I am selling my 1963 Pontiac Catalina 4d hardtop 389 2bbl factory power brakes, power steering and AC. AC compressor was removed from the car, but is not seized. It will be included with the car. The car runs and drives like it should, and is good on the city streets and the highway.
I have put quite a bit of work into the car New dual master cylinder (ditched the usicide single cylinder) All steel brake lines replaces New brake hoses New wheel cylinders New brake pads Turned the drums New voltage regulator New NOS tail light lenses New upper and lower radiator hoses New 160 degree thermostat New iginition (Accel super coil) Accel wire set 8mm Standard Electric blue streak Distributor cap Standard Electric Blue Streak rotor Standard Electric Blue Streak points/condener Autolite 86 plugs Kelly Charger Tires white letter (750 miles) original rims with 1960 dog dishes New fuel pump New fuel filter oil changed 200 miles ago exhaust is also new Has an oil leak. the oil pan gasket needs to be replaced. The transmission pan gasket should also be replaced. I have the transmission pan gasket already. I am open to trades, I prefer a 40s-50s project car, but will consider cars as new as 74. I am open to cars in any shape. I would prefer your non running solid project in trade for my running daily driver. Call, text or email whenever you like, I work odd hours. If you leave a message please leave a good time to get back to you. Thanks, Dan 414 915 4979 I am looking to get 4500 obo |
SOLD!
