Industry Stuff new repro's, updates, other info.
Old 03-28-2011, 07:20 AM
ponchopower69's Avatar
ponchopower69 ponchopower69 is offline
Oh most importantly...69 Firebird 4-speed console!!!!! This is a MUCH needed item I know sevarl guys that need one.
Old 05-26-2011, 10:37 AM
61 vent 61 vent is offline
Anything for the 61/62 B bodies.
  #1203
Old 05-26-2011, 10:51 AM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Originally Posted by ponchopower69 View Post
Oh most importantly...69 Firebird 4-speed console!!!!! This is a MUCH needed item I know several guys that need one.
+1,000,000,000
Im tired of seeing original ones go on ebay for $500+
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
  #1204
Old 05-26-2011, 11:36 AM
beargfr beargfr is offline
Complete dash for 69 GTO
'Ram Air' scoop inserts in metal, not plastic.
Bear
  #1205
Old 05-26-2011, 11:43 AM
71ModelJ's Avatar
71ModelJ 71ModelJ is offline
Repro fuel tank for 71-72 grand prix's would be sweet.
  #1206
Old 05-26-2011, 12:07 PM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
I spoke to several mfg's on the GP tank. Each did not sound overly enthusiastic, but I will keep trying. Each year I say something to those guys. GP Mike
  #1207
Old 05-28-2011, 11:48 AM
GT182's Avatar
GT182 GT182 is online now
Manual Shift Linkage Swivel Trunnion for the 64-66 4 speeds.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #1208
Old 05-28-2011, 06:06 PM
TA70455 TA70455 is offline
repro steel hood for 70-76 Trans am. They are making hoods for 77-81's already???? why skip the older cars???
  #1209
Old 05-30-2011, 07:48 AM
bpenrod bpenrod is offline
Door shells for 70 GTO
  #1210
Old 05-30-2011, 07:49 AM
Door shells for 70 GTO.
  #1211
Old 05-30-2011, 11:12 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
in the works! No specific date yet but expect to see it available in the next 12-15 months.
  #1212
Old 05-30-2011, 11:21 PM
Ccass's Avatar
Administrator
Originally Posted by 70&71 TRANSAM OWNER View Post
HI ALL
Has anyone seen or herd of a aftermarket rear bumper for the 70 -- 73 Firebirds??
Bruce
In stock. RFR56A
  #1213
Old 05-31-2011, 07:07 PM
Father&Son73T/A Father&Son73T/A is offline
Unitized wire looms.....PLEASE SOMEONE!
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
  #1214
Old 06-01-2011, 07:48 AM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
'65-6 big car battery trays. Yes, I am jamming the ballot box.
'66 2+2 side trim and retainer clips, quarter panel 2+2 emblems. Cost of NOS is unreal.
'65-6 Coupe / GP gas tanks. Preferably the kind that make their own premium!
  #1215
Old 06-02-2011, 11:47 AM
Rack776's Avatar
Rack776 Rack776 is offline
About time to ask again.......
75-81 Firebird full rear quarter panels - Please! I dont wanna buy
another "good" used quarter section from CA for $1000 only to
find its been in a crash in a previous life.
New metal Please!
Full length frame rails with the front spring hanger area for 74-81
Heck....ANY new sheet metal to restore a 1975 bird would be good for me.
Jason Rackawack
1975 455 Trans Am - 1975 Firebird 400
  #1216
Old 06-02-2011, 12:25 PM
Okay, from the top:
Power Steering Pullies for 67-72, and G-Body Pontiacs.
Perhaps the PS & Alt bracket kits if they are not already available.
Rear Disc Brake Caliper Brackets for 67-72 Rears, where the Brackets accept 10&12-Bolts, and the Strange Dana60 Flange, Then accept either GM Rear Calipers 79, 86, or 95 Lincoln 8.8rear calipers (because they are BETTER with the mini-drum EMERG Brake). And Rear Rotors: 79 T/A, 86 T/A, Lincoln 8.8rear rotors.
An EMERG Brake cable "crimped-to-length" to support ANY Emerg Brake cable application. (I need).
A driveshaft Safety Loop that anchors to the Seat Belt Bolt weld-nuts (Kit would include a pair of longer seat-belt anchor bolts so the Loop can be nutted-on.
Lincoln-style 8.8 Rear Yoke kits for 10&12 Bolts rears to replace the U-Bolt design, GTO size & 1350 size U-Joint.
Front & Rear Shocks with external knobs/setscrew for Up-jounce adjust, & down-jounce adjust.
Ram Air III hood stickers
Aluminum Rear Bumper brackets for 68 GTO
Aluminum Front Bumper brackets for 68-72 GTO
'glass GTO Front nose with actual mounting capability-to-fender-front-holes & Rad Support, to Reliably replace Endura.
Aluminum Front Upper Control Arms that are stock looking, with upper mount bar, either bushed-or-bearing.
Aluminum AC Compressor Mount Bracket-to-Head.
Aluminum Radiator supports for 68-72
Aluminum or black plastic Front wheel wells for 68-72.
Aluminum window crank kits to replace the heavy steel parts in Doors&Quarters.
Aluminum TH400 parts: 1-2 Servo cover, Center-Support, Front Pump Cover, Pump Rear cover too, ValveBody, perhaps the parts that carry HP&TQ.
Pair of Billet Rear Lower Control Arms (seen a pair for a Honda at $200, that are 2" shy of fitting the GTO).
  #1217
Old 06-02-2011, 01:16 PM
Tinindianworkshop's Avatar
Tinindianworkshop Tinindianworkshop is offline
Default LEMANS
67 LEMANS GRILLS,TAIL LIGHTS TAIL LIGHT BEZELS AND EMBLEM BETWEEN TAIL LIGHTS
  #1218
Old 06-02-2011, 07:42 PM
Thomasmoto's Avatar
Thomasmoto Thomasmoto is offline
A bolt in affordable roll bar for 2nd gen f bodies.
79 Pontiac Trans Am
  #1219
Old 06-16-2011, 05:47 PM
Goat & Chicken Farmer's Avatar
Goat & Chicken Farmer Goat & Chicken Farmer is offline
71 GTO Grill insert rings (chrome) These go around the mesh.
"Lucy" 1971 GTO (dad's) A true clean one owner. all orig. #'s match, 400, 4 sp, P/S, A/C, Lucy Blue
"Buffy" 1969 Firebird vert (mine) Not a clean one owner. Born Carousel Red, 350 2bbl, A/T, P/S, P/B, A/C. Now, Primer gray. Will have a 400, 5 sp, P/S, P/B, A/C, Black with carousel red pin stripes.
  #1220
Old 06-17-2011, 12:15 PM
Dustin68's Avatar
Dustin68 Dustin68 is offline
67-69 Firebird th400 dipstick & tube.
Looking for years for one and nowhere to be found
Restoration Album: http://s262.photobucket.com/albums/ii106/colorado68/
