's or better. Where u shifting at?
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
